  4. MFA
28 Posts 4 Posters 1.0k Views 4 Watching
    wrote last edited by
    @toggledbits ,
    I didn't want to pile on to the Login protection thread, but it reminded me about the MFA authentication. I tried to set it up once, and I could never get it to work. I got the pop up to login, and it returns an Access Denied page.
    I'm starting with a clean, newly opened browser window, and my credentials are correct.
    I'm using these directions, and using my URL and my username in place of UUUU
    https://notmyurl.com/api/v1/mfa.add/notmyuserid?askauth=1
    I tried it via my private IP as well, and I'm still receiving Access Denied. I'm unsure what the log file is that would provide the why.
    I'm running latest-26298-fbb75fb8
    • T tamorgen
      @toggledbits ,
      @tamorgen My experience is the same and I’m sure I’m missing something obvious. I’m at work and haven’t had time to dig in as yet.
        @tamorgen I beat it. With a lot of AI help, admittedly. But it's up and running. I'm using Portainer inside Proxmox so it had... challenges... with what IP it was "seeing".
        I'll see if tomorrow I can pull together the full steps.
          wrote last edited by tamorgen
          @gwp1 said in MFA:
          I have the same setup, and I have my own Cloudflare domain, with a local LXC running Cloudflared for the tunnels, so yeah, I'm sure the authenticator is having issues with the IPs and the virtual networking. Please let me know what you did to get past it.
          • T tamorgen
            @gwp1 said in MFA:
            @tamorgen I asked Lumo to pull together everything that WORKED to get to the end goal (we had a lot of trial and error at times).
            Good luck. YMMV.
            Here's the working procedure — tested end-to-end with your Reactor instance.
            Setting Up MFA for Multi-System Reactor (MSR)
            Problem: Requesting http://<reactor_host>:8111/api/v1/mfa.add/<username>?askauth=1 from a browser or host shell returns ACCESS DENIED, even after entering valid admin credentials.
            Root Cause: When access control is enabled (config/users.yaml exists), MSR restricts API access by default to localhost only. Traffic reaching a Dockerised Reactor from the host appears to come from Docker's bridge gateway (172.17.0.1), not 127.0.0.1, so it fails the default loopback rule and falls through to the catch-all deny.
            Working Setup Procedure
            Prerequisites
            • MSR installed and running in Docker
            • Target user exists in config/users.yaml and is a member of the admin group
            • You have shell access to the host running the container
            Step 1: Enter the Reactor Container
            docker exec -it <container_name> sh
            Replace <container_name> with your container name (e.g., reactor). Find it with:
            docker ps | grep reactor
            Step 2: Request the MFA QR Code From Inside the Container
            Run the following command inside the container:
            curl -s -o /tmp/qrcode.png -u <target_username> \
              http://localhost:8111/api/v1/mfa.add/<target_username>
            When prompted, enter the target user's password.
            Notes:
            • -u <target_username> makes curl prompt for the password interactively (safer than typing it in the command line).
            • The request originates from 127.0.0.1 inside the container, which matches the default ACL allowing loopback.
            • The ?askauth=1 parameter is not needed here — it's only for the browser-based flow.
            Step 3: Verify the Image Was Generated
            ls -la /tmp/qrcode.png
            head -c 8 /tmp/qrcode.png | od -An -tx1
            You should see 89 50 4e 47 0d 0a 1a 0a — the PNG magic bytes. If you see 41 63 63 65 73 73 20 64 ("Access denied"), the file is stale from an earlier failed attempt. Redo step 2.
            Step 4: Copy the QR Code to Your Desktop
            exit
            docker cp <container_name>:/tmp/qrcode.png ~/Desktop/qr-mfa.png
            Or from a separate machine:
            scp root@<host_ip>:/tmp/qrcode.png .
            Step 5: Scan the QR Code
            Open qr-mfa.png in any image viewer and scan it with your authenticator app (Google Authenticator, Authy, Aegis, 1Password, Bitwarden, Ente, etc.).
            Alternative: Manual Entry
            If your viewer can't display the image, install zbar-tools:
            apt update && apt install -y --no-install-recommends zbar-tools
            zbarimg --quiet ~/Desktop/qr-mfa.png
            This outputs an otpauth://totp/... URI. Use the secret= value in your authenticator app's "Manual Entry" or "Setup Key" option.
            Step 6: Test the Login
            Log into the Reactor UI as the target user. You should be prompted for a six-digit code. Enter the code from your authenticator app.
            Step 7: Clean Up the Seed File
            Both the host and container copies contain the TOTP secret in plaintext. Delete them after enrollment:
            rm -f ~/Desktop/qr-mfa.png
            docker exec <container_name> rm -f /tmp/qrcode.png
            Anyone who photographs this image can generate valid codes indefinitely.
