I need a handful of victims volunteers to help test previews of the next build of Reactor. A long-standing request was for "a simple login mechanism," but in practice, adding user authentication and competent access control turned out to be a pretty big project with a lot of big changes on both server and client sides. It's a bit more than I'm comfortable testing myself and springing out to everyone at once, so I'd like to work with a small group to put it through "sea trials."
Major changes/features include:
User authentication with hashed password storage; User group configuration with application restriction (admin, dashboard, API); Detailed control over API access, with user- and token-based authentication/authorization; Improvements to the HTTPS service; Improvements to UI coordination with the core for Rules and Reactions.If this sounds like something you'd like to help with, drop me a reply here in this thread or privately.
I have a case where I'm trying to send a MQTT message similar to the example below:
Topic: pool/set { "command": 4, "value": 1, "time": 0, "interval": 0 }But I need to set "value" so that it is an integer between 20-30. I thought I could use "dimming" capability here, but there's probably a better way. @therealdb ?
(Using userauth-24120-7745fb8d build in Docker)
There's a filtering capability for entities in reactor.yaml, but I have a case where I don't want to filter an entity altogether, but would like to "throttle" it, as this sensor updates every 1-2 seconds (and therefore unnecessarily takes database space).
Sensor data comes through home assistant, and seems that there's no way to control update interval at that end.
So I'm asking if plugin configuration could support limiting/throttling updates for certain entities?
Good morning,
Hopefully this is a simple request. I believe the title should be self explanatory, but just in case, I'll elaborate.
On the status tab, we all get alerts if a device state has changed (i.e., been removed). This is great, but when I go into the entities tab, I have to either type the name (or a portion thereof) of the device that has been removed, or I need to scroll all the way through my list of devices. This is infrequent, however, yesterday I replaced a failed device in my HAAS environment. It was a Z-Wave switch that is added using the Smart Scan QR code, which normally makes it pretty easy. However, some devices don't get fully added the first time around, so it'll add multiple entries into HAAS until it get's the S2 authentication correct and the device fully included. It did this to me yesterday, and I had to delete the incomplete device from my installation. MSR still saw the entities of that failed/incomplete switch entity, and I was left with 8 alerts and entities that I needed to removed.
It's not a huge problem, but this example was just one switch. If I were to add replace multiple devices at once, this could be a bit more annoying to remove. It would be helpful to be able to filter by removed entities, so I can find them all quickly and delete them. Continuing that train of thought, it would also be useful to have check boxes next to those lines, and perhaps do a select all type of thing so they could be deleted in one mouse click.
@toggledbits I have finally finished up the SSL using Let's Encrypt and am getting this from my local browser:
I know you said in the docs that using a self-signed could lead to this but this is LE.
Hi @toggledbits,
I don't know if I'm the only one, so I'm reporting here first instead of opening a bug.
Basically, with the latest 2-3 updates of Reactor and MQTTController, after a restart previous statuses are lost (for both Virtual and MQTT entities), until they're restored.
It's particularly annoying for Virtual Entities, because I have to set them all over again (I've coded some defaults at startup if the values are empty, but sometimes these are not the correct values before the update).
Not easy to reproduce, and logs are gone, but the first time I tought it was me hallucinating, the second one didn't bother too much, after the third I realized it's something not coming from me.
the behavior could be seen in this screenshot:
Any hint is appreciated.
Home Assistant up to version 2021.8.6 supported; the online version of the manual will now state the current supported versions; Fix an error in OWMWeatherController that could cause it to stop updating; Unify the approach to entity filtering on all hub interface classes (controllers); this works for device entities only; it may be extended to other entities later; Improve error detail in messages for EzloController during auth phase; Add isRuleSet() and isRuleEnabled() functions to expressions extensions; Implement set action for lock and passage capabilities (makes them more easily scriptable in some cases); Fix a place in the UI where 24-hour time was not being displayed.I'm slowly migrating all my stuff to MQTT under MSR, so I have a central place to integrate everything (and, in a not-so-distant future, to remove virtual devices from my Vera and leave it running zwave only).
