  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 123.9k Views 6 Watching
      Mmm looked high and low for the Shelly bridge and can find no mention of it. Using openLuup ver 2021.03.01b. What's the trick?
        That's odd, I am running 2021.02.20 and had mine show up once I upgraded even though I did not setup anything for it. Maybe you need to enable the MQTT server?
          @a-lurker you need to enable the MQTT server and also the Shelly’s use of MQTT. Bridge is then created automatically.
          @rafale77 this is now fixed. Update to latest and delete the plugin device.
          • ElcidE Offline
            ElcidE Offline
            Elcid
            @akbooer
            Just playing and adding some shelly 1's the bridged mqtt server finds the devices and the switch and relay variable update, all good there. Just have to ask are the set target actions and status implemented? As the status never updates.
              Hmm... should be. Both SetTarget and ToggleState actions are implemented.
              I haven't got any Shelly 1s but it works for the 2.5.
              ElcidE 1 Reply Last reply
                ElcidE Offline
                ElcidE Offline
                Elcid
                wrote on last edited by Elcid
                @akbooer
                Here is the returned error
                and when i toggle button on altui device i get this in log but no response on physical device.
                2021-04-16 17:35:07.971   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=587647848&Timeout=60&MinimumDelay=1500&_=1618590331394 HTTP/1.1 tcp{client}: 0xf3280b98
                2021-04-16 17:35:12.250   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=30005&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1 HTTP/1.1 tcp{client}: 0xf32afcf8
                2021-04-16 17:35:12.254   luup.call_action:: 30005.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                2021-04-16 17:35:12.255   luup.call_action:: action will be handled by parent: 46
                2021-04-16 17:35:12.256   openLuup.server:: request completed (44 bytes, 1 chunks, 3 ms) tcp{client}: 0xf32afcf8
                2021-04-16 17:35:14.492   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=30005&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0 HTTP/1.1 tcp{client}: 0xf32afcf8
                2021-04-16 17:35:14.495   luup.call_action:: 30005.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                2021-04-16 17:35:14.497   luup.call_action:: action will be handled by parent: 46
                2021-04-16 17:35:14.499   openLuup.server:: request completed (44 bytes, 1 chunks, 5 ms) tcp{client}: 0xf32afcf8
                2021-04-16 17:35:15.497   openLuup.server:: request completed (3627 bytes, 1 chunks, 7566 ms) tcp{client}: 0xf345b938
                2021-04-16 17:35:15.508   openLuup.server:: request completed (3627 bytes, 1 chunks, 7535 ms) tcp{client}: 0xf3280b98
                2021-04-16 17:35:15.511   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0xf345b938
                2021-04-16 17:35:15.519   openLuup.io.server:: HTTP:3480 connection from 192.168.1.10 tcp{client}: 0xf38161e8
                2021-04-16 17:35:15.526   openLuup.server:: GET /data_request?id=status&DataVersion=587647852&Timeout=15&MinimumDelay=100&output_format=json&_r=1618590915513 HTTP/1.1 tcp{client}: 0xf38161e8
                2021-04-16 17:35:15.651   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=587647852&Timeout=60&MinimumDelay=1500&_=1618590331395 HTTP/1.1 tcp{client}: 0xf3280b98
                2021-04-16 17:35:20.890   openLuup.server:: GET /openLuup?page=log HTTP/1.1 tcp{client}: 0xf32afcf8
                Does the fact that the devices are set to a broker that is bridged to openLuup have any bearing
                P.S. where can we change the polling fequency?
                  So device #46 is your Shelly bridge?
                  Which polling frequency were you thinking of?
                  • ElcidE Offline
                    ElcidE Offline
                    Elcid
                    The devices seem to be updating in reactor(MSR) every 30 seconds, but there has been no actions in that time, they just seem very chatty
                    Yes 46 is the shelly bridge
                    [edit] also noting that openLuup cpu has gone from 0.6 - 1% to 3 - 3.8 %
                      Oh, you mean the Shelly devices themselves. This is on each individual Shelly device and related to :
                      Internet & Security > ADVANCED - DEVELOPER SETTINGS > MQTT > Keep Alive.
                      ...but I'm not sure. I you make this longer, it will take londer for your devices to be discovered initially (but that doesn't really matter.) Updates should be effectively instant.
                      Edit: that increase in CPU doen't seem right. I can barely detect any difference... unless you are subscribed to everything (with, for example MQTT Explorer.) Even then it should be minimal.
                      • ElcidE Offline
                        ElcidE Offline
                        Elcid
                        Strange keep alive is set to 60s and the updates are every 30
                        the only thing subscribed to openLuup is the mosquitto broker with #, all devices are subscribed to mosquitto
                          Yes, I think it uses half the keep-alive time.
                            @Elcid
                            Can I see the openLuup device variable page for the Shelly device in question?
                              @Elcid
                              ElcidE Offline
                              ElcidE Offline
                              Elcid
                              @akbooer
                              HaDevice1		CommFailure
                              HaDevice1		Configured
                              HaDevice1		LastUpdate
                              2021-04-16 18:30:58
                              HaDevice1		PollMinDelay
                              60
                              HaDevice1	history graph	PollingEnabled
                              SwitchPower1		Status
                              SwitchPower1		Target
                              93FC56		announce
                              {"id":"shelly1-93FC56","model":"SHSW-1","mac":"BCDDC293FC56","ip":"192.168.1.100","new_fw":true,"fw...
                              93FC56		input/0
                              93FC56		input_event/0
                              {"event":"","event_cnt":0}
                              93FC56		online
                              true
                              93FC56		relay/0
                              off
                              • ElcidE Offline
                                ElcidE Offline
                                Elcid
                                The cpu usage seems to be MSR. I linked MSR to openLuup at same time I added shelly 1's.
                                CPU now at 0.8%
                                  Good news re. CPU.
                                  On the action call, are you using the right device? There should be a child device which is a binary light, rather than the device with the Shelly icon.
                                  • ElcidE Offline
                                    ElcidE Offline
                                    Elcid
                                    Yep, using device 30005 a binary type device
                                      Can you post the content of one of its status messages, so that I can reproduce the problem?
                                      • ElcidE Offline
                                        ElcidE Offline
                                        Elcid
                                        subscribing to shellies/shelly1-93FC56/relay/0
                                        "off" or "on"
                                        depeding on the switch position
                                          Ah, no, sorry. I meant specifically the announce message (first one after bridge starts up.)