            Recovery (If You Lose the Authenticator)
            The same procedure applies for clearing MFA. From inside the container:
            curl -s -o /dev/null -u <admin_user> -w 'HTTP %{http_code}\n' \
              http://localhost:8111/api/v1/mfa.clear/<username_to_clear>
            You'll need admin credentials. The endpoint is subject to the same default ACL rules, so it must be called from inside the container.
            What Not to Do (Common Pitfalls)
            ❌ Don't ✅ Do
            Run curl from the host shell against localhost or the LAN IP Run the command from inside the container via docker exec
            Use ?askauth=1 with curl Only use it for the browser-based flow
            Edit users.yaml to add ACL rules Not required for the initial setup; stick to stock defaults
            Paste my suggested YAML without validation Use python3 -c "import yaml; yaml.safe_load(open('users.yaml'))" to verify first
            Re-run mfa.add after enrolling It may rotate the secret and invalidate your existing setup
            Leave the QR code PNG anywhere accessible Delete it immediately after enrollment
            Troubleshooting
            Symptom Likely Cause Fix
            HTTP 403 Forbidden Request from host/network interface Use docker exec to run curl inside container
            HTTP 401 Unauthorized Wrong password Verify credentials, use -u <user> for interactive prompt
            Empty qrcode.png or "Access denied" text Stale file from failed attempt Delete old copy and re-run step 2
            File opens as text instead of image curl wrote error body over PNG Check magic bytes with od before scanning
            Optional: Browser-Based MFA Setup (Requires ACL Change)
            If you prefer the browser method from a LAN machine (http://<reactor_host>:8111/api/v1/mfa.add/<user>?askauth=1), you need to add an ACL rule in config/users.yaml:
            api_acls:
              - url: "/api/v1/mfa.add"
                group: admin
                allow: true
              - url: "/api/v1/mfa.clear"
                group: admin
                allow: true
            Place these at the top level of the file (same indent as users: and groups:). Then restart:
            docker restart <container_name>
            Validate the YAML before applying:
            python3 -c "import yaml; yaml.safe_load(open('/var/reactor/config/users.yaml')); print('Valid')"
            Note: This is optional. The docker exec method works on stock defaults and requires no configuration changes.
            Documented based on real-world testing with Reactor in Docker, October 2026.
              Good luck. YMMV.
              Prerequisites
              Notes:
              exit
              ❌ Don't ✅ Do
              Troubleshooting
              api_acls:
                  group: admin
                  allow: true
                  group: admin
                  allow: true
              When working you'll get this prompt for the code:
                wrote last edited by toggledbits
                You don't need to run the commands from inside the container. You can add an ACL allowing the IP address of the host system or your LAN subnet (as source_ip). But in any case, once you add the user/group ACL entry to permit the endpoint as suggested above, as long as that entry also doesn't restrict IP (i.e. doesn't contain source_ip), any IP that can log in as that user (or a user in that group, if group), will be allowed from anywhere (i.e. authorized queries from outside the container will work).
                G T 2 Replies Last reply
                  @toggledbits I honestly did not recall implementing any ACL or Access Control settings outside of adding a user.
                  That to say, this morning when I went in to start that work, I found entries in place. No recollection of adding them - but it made all of the above suddenly make much more sense.
                  I can remove the above post if it's way out.
                    @toggledbits,
                    This is what I see in my reactor.log file:
                    [latest-26298]2026-10-28T16:27:53.505Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                    [latest-26298]2026-10-28T16:27:53.505Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                    [latest-26298]2026-10-28T16:27:53.517Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                    [latest-26298]2026-10-28T16:27:53.517Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.123 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                    [latest-26298]2026-10-28T16:27:53.517Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                    I'm assuming the "allow": false is the deny.
                    The allowed list in my reactor.yaml covers that IP:
                    allowed_ips:
                    #  - "127.0.0.1"
                    #  - "192.168.0."  # or whatever your local trusted subnet
                      - "192.168.1.0/24"
                      The allowed list is separate from ACLs. It's just a first check. The ACLs are next. The former doesn't imply the latter, the latter having much more granularity/detail.
