  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 115.1k Views 6 Watching
    Yes, that’s really weird, isn’t it?
    I must try harder…
    @akbooer if I remember correctly, I’ve experienced something similar while developing my virtual Dimmer and this should be related to target/status variables (in this case loadleveltarget).
      @therealdb said in openLuup: Shelly Bridge plugin:
      Thanks, yes, indeed it's something like that.
      The curious this is that the AltUI dimmer controls work differently from each other, so this rather looks like a 'feature' of AltUI.
      As far as I can tell from the openLuup side of things, it's working as it should. The nasty hack is to allow the status to override the target, but that brings other side-effects. It's usually more of an issue if there is a slow ramp involved too.
      I hate dimmers.
        #83
        @akbooer It's been awhile but I thought I would try out a gen2 Shelly Plus H&T. It's a nice looking device.
        The openLuup Shelley bridge has some initial support for Gen2 devices but I encountered quite a few show stoppers. The gen2 devices use different topics and Remote Procedure Calls (RPC) seem to be the new direction. I can go into that further but I thought this would be a starting point:
        With the log below; openLuup and the Shelly don't know about each other as yet and I get this RX error every time the Shelly publishes an event. I have no idea why. The Shelley device spits out event info unprompted, as it lets the world know of its status. I see this in MQTT explorer:
        zigbee2mqtt
        $SYS
        shellyplusht-80646fc9b46d
         online = true
          events
          rpc = {
          "src": "shellyplusht-80646fc9b46d",
          "dst": "shellyplusht-80646fc9b46d/events",
          "method": "NotifyFullStatus",
          "params": {
            "ts": 1.49,
            "ble": {},
            "cloud": {
              "connected": false
            "devicepower:0": {
              "id": 0,
              "battery": {
                "V": 0.43,
                "percent": 0
              "external": {
                "present": true
            "ht_ui": {},
            "humidity:0": {
              "id": 0,
              "rh": 51.8
            "mqtt": {
              "connected": true
            "sys": {
              "mac": "<mac address>",
              "restart_required": false,
              "time": null,
              "unixtime": null,
              "uptime": 1,
              "ram_size": 246868,
              "ram_free": 167952,
              "fs_size": 458752,
              "fs_free": 176128,
              "cfg_rev": 11,
              "kvs_rev": 0,
              "webhook_rev": 0,
              "available_updates": {},
              "wakeup_reason": {
                "boot": "deepsleep_wake",
                "cause": "status_update"
              "wakeup_period": 600
            "temperature:0": {
              "id": 0,
              "tC": 21.9,
              "tF": 71.5
            "wifi": {
              "sta_ip": "<ip address>",
              "status": "got ip",
              "ssid": "<sid>",
              "rssi": -67
            "ws": {
              "connected": false
        And the log looks like this:
        2023-12-20 13:32:14.259   openLuup.io.server:: MQTT:1883 connection from <ip address> tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.261   openLuup.mqtt:: CONNECT	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.261   openLuup.mqtt:: ClientId: 	shellyplusht-80646fc9b46d
        2023-12-20 13:32:14.261   openLuup.mqtt:: WillTopic: 	shellyplusht-80646fc9b46d/online
        2023-12-20 13:32:14.261   openLuup.mqtt:: WillMessage: 	false
        2023-12-20 13:32:14.261   openLuup.mqtt:: UserName: 	****
