  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 126.9k Views 6 Watching
    Good diagnostics! I will dig in (although it IS the holidays, so time for this is somewhat limited...)
      What - you aren't around on Xmas day?
        I obviously need to get one of these myself… but the UK store is currently out of stock.
          Yes - they are a nice unit. The large display is easy to read. This guy does a good rant on the Shelley MQTT info.
          I also got one of these zigbee devices: Aqara temperature, humidity, TVOC air quality monitor. The latter has smaller display than the Shelley. Both devices give very similar temperature readings but a substantial 10% difference in the humidity readings. I can't be certain but it looks like the zigbee device is less likely to be showing the correct figure. You can add offsets, etc but not too sure how you would actually go about calibrating it.
            Yes, I’ve found significant humidity variation between different devices in the past. It’s a much harder measurement to make accurately than temperature.
              I see that Shelly have now come out with Gen 3 devices, which may explain why there are none of the old ones available now.
                Well I compared another Xiaomi humidity temperature device with the Shelley device and got a good match in the readings. It looks like the Shelly device and this particular Xiaomi device are literally out by the old software error factor of one ie a 10% difference. There is an OTA software update available but I can't get it to happen.
                Anyway I got one of the hairs off my head and proceeded to calibrate it against the Shelly and the Xiaomi devices. I searched & searched and could only find a hair about 2 mm long. Complete waste of time. Maybe alopecia has set in?
                Great to see the Gen3 device ( they've shrunk the kids once again) - looks like you have your work cut out for you re: openLuup. About a year from now; we'll get to see them on sale here where I live.
                  Shelly Plus H&T now back in stock, so I've ordered one.
                    #97
                    Good news and I still haven't forgotten about Zwave via MQTT! Starting point, at a minimum, would be:
                    • light on/off (although most are dimmers these days, but not all)
                    • blinds up/down - pretty much the same as the above
                    • general purpose outlets (GPO) - pretty much the same as the above
                    • minimotes
                    Some items may be returning power consumption info as well.
                    The above would cover the majority of stuff?
                      @a-lurker
                      Good news, in a way! I have received my Plus H&T, and I get exactly the same error.
                      I will work on it…!
                        @a-lurker
                        This error is looking very weird: the server says the socket is ready to read, but the read fails. I've added an extra check for the status just before the read, and it looks like this is, indeed, the case.
                        Apart from blaming a flakey LuaSocket module, I can't, as yet, think how this happens. So still working on it...
                          @a-lurker
                          Latest development version (v24.2.8) now supports the Shelly Plus H&T. It should detect a new device when it is reset or generates a normal update. There is a parent Shelly device and temperature and humidity child devices.
                          The unexplained fixed header byte error remains, but it has no impact since the connection with the device is closed anyway, and the connection remade when the device wakes up again.
                          I have rounded the humidity reading to the nearest integer, since there's no way that it's that accurate.
                            @a-lurker
                            @akbooer
                            Tried out the latest software:
                            • line 583: The newinfo.ip is null, so the software does a return and no device is created. I think, if a static address is set up in the Shelley, this may return an IP address. But I'm using DCHP with statics set there.
                            • I bypassed the return code by setting the ip address to "1.1.1.1". At line 588 sys.device.name is null. So I gave it a fake name "Shelley_Name" regardless later on you seem to have populated with shellyplusht-<the_id>.
                            • After setting up the bypass: the parent device was created with the two children. The handler is hit every five minutes and only stops running once it realises the device already exists in function init_device() at line 463. Can this exit be determined earlier in the handler (just my OCD on wasted CPU cycles)?
                            • The children aren't populated. You have to subscribe to "shellyplusht-<the_id>/events/rpc". Refer to this guys vid. And then look specifically for the event that contains this "method": "NotifyFullStatus". It contains all the good info.
                            • You can then get the temp & humidity and also the ip address. The battery info has a flag indicating if running of USB (ie 5 Volts) or not. The device id is the Mac address. When you read the mac address, it has had all the colons or dashes removed. Can they be put back in when the MAC address is stored in the device attributes?
                            Here is the NotifyFullStatus event json and after that I have attached the json used when the device is being created.
                            So making good progress.
