  4. Grouped devices
3 Posts 2 Posters 135 Views 2 Watching
    wrote last edited by
      AFAIK groups should be enabled in alexa app and you'll find them as device in home assistant. So you can set announcements and volume and such on a single group, instead of separate devices, with the risk of exhausting the api limits.
        @therealdb it does and the 2026.11.0 release of Ha fixes the AMZ changes they made that were after affecting login.
        Problem: AMZ only allows a device to appear in a single group.
        I worked on this last night and found I could write a script to create the groupings I wanted. In testing now.
          157.4k