        2023-12-20 13:32:14.261   openLuup.mqtt:: Password: 	****
        2023-12-20 13:32:14.262   openLuup.mqtt:: CONNACK	ack
        2023-12-20 13:32:14.273   openLuup.mqtt:: SUBSCRIBE	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.273   openLuup.mqtt:: Packet Id: 0x0001
        2023-12-20 13:32:14.273   openLuup.mqtt:: Topic: 	shellyplusht-80646fc9b46d/rpc
        2023-12-20 13:32:14.273   openLuup.mqtt:: SUBACK	ack
        2023-12-20 13:32:14.274   openLuup.mqtt:: shellyplusht-80646fc9b46d SUBSCRIBE to shellyplusht-80646fc9b46d/rpc tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.279   openLuup.mqtt:: SUBSCRIBE	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.279   openLuup.mqtt:: Packet Id: 0x0002
        2023-12-20 13:32:14.279   openLuup.mqtt:: Topic: 	shellyplusht-80646fc9b46d/command/sys
        2023-12-20 13:32:14.280   openLuup.mqtt:: SUBACK	ack
        2023-12-20 13:32:14.280   openLuup.mqtt:: shellyplusht-80646fc9b46d SUBSCRIBE to shellyplusht-80646fc9b46d/command/sys tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.282   openLuup.mqtt:: SUBSCRIBE	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.282   openLuup.mqtt:: Packet Id: 0x0003
        2023-12-20 13:32:14.282   openLuup.mqtt:: Topic: 	shellyplusht-80646fc9b46d/command
        2023-12-20 13:32:14.282   openLuup.mqtt:: SUBACK	ack
        2023-12-20 13:32:14.283   openLuup.mqtt:: shellyplusht-80646fc9b46d SUBSCRIBE to shellyplusht-80646fc9b46d/command tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.285   openLuup.mqtt:: SUBSCRIBE	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.285   openLuup.mqtt:: Packet Id: 0x0004
        2023-12-20 13:32:14.285   openLuup.mqtt:: Topic: 	shellies/command
        2023-12-20 13:32:14.285   openLuup.mqtt:: SUBACK	ack
        2023-12-20 13:32:14.285   openLuup.mqtt:: shellyplusht-80646fc9b46d SUBSCRIBE to shellies/command tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.287   openLuup.mqtt:: PUBLISH	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.288   openLuup.mqtt:: PUBACK	ack
        2023-12-20 13:32:14.290   openLuup.mqtt:: PUBLISH	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.290   openLuup.mqtt:: PUBACK	ack
        2023-12-20 13:32:14.293   openLuup.mqtt:: PUBLISH	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:14.293   openLuup.mqtt:: PUBACK	ack
        2023-12-20 13:32:16.280   openLuup.mqtt:: PUBLISH	 	tcp{client}: 0x559e2a9768
        2023-12-20 13:32:16.281   openLuup.mqtt:: PUBACK	ack
        2023-12-20 13:32:16.775   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x559e2a9768
        2023-12-20 13:32:16.775   openLuup.mqtt:: RECEIVE ERROR: (Fixed Header byte) closed tcp{client}: 0x559e2a9768
        2023-12-20 13:32:16.775   openLuup.mqtt:: shellyplusht-80646fc9b46d UNSUBSCRIBE from shellyplusht-80646fc9b46d/rpc tcp{client}: 0x559e2a9768
        2023-12-20 13:32:16.776   openLuup.mqtt:: shellyplusht-80646fc9b46d UNSUBSCRIBE from shellyplusht-80646fc9b46d/command tcp{client}: 0x559e2a9768
        2023-12-20 13:32:16.776   openLuup.mqtt:: shellyplusht-80646fc9b46d UNSUBSCRIBE from shellyplusht-80646fc9b46d/command/sys tcp{client}: 0x559e2a9768
        2023-12-20 13:32:16.776   openLuup.mqtt:: shellyplusht-80646fc9b46d UNSUBSCRIBE from shellies/command tcp{client}: 0x559e2a9768
        Looks like openLuup is expecting more but the Shelley device is all done?
        I looked around mqtt.lua but the only thing that I thought may be incorrect is line 201:
        for i = 0, 2 do                   -- maximum of 3 bytes encode remaining length, LSB first
        As I understand it, the protocol is 4 bytes here, not three, so the for loop is short by one. However, this wouldn't be found out, unless your mqtt message was more than 2 megabytes long, so not likely to be encountered any time soon.