Anyway, here's my reactor-mqtt-contrib package:
Simply download yaml files (everything or just the ones you need) and you're good to go.
I have mapped my most useful devices, but I'll add others soon. Feel free to ask for specific templates, since I've worked a lot in the last weeks to understand and operate them.
The templates are supporting both init and query, so you have always up-to-date devices at startup, and the ability to poll them. Online status is supported as well, so you can get disconnected devices with a simple expression.
Many-many thanks to @toggledbits for its dedication, support, and patience with me and my requests 🙂
Good morning,
So Home Assistant decided to change the default weather home format that I've been using for the past year and a half. I had two Global Expressions set up to pull the high and low temp forecast for the day. Now it's pulling null values.
In the dev tools, it now uses a new service (Weather. get forecasts), plural, where the old Weather.get forecast is depreciated and now longer functions.
It shows a templow field, and a temperature field, which I presume is the forecast high.
When I head back over to MSR, I'm having a hard time finding those values in the Entities tab.
wx.asoftime=null wx.ceiling=null wx.ceiling_unit=null wx.cloud_cover=null wx.condition_code=null wx.description="partlycloudy" wx.feels_like=null wx.humidity=57 wx.humidity_unit="%" wx.icon=null wx.location=null wx.precipitation_1hr=null wx.precipitation_24hr=null wx.precipitation_other=null wx.precipitation_type=null wx.precipitation_unit="in" wx.pressure=30 wx.pressure_unit="inHg" wx.temperature=55 wx.temperature_unit="°F" wx.visibility=null wx.visibility_unit="mi" wx.wind_compass=210.3 wx.wind_conditions=null wx.wind_direction="SSW" wx.wind_gust=null wx.wind_speed=6.28 wx.wind_speed_unit="mph" x_hass.domain="weather" x_hass.entity_id="weather.forecast_home" x_hass.services=["weather"] x_hass.state="partlycloudy" x_hass_attr.attribution="Weather forecast from met.no, delivered by the Norwegian Meteorological Institute." x_hass_attr.cloud_coverage=85.9 x_hass_attr.dew_point=40 x_hass_attr.friendly_name="New Windsor Weather" x_hass_attr.humidity=57 x_hass_attr.precipitation_unit="in" x_hass_attr.pressure=30 x_hass_attr.pressure_unit="inHg" x_hass_attr.supported_features=3 x_hass_attr.temperature=55 x_hass_attr.temperature_unit="°F" x_hass_attr.visibility_unit="mi" x_hass_attr.wind_bearing=210.3 x_hass_attr.wind_speed=6.28 x_hass_attr.wind_speed_unit="mph"There is a x_hass_attr.temperature, but that appears to be the current temperature, not the high that I found on the dev tools screenshot.
Any ideas?
Running:
Core
2024.4.3
Supervisor
2024.04.0
Operating System
12.2
Frontend
20240404.2
MSR: latest-24057-e9add9f5
Hey Patrick, I recently have been noticing that MSR has been acting up ie. it's been needing restarts and has been slow. I began trouble shooting by looking at the logs and have noticed the following errors for a lot of entities. I thought maybe a simple reboot of RPi was needed and I kept seeing the same errors in the system logs. I am oddly enough not seeing these same errors in the MSR logs. Where things started getting weird is whenever I rebooted MSR it wouldn't come back online .I would have to restart the RPi then it would come back online. I just restarted MSR again to capture logs and it restarted fine, so I guess its good for now? I think this is more or so a corrupted SD card issue rather a MSR issue but well being troubleshooting from here. The SD card is about 1-2 years old.
Apologies if this post is everywhere, I cannot consistently recreate any oddities that are happening, that's what is leading me to believe my SD is going bad.
PS: If anyone knows how to diagnose a corrupt SD card please chime in.