                                "src": "shellyplusht-<the_id>",
                                "dst": "shellyplusht-<the_id>/events",
                                "method": "NotifyFullStatus",
                                "params": {
                                    "ts": 9.37,
                                    "ble": {},
                                    "cloud": {
                                        "connected": false
                                    "devicepower:0": {
                                        "id": 0,
                                        "battery": {
                                            "V": 0.43,
                                            "percent": 0
                                        "external": {
                                            "present": true
                                    "ht_ui": {},
                                    "humidity:0": {
                                        "id": 0,
                                        "rh": 54.2
                                    "mqtt": {
                                        "connected": true
                                    "sys": {
                                        "mac": "<the_id>",
                                        "restart_required": false,
                                        "time": null,
                                        "unixtime": null,
                                        "uptime": 9,
                                        "ram_size": 246872,
                                        "ram_free": 167920,
                                        "fs_size": 458752,
                                        "fs_free": 176128,
                                        "cfg_rev": 11,
                                        "kvs_rev": 0,
                                        "webhook_rev": 0,
                                        "available_updates": {},
                                        "wakeup_reason": {
                                            "boot": "deepsleep_wake",
                                            "cause": "status_update"
                                        "wakeup_period": 600
                                    "temperature:0": {
                                        "id": 0,
                                        "tC": 24.8,
                                        "tF": 76.7
                                    "wifi": {
                                        "sta_ip": "the_IP",
                                        "status": "got ip",
                                        "ssid": "the_SID",
                                        "rssi": -75
                                    "ws": {
                                        "connected": false
                            Device creation - topic "shelly-gen2-cmd/rpc":
                                "id": "table: 0x55a8a880e0",
                                "dst": "shelly-gen2-cmd",
                                "result": {
                                    "ble": {
                                        "enable": false,
                                        "rpc": {
                                            "enable": true
                                    "cloud": {
                                        "enable": false,
                                        "server": "iot.shelly.cloud:6012/jrpc"
                                    "devicepower:0": {},
                                    "ht_ui": {
                                        "temperature_unit": "C"
                                    "humidity:0": {
                                        "id": 0,
                                        "name": null,
                                        "report_thr": 5,
                                        "offset": 0
                                    "mqtt": {
                                        "enable": true,
                                        "server": "server_ip:1883",
                                        "client_id": "shellyplusht-<the_id>",
                                        "user": null,
                                        "topic_prefix": "shellyplusht-<the_id>",
                                        "rpc_ntf": true,
                                        "status_ntf": false,
                                        "use_client_cert": false,
                                        "enable_rpc": true,
                                        "enable_control": true
                                    "sys": {
                                        "device": {
                                            "name": null,
                                            "mac": "<the_id>",
                                            "fw_id": "20231106-160224/1.0.8-gdba0ee3",
                                            "discoverable": true
                                        "location": {
                                            "tz": "some-place",
                                            "lat": "lat",
                                            "lon": "lon"
                                        "debug": {
                                            "level": 2,
                                            "file_level": null,
                                            "mqtt": {
                                                "enable": false
                                            "websocket": {
                                                "enable": false
                                            "udp": {
                                                "addr": null
                                        "ui_data": {},
                                        "rpc_udp": {
                                            "dst_addr": null,
                                            "listen_port": null
                                        "sntp": {
                                            "server": "time.google.com"
                                        "cfg_rev": 11
                                    "temperature:0": {
                                        "id": 0,
                                        "name": null,
                                        "report_thr_C": 0.5,
                                        "offset_C": 0
                                    "wifi": {
                                        "ap": {
                                            "ssid": "ShellyPlusHT-<the_id>",
                                            "is_open": true,
                                            "enable": false
                                        "sta": {
                                            "ssid": "some_SID",
                                            "is_open": false,
                                            "enable": true,
                                            "ipv4mode": "dhcp",
                                            "ip": null,
                                            "netmask": null,
                                            "gw": null,
                                            "nameserver": null
                                        "sta1": {
                                            "ssid": null,
                                            "is_open": true,
                                            "enable": false,
                                            "ipv4mode": "dhcp",
                                            "ip": null,
                                            "netmask": null,
                                            "gw": null,
                                            "nameserver": null
                                        "roam": {
                                            "rssi_thr": -80,
                                            "interval": 60
                                    "ws": {
                                        "enable": false,
                                        "server": null,
                                        "ssl_ca": "ca.pem"
                              None of this is needed for my config, but indeed I do have a static IP defined.
                                #103
                                Edit : that didn't sound to good on 2nd read, so: yes I'm unsure why you would need an ip address, so not so concerning.
                                  #104
                                  IP was used for HTTP request to get device name in an early version, and that piece of code remained.
                                  The whole point of MQTT is that it doesn’t need one, of course.
                                  Edit: It is, however, used to the browser window in the openLuup device page of the parent device, so that you can interact directly with the it for firmware updates, etc..
                                    #105
                                    @a-lurker
                                    Try development latest version (v24.2.11).
                                    Valid child readings should happen on next device update (ie. time interval or temperature/humidity significant change)
                                    I've tested this with a DCHP configuration and it works OK.
                                      #106
                                      Now working. Thank you. Will get back to you with a full report.
                                      • A a-lurker
                                        #107
                                        Working fine except for a couple of small points. In the earlier H&T device the battery topic is:
                                        shellies/shellyht-<deviceid>/sensor/battery
                                        In the newer device it's:
                                        shellyplusht-<Device_ID>/status/devicepower:0
                                        and returns:
                                          "id": 0,
                                          "battery": {
                                            "V": 0.43,
                                            "percent": 0
                                          "external": {
                                            "present": true
                                        It would be good if "external" is true ie USB powered; that battery percent is set to 100% and the Voltage (variable V) to 5 Volts. ie USB Voltage. Any battery values are incorrect, as you are meant to remove the batteries, when running off USB power.
                                        Interesting the battery percent in the UI dashboard for the parent device shows the value of "CurrentLevel" ie the actual humidity percentage measured. Not sure how that got in there! Looks like if the battery level is missing, something else gets plugged into there.
                                        The service urn:micasaverde-com:serviedId:HumiditySensor1 service saves the humidity as "CurrentLevel". In the Historian rules this gets picked up as Current as in Amperes.
                                        CurrentHumidityLevel would have been nice but that's MIOS.
                                          #108
                                          Please try development latest version (v24.2.14) for power V and %.
                                          Don't understand your comments on UI dashboard and Historian rules.
                                            163.6k