          #84
          Thanks for the error report. Not surprising, since, as you say, there is only limited support for the new Shellys. I've just added them on an as-needed basis, and I don't have that device (looks interesting, though!)
          @a-lurker said in openLuup: Shelly Bridge plugin:
          No, this is not an error. The initial fixed-header byte is picked up in line 196:
          local fixed_header_byte1, err = client: receive (1)
          I'll look into this further and get back to you.
          AK
            You have fixed_header_byte1, which is essential and nothing would work with out it but the subsequent message length encoding is a four byte concertina arrangement, not a three byte one.
              Ah! My mistake. I will fix that. Thanks.
              As you say, though, that’s not the issue here.
                The error seems odd, since the receive function is only called from the incoming handler when there is data to read...
                I'm perplexed.
                  I added a one line of logging after line 296 & 297 like so:
                    function MQTT_packet.PUBLISH (TopicName, ApplicationMessage, control_flags)
                      -- publish to MQTT client socket (with QoS = 0)
                      _log ('Topic: '..TopicName..' ApplicationMessage: '..ApplicationMessage)
                  and here is the log edited to show the action:
                  CONNECT	 	tcp{client}: 0x55a8931288
                  WillMessage: 	false
                  UserName: 	****
                  Password: 	****
                  CONNACK	ack
                  SUBSCRIBE	 	tcp{client}: 0x55a8931288
                  Packet Id: 0x0001
                  SUBACK	ack
                  shellyplusht-80646fc9b46d SUBSCRIBE to shellyplusht-80646fc9b46d/rpc tcp{client}: 0x55a8931288
                  Packet Id: 0x0002
                  SUBACK	ack
                  shellyplusht-80646fc9b46d SUBSCRIBE to shellyplusht-80646fc9b46d/command/sys tcp{client}: 0x55a8931288
                  Packet Id: 0x0003
                  SUBACK	ack
                  shellyplusht-80646fc9b46d SUBSCRIBE to shellyplusht-80646fc9b46d/command tcp{client}: 0x55a8931288
                  Packet Id: 0x0004
                  SUBACK	ack
                  shellyplusht-80646fc9b46d SUBSCRIBE to shellies/command tcp{client}: 0x559c9277e8
                  PUBLISH	 	tcp{client}: 0x559c9277e8
                  PUBACK	ack
                  Topic: shellyplusht-80646fc9b46d/online ApplicationMessage: true
                  PUBACK	ack
                  Topic: shellyplusht-80646fc9b46d/events/rpc ApplicationMessage: {"src":"shellyplusht-80646fc9b46d","dst":"shellyplusht-80646fc9b46d/events","method":"NotifyFullStatus","params":{"ts":1.45,"ble":{},"cloud":{"connected":false},"devicepower:0":{"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}},"ht_ui":{},"humidity:0":{"id": 0,"rh":54.7},"mqtt":{"connected":true},"sys":{"mac":"80646fc9b46d","restart_required":false,"time":null,"unixtime":null,"uptime":1,"ram_size":246864,"ram_free":167876,"fs_size":458752,"fs_free":176128,"cfg_rev":11,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600},"temperature:0":{"id": 0,"tC":23.2, "tF":73.7},"wifi":{"sta_ip":"<ip_address>","status":"got ip","ssid":"<ssid>","rssi":-66},"ws":{"connected":false}}}
                  PUBACK	ack
                  Topic: shellyplusht-80646fc9b46d/events/rpc ApplicationMessage: {"src":"shellyplusht-80646fc9b46d","dst":"shellyplusht-80646fc9b46d/events","method":"NotifyStatus","params":{"ts":1.45,"mqtt":{"connected":true}}}
                  PUBACK	ack
                  Topic: shellyplusht-80646fc9b46d/events/rpc ApplicationMessage: {"src":"shellyplusht-80646fc9b46d","dst":"shellyplusht-80646fc9b46d/events","method":"NotifyEvent","params":{"ts":1703301404.25,"events":[{"component":"sys", "event":"sleep", "ts":1703301404.25}]}}
                  MQTT:1883 connection closed  tcp{client}: 0x559c9277e8
                  openLuup.mqtt:: RECEIVE ERROR: (Fixed Header byte) closed tcp{client}: 0x559c9277e8
                  Every 5 minutes the Shelly come on line, sends some status and finally sends the sleep mode event then goes into sleep mode. This would close the connection to the openLuup server. So I'm wondering if openLuup is checking for a "PUBACK" at this time and that's an issue? Might also be a QoS level mix up as well; eg "PUBACK" is not needed. Or the Shelly is going to sleep too early.