MSR latest-24057-e9add9f5
Home Assistant 2024.4.3
Raspberry Pi 3b+
I've rebooted the RPi I've restarted MSR after double-checking the time on the RPi. Used a completely different browser to eliminate any caching concerns. Double-checked MSR reactor.yamla5f23151-d691-4343-8499-8e77a55528e5-image.png
For the standard capabilities MSR sends both a value record and a units record to InfluxDB. The latter I would like not to send as they are not really any use for me and it will reduce the number of records send to my InfluxDB.
Is there a quick way to do this with a filter_entities line like: *>units?
Or do I have to update all capabilities to read like this:
power_sensor:
attributes:
value: true
Cheers Rene
I'm trying to replicate this
into a MQTT entity where I could set a number with a min and max value.
I can't find a standard capability that fits or any documentation on local MQTT capabilities and the only post on the forum mentioning local MQTT capabilities is this post, is it even possible in current release?
My trial and error work in local_mqtt_capabilities.yaml isn't much to show as it's just a copy of mqtt_capabilities.yaml with changed names and then I got stuck.
Any guidance, examples, documentation, future feature request or denial would be much appreciated, thanks!
Reactor 24057-e9add9f5 bare metal
MQTTController 24050
Hi guys,
Any tips are appreciated.
NOTES FROM TROUBLESHOOTING:
'rgb_color.set_rgb' works successfully, which seems strange. You'd think they would both be affected I've tried a couple different formats, like adding quotes, adding/removing spaces between the RGB values, nothing has fixed it.EXAMPLES:
DETAILS:
Bulb is LZW42 by Inovelli MSR version: stable-23242-5ee8e1d4HA DETAILS
Core 2024.2.5 Supervisor 2024.02.1 Operating System 12.0Hi,
Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Noticed right away last night at closing time that the open/close had become inverted with the update to v23326.
Hubitat "hubitat" is reconnecting alert
If you haven't already done so, the docs suggest this:
Install the Hub Information driverIt is highly recommended that you install and configure (create a device using) the Hub Information driver on your hub. This driver is available through Hubitat Package Manager and from Github. The device must also be published by Maker API.
@alan_f said in Hubitat "hubitat" is reconnecting alert:
I too was seeing this message, especially after a reboot, and was curious about it as well. It appeared to happen more often a few builds ago, but has stopped now. I had Hub Info installed, but recently removed it as I wasn't really using it much anymore. However I couldn't find anything in the MSR docs about this though. Maybe I missed it?
But what I did find was how I could include a
username:
andpassword:
in theconfig:
section of the reactor.yaml file to help with this. But when I put these in under the config section, I started getting errors about invalid formatting in the yaml file and my docker wouldn't start anymore. Did I format things wrong? Is my username and password needed if I have Hub Info reinstalled and published via the Marker API?name: __Home Hubitat config: source: "http://[IPADDRESS]/apps/api/4/devices?access_token=TOKEN-KEY" dump_all_devices: false username: thatsme password: itssecret - id: weather enabled: false
@3rdstng That doesn't look right at all. YAML needs all the indentations to be correct, and yours don't match up to the docs which show this:
- id: hubitat enabled: true implementation: HubtitatController name: Hubitat config: source: "http://192.168.0.3/apps/api/166/devices?access_token=4b840f3e-0000-4c1d-0000-357242c2d272"
I'm assuming you have the
- id: hubitat enabled: true implementation: HubitatController
above what you quoted. If so, what comes after that should look something like:
Name needs to be indented two spaces. Everything below needs to be backed up by two spaces so 'config' lines up with 'name' and everything below 'config' lines up with the 'n' in 'config' (I think... I'm a yaml newbie). It also looks like your "- id: weather" is indented more than it should be.
(Disclaimer: I looked at the docs, but I'm not looking at my own config file right now, so this advice may be worth slightly less than you paid for it)
Sorry. I didn't include the very top of my Hubitat section. It does have the id: stuff. I think I was missing the two spaces. I went back and edited the yaml more and made sure those additional spaces were there. Then restarted the docker and everything worked just fine.
