Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
[SOLVED] All Modes not visible in MSR 21337 from Hubitat
I updated to
latest-21337-b535732
last night before heading off to sleep. I have a ruleset that checks forphone charging
, modeevening
, and room-assistanthome
. The system then waits five minutes and flips to modenight
and announces it has done so via Echo devices.At 05:30 ET each morning the system shifts to mode
day
.However...
Last night MSR went thru the paces but mode
evening
never switched to modenight
. Multiple attempts including reboots of MSR and Hubitat, no change.This morning, instead of mode
day
it went back to modeevening
which isn't supposed to trigger until sunset. This is confirmed across MSR, H-A, and Hubitat.I'd missed the 21336 update and went from 21332 to 21337. I'll be log diving after coffee is ready.
Updated title to reflect what the issue seems to actually be.
@gwp1 This is interesting: can't have the house in mode
evening
so I hit thereset
icon on theday mode
rulesetRule ID: rule-kmfo3pz8
. It shows I took the action:...but I don't see any reference to that action in the log nor did the mode change to
day
.This is the log since 0529 ET.
[latest-21337]2021-12-04T15:05:29.018Z <Rule:NOTICE> Rule#rule-kmfo3pz8 resetting! [latest-21337]2021-12-04T15:05:29.020Z <Rule:NOTICE> Rule#rule-kmfo3pz8 stopping rule [latest-21337]2021-12-04T15:05:29.021Z <Rule:5:Rule.js:743> Rule#rule-kmfo3pz8 acquiring semaphore [latest-21337]2021-12-04T15:05:29.023Z <Rule:5:Rule.js:746> Rule#rule-kmfo3pz8 semaphore acquired; releasing timer [latest-21337]2021-12-04T15:05:29.024Z <Rule:5:Rule.js:746> Rule#rule-kmfo3pz8 semaphore acquired; unsubscribing from condition dependencies [latest-21337]2021-12-04T15:05:29.036Z <Rule:5:Rule.js:748> Rule#rule-kmfo3pz8 saving states [latest-21337]2021-12-04T15:05:29.041Z <Rule:5:Rule.js:752> Rule#rule-kmfo3pz8 stopped [latest-21337]2021-12-04T15:05:29.041Z <Rule:NOTICE> Rule Rule#rule-kmfo3pz8 stopped [latest-21337]2021-12-04T15:05:29.044Z <Rule:NOTICE> Rule#rule-kmfo3pz8 restarting after reset [latest-21337]2021-12-04T15:05:29.045Z <Rule:5:Rule.js:716> Rule#rule-kmfo3pz8 start(), awaiting semaphore [latest-21337]2021-12-04T15:05:29.051Z <Rule:5:Rule.js:724> Rule#rule-kmfo3pz8 restored states: trig=(null), rule=(null) [latest-21337]2021-12-04T15:05:29.052Z <Rule:5:Rule.js:724> Rule#rule-kmfo3pz8 subscribing to dependencies [latest-21337]2021-12-04T15:05:29.053Z <Rule:INFO> Rule#rule-kmfo3pz8 (Day mode: 05:30 ET) started [latest-21337]2021-12-04T15:05:29.054Z <Rule:5:Rule.js:728> Rule#rule-kmfo3pz8 start() dependencies resolved, performing initial evaluation [latest-21337]2021-12-04T15:05:29.055Z <Rule:5:Rule.js:1005> Rule#rule-kmfo3pz8 (Day mode: 05:30 ET) evaluate() acquiring mutex [latest-21337]2021-12-04T15:05:29.056Z <Rule:5:Rule.js:1009> Rule#rule-kmfo3pz8._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T15:05:29.057Z <Rule:5:Rule.js:1013> Rule#rule-kmfo3pz8 update rate is 0/min limit 60/min [latest-21337]2021-12-04T15:05:29.058Z <Rule:5:Rule.js:936> Rule#rule-kmfo3pz8 evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T15:05:29.065Z <Rule:5:Rule.js:1689> cond cond6xza990 evaluation state (null)->false [latest-21337]2021-12-04T15:05:29.069Z <Rule:5:Rule.js:1689> cond condkmfo3pz8 evaluation state (null)->true [latest-21337]2021-12-04T15:05:29.074Z <Rule:5:Rule.js:1689> cond condeadfqgq evaluation state (null)->true [latest-21337]2021-12-04T15:05:29.075Z <Rule:5:Rule.js:1689> cond trig evaluation state (null)->false [latest-21337]2021-12-04T15:05:29.079Z <Rule:5:Rule.js:1033> Rule#rule-kmfo3pz8._evaluate() trigger state now false (was (null)) [latest-21337]2021-12-04T15:05:29.080Z <Rule:5:Rule.js:1035> Rule#rule-kmfo3pz8._evaluate() constraints state true [latest-21337]2021-12-04T15:05:29.081Z <Rule:5:Rule.js:1041> Rule#rule-kmfo3pz8 trigger conditions not met [latest-21337]2021-12-04T15:05:29.081Z <Rule:5:Rule.js:1042> Rule#rule-kmfo3pz8 rule state changed, was (undefined) now false [latest-21337]2021-12-04T15:05:29.082Z <Rule:INFO> Day mode: 05:30 ET (Rule#rule-kmfo3pz8) RESET! [latest-21337]2021-12-04T15:05:29.083Z <Rule:5:Rule.js:1044> Rule#rule-kmfo3pz8 rule state now false, changed true [latest-21337]2021-12-04T15:05:38.996Z <Rule:5:Rule.js:793> Rule#rule-grpoix7c2a Office On/Off requesting eval; entity-changed from Entity#hubitat>51 [latest-21337]2021-12-04T15:05:38.997Z <Rule:5:Rule.js:1005> Rule#rule-grpoix7c2a (Office On/Off) evaluate() acquiring mutex [latest-21337]2021-12-04T15:05:38.998Z <Rule:5:Rule.js:1009> Rule#rule-grpoix7c2a._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T15:05:38.999Z <Rule:5:Rule.js:1013> Rule#rule-grpoix7c2a update rate is 4/min limit 60/min [latest-21337]2021-12-04T15:05:39.000Z <Rule:5:Rule.js:936> Rule#rule-grpoix7c2a evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T15:05:39.006Z <Rule:5:Rule.js:1033> Rule#rule-grpoix7c2a._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T15:05:39.007Z <Rule:5:Rule.js:1035> Rule#rule-grpoix7c2a._evaluate() constraints state true [latest-21337]2021-12-04T15:05:39.008Z <Rule:5:Rule.js:1044> Rule#rule-grpoix7c2a rule state now false, changed no [latest-21337]2021-12-04T15:05:45.991Z <Rule:5:Rule.js:793> Rule#rule-grpoix7c2a Office On/Off requesting eval; entity-changed from Entity#hubitat>51 [latest-21337]2021-12-04T15:05:45.995Z <Rule:5:Rule.js:1005> Rule#rule-grpoix7c2a (Office On/Off) evaluate() acquiring mutex [latest-21337]2021-12-04T15:05:45.998Z <Rule:5:Rule.js:1009> Rule#rule-grpoix7c2a._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T15:05:46.000Z <Rule:5:Rule.js:1013> Rule#rule-grpoix7c2a update rate is 4/min limit 60/min [latest-21337]2021-12-04T15:05:46.002Z <Rule:5:Rule.js:936> Rule#rule-grpoix7c2a evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T15:05:46.005Z <Rule:5:Rule.js:1033> Rule#rule-grpoix7c2a._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T15:05:46.007Z <Rule:5:Rule.js:1035> Rule#rule-grpoix7c2a._evaluate() constraints state true [latest-21337]2021-12-04T15:05:46.009Z <Rule:5:Rule.js:1044> Rule#rule-grpoix7c2a rule state now false, changed no [latest-21337]2021-12-04T15:06:02.533Z <Rule:5:Rule.js:793> Rule#rule-kphozuch Upstairs bulb requesting eval; entity-changed from Entity#hubitat>55 [latest-21337]2021-12-04T15:06:02.534Z <Rule:5:Rule.js:793> Rule#rule-komaz8fr Upstairs motion requesting eval; entity-changed from Entity#hubitat>55 [latest-21337]2021-12-04T15:06:02.535Z <Rule:5:Rule.js:1005> Rule#rule-kphozuch (Upstairs bulb) evaluate() acquiring mutex [latest-21337]2021-12-04T15:06:02.535Z <Rule:5:Rule.js:1005> Rule#rule-komaz8fr (Upstairs motion) evaluate() acquiring mutex [latest-21337]2021-12-04T15:06:02.536Z <Rule:5:Rule.js:1009> Rule#rule-kphozuch._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T15:06:02.537Z <Rule:5:Rule.js:1013> Rule#rule-kphozuch update rate is 0/min limit 60/min [latest-21337]2021-12-04T15:06:02.538Z <Rule:5:Rule.js:936> Rule#rule-kphozuch evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T15:06:02.540Z <Rule:5:Rule.js:1033> Rule#rule-kphozuch._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T15:06:02.541Z <Rule:5:Rule.js:1035> Rule#rule-kphozuch._evaluate() constraints state true [latest-21337]2021-12-04T15:06:02.541Z <Rule:5:Rule.js:1044> Rule#rule-kphozuch rule state now false, changed no [latest-21337]2021-12-04T15:06:02.545Z <Rule:5:Rule.js:1009> Rule#rule-komaz8fr._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T15:06:02.545Z <Rule:5:Rule.js:1013> Rule#rule-komaz8fr update rate is 0/min limit 60/min [latest-21337]2021-12-04T15:06:02.546Z <Rule:5:Rule.js:936> Rule#rule-komaz8fr evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T15:06:02.548Z <Rule:5:Rule.js:1033> Rule#rule-komaz8fr._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T15:06:02.549Z <Rule:5:Rule.js:1035> Rule#rule-komaz8fr._evaluate() constraints state true [latest-21337]2021-12-04T15:06:02.549Z <Rule:5:Rule.js:1044> Rule#rule-komaz8fr rule state now false, changed no [latest-21337]2021-12-04T15:06:03.376Z <Rule:5:Rule.js:793> Rule#rule-grpoix7c2a Office On/Off requesting eval; timer-trigger from Timer#rule-grpoix7c2a [latest-21337]2021-12-04T15:06:03.377Z <Rule:5:Rule.js:1005> Rule#rule-grpoix7c2a (Office On/Off) evaluate() acquiring mutex [latest-21337]2021-12-04T15:06:03.378Z <Rule:5:Rule.js:1009> Rule#rule-grpoix7c2a._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T15:06:03.379Z <Rule:5:Rule.js:1013> Rule#rule-grpoix7c2a update rate is 3/min limit 60/min [latest-21337]2021-12-04T15:06:03.380Z <Rule:5:Rule.js:936> Rule#rule-grpoix7c2a evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T15:06:03.381Z <Rule:5:Rule.js:1033> Rule#rule-grpoix7c2a._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T15:06:03.382Z <Rule:5:Rule.js:1035> Rule#rule-grpoix7c2a._evaluate() constraints state true [latest-21337]2021-12-04T15:06:03.383Z <Rule:5:Rule.js:1044> Rule#rule-grpoix7c2a rule state now false, changed no
I just tested mode sensitivity, which I also had done before the build, and it's working as expected. So that part is fine. The log shows "Day mode" rule is going to Reset state, so unless your action is in the Reset reaction, I wouldn't expect it to log the change you seem to anticipate. You haven't shown the rules or reactions, so I have no way of judging what it will do or whether what I can see it doing is right. Show your work, please! Also check your host time zone settings. Logs are Zulu (UTC), not ET, and that would account for a five hour difference in host time vs log time, normally (standard time).
http://your-reactor-ip:8111/diag/sun
Also look at the rule detail panel any time you are troubleshooting logic. Your log snippets don't show any actions being run at all for
rule-kmfo3pz8
, just the rule eval/update to Reset state. Logging of actions in HubitatController is currently unconditional, so if any action was being sent, it would be in the logs (regardless of log level). -
The host time is currently 12/4/2021, 10:41:24 AM offset -300 minutes from UTC
, which lines up to log timestamps of 15:xx:xx.This ruleset hasn't changed since MSR came online months ago so I'm loathe to point to that, esp since it's across multiple modes.
Searching the log for this ruleset shows it first appearing at that RESET! line.
I've rolled back to 21332 and retested. Mode
day
did not kick over as expected. Given this has worked flawlessly with this build I'm digging further. Right now it appears like the house never moved to modenight
even though all the actions (lights off, announcement made, unlocked locks locked) happened.How far back does MSR retain logs time-wise?
@gwp1 said in Modes not changing correctly since 21337:
As far as your log rotation allows.
Can you go back to 21337 and show the result of the rule detail/status panel?
Also, make sure to check the case of all mode setting actions. Mode names are case-sensitive in Hubitat ( day =/= Day ), so if they don't match, the action won't work. When testing in conditions, make sure the test is case-insensitive (it is in the rule you've shown, so that's good).
@toggledbits I just moved back to 21337 a moment ago. I cannot seem to get the house into mode
night
atm. Troubleshooting this as my thinking now is that the house, though doing all the actions (and I repeated that just now), doesn't actually going into modenight
anymore. -
Try "Night" (capital N)... case matters to Hubitat
@toggledbits When it is time for the house to go into
night
there is an Alexa routine that flips a virtual switch. This is the sole trigger and the result is the running of a Reaction.This has been unchanged.