                  I'm still trying to understand how this all works and in what direction information is being sent eg is "PUBACK" been sent or received by openLuup. A few <-- arrows might be good --> eg incoming and outgoing.
                  And why does my log code line, log the same information twice in a row. I see it does this also for my Zigbee MQTT devices, which work fine. If openLupp is publishing one of its own internal variables the log only shows it once.
                    Good diagnostics! I will dig in (although it IS the holidays, so time for this is somewhat limited...)
                      What - you aren't around on Xmas day?
                        I obviously need to get one of these myself… but the UK store is currently out of stock.
                          Yes - they are a nice unit. The large display is easy to read. This guy does a good rant on the Shelley MQTT info.
                          I also got one of these zigbee devices: Aqara temperature, humidity, TVOC air quality monitor. The latter has smaller display than the Shelley. Both devices give very similar temperature readings but a substantial 10% difference in the humidity readings. I can't be certain but it looks like the zigbee device is less likely to be showing the correct figure. You can add offsets, etc but not too sure how you would actually go about calibrating it.
                            Yes, I’ve found significant humidity variation between different devices in the past. It’s a much harder measurement to make accurately than temperature.
                              I see that Shelly have now come out with Gen 3 devices, which may explain why there are none of the old ones available now.
                                Well I compared another Xiaomi humidity temperature device with the Shelley device and got a good match in the readings. It looks like the Shelly device and this particular Xiaomi device are literally out by the old software error factor of one ie a 10% difference. There is an OTA software update available but I can't get it to happen.
                                Anyway I got one of the hairs off my head and proceeded to calibrate it against the Shelly and the Xiaomi devices. I searched & searched and could only find a hair about 2 mm long. Complete waste of time. Maybe alopecia has set in?
                                Great to see the Gen3 device ( they've shrunk the kids once again) - looks like you have your work cut out for you re: openLuup. About a year from now; we'll get to see them on sale here where I live.
                                  Shelly Plus H&T now back in stock, so I've ordered one.
                                    #97
                                    Good news and I still haven't forgotten about Zwave via MQTT! Starting point, at a minimum, would be:
                                    • light on/off (although most are dimmers these days, but not all)
                                    • blinds up/down - pretty much the same as the above
                                    • general purpose outlets (GPO) - pretty much the same as the above
                                    • minimotes
                                    Some items may be returning power consumption info as well.
                                    The above would cover the majority of stuff?
                                      @a-lurker
                                      Good news, in a way! I have received my Plus H&T, and I get exactly the same error.
                                      I will work on it…!
                                        @a-lurker
                                        This error is looking very weird: the server says the socket is ready to read, but the read fails. I've added an extra check for the status just before the read, and it looks like this is, indeed, the case.
                                        Apart from blaming a flakey LuaSocket module, I can't, as yet, think how this happens. So still working on it...
                                          @a-lurker
                                          Latest development version (v24.2.8) now supports the Shelly Plus H&T. It should detect a new device when it is reset or generates a normal update. There is a parent Shelly device and temperature and humidity child devices.
                                          The unexplained fixed header byte error remains, but it has no impact since the connection with the device is closed anyway, and the connection remade when the device wakes up again.
                                          I have rounded the humidity reading to the nearest integer, since there's no way that it's that accurate.
                                            141.3k