At the end of the reaction is a :10 delay and the virtual switch flips back off again (for next time.) That's it. Nothing fancy. All of these steps are working except for the mode actually changing to
night
.This has worked for MONTHS untouched. I'm literally watching it step thru here:
@toggledbits This is odd. Wouldn't I expect to see all the modes listed under
x_hubitat_sys_mode.modes={"Day":1}
?Tried setting
Night
from the Entities list actions. Nada.[latest-21337]2021-12-04T16:45:03.111Z <Rule:5:Rule.js:793> Rule#rule-kphozuch Upstairs bulb requesting eval; entity-changed from Entity#hubitat>55 [latest-21337]2021-12-04T16:45:03.112Z <Rule:5:Rule.js:793> Rule#rule-komaz8fr Upstairs motion requesting eval; entity-changed from Entity#hubitat>55 [latest-21337]2021-12-04T16:45:03.113Z <Rule:5:Rule.js:1005> Rule#rule-kphozuch (Upstairs bulb) evaluate() acquiring mutex [latest-21337]2021-12-04T16:45:03.114Z <Rule:5:Rule.js:1005> Rule#rule-komaz8fr (Upstairs motion) evaluate() acquiring mutex [latest-21337]2021-12-04T16:45:03.120Z <Rule:5:Rule.js:1009> Rule#rule-kphozuch._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T16:45:03.121Z <Rule:5:Rule.js:1013> Rule#rule-kphozuch update rate is 0/min limit 60/min [latest-21337]2021-12-04T16:45:03.122Z <Rule:5:Rule.js:936> Rule#rule-kphozuch evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T16:45:03.124Z <Rule:5:Rule.js:1033> Rule#rule-kphozuch._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T16:45:03.125Z <Rule:5:Rule.js:1035> Rule#rule-kphozuch._evaluate() constraints state true [latest-21337]2021-12-04T16:45:03.127Z <Rule:5:Rule.js:1044> Rule#rule-kphozuch rule state now false, changed no [latest-21337]2021-12-04T16:45:03.131Z <Rule:5:Rule.js:1009> Rule#rule-komaz8fr._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T16:45:03.133Z <Rule:5:Rule.js:1013> Rule#rule-komaz8fr update rate is 0/min limit 60/min [latest-21337]2021-12-04T16:45:03.134Z <Rule:5:Rule.js:936> Rule#rule-komaz8fr evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T16:45:03.136Z <Rule:5:Rule.js:1033> Rule#rule-komaz8fr._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T16:45:03.137Z <Rule:5:Rule.js:1035> Rule#rule-komaz8fr._evaluate() constraints state true [latest-21337]2021-12-04T16:45:03.139Z <Rule:5:Rule.js:1044> Rule#rule-komaz8fr rule state now false, changed no [latest-21337]2021-12-04T16:45:46.427Z <Rule:5:Rule.js:793> Rule#rule-grpoix7c2a Office On/Off requesting eval; entity-changed from Entity#hubitat>51 [latest-21337]2021-12-04T16:45:46.429Z <Rule:5:Rule.js:1005> Rule#rule-grpoix7c2a (Office On/Off) evaluate() acquiring mutex [latest-21337]2021-12-04T16:45:46.431Z <Rule:5:Rule.js:1009> Rule#rule-grpoix7c2a._evaluate() mutex acquired, evaluating [latest-21337]2021-12-04T16:45:46.432Z <Rule:5:Rule.js:1013> Rule#rule-grpoix7c2a update rate is 2/min limit 60/min [latest-21337]2021-12-04T16:45:46.433Z <Rule:5:Rule.js:936> Rule#rule-grpoix7c2a evaluateExpressions() with 0 expressions [latest-21337]2021-12-04T16:45:46.436Z <Rule:5:Rule.js:1033> Rule#rule-grpoix7c2a._evaluate() trigger state now false (was false) [latest-21337]2021-12-04T16:45:46.437Z <Rule:5:Rule.js:1035> Rule#rule-grpoix7c2a._evaluate() constraints state true [latest-21337]2021-12-04T16:45:46.439Z <Rule:5:Rule.js:1044> Rule#rule-grpoix7c2a rule state now false, changed no [latest-21337]2021-12-04T16:45:46.673Z <HubitatController:null> HubitatController#hubitat final action path for x_hubitat_sys_mode.set on Entity#hubitat>sys_mode: http://192.168.1.214/apps/api/14/modes/Night
According to the entity, the only mode that exists on the hub is Day. Log in to your hub and check the Modes screen. If that agrees, something happened to your hub (firmware upgrade to latest new version recently?).
Latest release to 2.3.0.115 on Hubitat. Rolling back to .113 to see what happens.
Are you on their latest firmware?
@toggledbits Well I was until apparently an hour ago lol Seems there's .116 out now. Also, rolling back apparently doesn't restore the old firmware to .113 like I thought it would. I'm still on .115. Guess I'll fail forward to .116.
@gwp1 On Hubitat's latest, .116. No change.
Following my Rule#1 of troubleshooting, "what changed?" I rolled back MSR to 21332 (because I'd just updated to 21337) just in case and now I see this:
Things are behaving as they should. Using the
Entities
menu I triggered modenight
and it flipped over (only to flip back today
as it should because it's day time - but I watched it three times visibly flip to the correct mode.) -
Yup, and I think I see the issue... stay tuned...
OK. 21338