                        @toggledbits said in MFA:
                        Okay, I added my /24 to the allowed api in users.yaml
                        groups:
                          api_allowed:
                            users:
                              - admin
                              - tmorgenthaler
                        api_acls:
                          - url: "/api/"
                            group: api_allowed
                            source_IP: 192.168.1.1/24
                            allow: true
                        but I'm still not getting anywhere:
                        [latest-26298]2026-10-28T18:22:12.362Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-28T18:22:12.379Z <wsapi:5:wsapi.js:152> (event handler) sending update for 20 entities
                        [latest-26298]2026-10-28T18:22:13.139Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-28T18:22:13.164Z <wsapi:5:wsapi.js:152> (event handler) sending update for 1 entities
                        root@docker:/home/tmorgenthaler/reactor/logs# cat httpapi.log | grep auth
                        [latest-26298]2026-10-28T18:18:50.085Z <httpapi:CRIT> httpapi#1 ACLs Array(7) [{ "url": "/api/v1/authorize", "allow": true, "index": 0 }, { "url": "/api/v1/deauthorize", "allow": true, "index": 1 }, { "url": "/api/v1/systime", "allow": true, "index": 2 }, { "url": "/api/v1/alive", "allow": true, "index": 3 }, { "url": "/api/v1/lang", "allow": true, "index": 4 }, { "url": "/api", "source_ip": "127/8", "allow": true, "index": 5 }, { "url": "/", "allow": false, "index": 6 }]
                        [latest-26298]2026-10-28T18:18:50.086Z <httpapi:CRIT> httpapi#1 ACL index Map(7) {"/api/v1/authorize": Array(1) [0], "/api/v1/deauthorize": Array(1) [1], "/api/v1/systime": Array(1) [2], "/api/v1/alive": Array(1) [3], "/api/v1/lang": Array(1) [4], "/api": Array(1) [5], "/": Array(1) [6] }
                        [latest-26298]2026-10-28T18:18:52.748Z <httpapi:5:httpapi.js:820> httpapi#1 purging expired authorizations; default delay 7200000
                        [latest-26298]2026-10-28T18:18:52.748Z <httpapi:5:httpapi.js:848> httpapi#1 setting timer for next authorization purge in 7200000ms
                        [latest-26298]2026-10-28T18:19:12.395Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:19:12.396Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                        [latest-26298]2026-10-28T18:19:12.407Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                        [latest-26298]2026-10-28T18:19:12.408Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                        [latest-26298]2026-10-28T18:19:34.975Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:19:34.975Z <httpapi:5:httpapi.js:1221> httpapi#1 askauth!
                        [latest-26298]2026-10-28T18:19:47.485Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:19:47.485Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                        [latest-26298]2026-10-28T18:19:47.495Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                        [latest-26298]2026-10-28T18:19:47.495Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                        [latest-26298]2026-10-28T18:19:54.970Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:19:54.970Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                        [latest-26298]2026-10-28T18:19:54.979Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                        [latest-26298]2026-10-28T18:19:54.979Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                        [latest-26298]2026-10-28T18:20:01.600Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:20:01.600Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                        [latest-26298]2026-10-28T18:20:01.607Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                        [latest-26298]2026-10-28T18:20:01.607Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                        [latest-26298]2026-10-28T18:20:10.938Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:20:10.938Z <httpapi:5:httpapi.js:1221> httpapi#1 askauth!
                        [latest-26298]2026-10-28T18:20:54.025Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-28T18:20:54.025Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                        [latest-26298]2026-10-28T18:20:54.040Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                        [latest-26298]2026-10-28T18:20:54.040Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                        root@docker:/home/tmorgenthaler/reactor/logs# cat httpapi.log | grep 18:20:54
                        [latest-26298]2026-10-28T18:20:54.040Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.123 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                        [latest-26298]2026-10-28T18:20:54.042Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-28T18:20:54.067Z <wsapi:5:wsapi.js:152> (event handler) sending update for 2 entities
                        [latest-26298]2026-10-28T18:20:54.749Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-28T18:20:54.775Z <wsapi:5:wsapi.js:152> (event handler) sending update for 1 entities
                        [latest-26298]2026-10-28T18:20:54.836Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-28T18:20:54.861Z <wsapi:5:wsapi.js:152> (event handler) sending update for 2 entities
                          Are you requesting from a browser or curl?
                          Edit: also source_IP must be source_ip (all lower case).
                            This is from a browser
                              See edit above
                                DOH! I'll fix it and try again.
                                  Still no joy. I'm still getting Access Denied after entering my username and password
                                  [latest-26298]2026-10-30T11:39:27.726Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                  [latest-26298]2026-10-30T11:39:27.735Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                                  [latest-26298]2026-10-30T11:39:27.982Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                  [latest-26298]2026-10-30T11:39:27.982Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                  [latest-26298]2026-10-30T11:39:27.990Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                  [latest-26298]2026-10-30T11:39:27.991Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.127 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                  [latest-26298]2026-10-30T11:39:27.991Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.127 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                                  [latest-26298]2026-10-30T11:39:28.264Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                  [latest-26298]2026-10-30T11:39:28.265Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                  groups:
                                    api_allowed:
                                      users:
                                        - admin
                                        - tmorgenthaler
                                  api_acls:
                                    - url: "/api/"
                                      group: api_allowed
                                      source_ip: 192.168.1.1/24
                                      allow: true
                                  • T tamorgen
                                    groups:
                                      api_allowed:
                                        users:
                                          - admin
                                          - tmorgenthaler
                                    api_acls:
                                      - url: "/api/"
                                        group: api_allowed
                                        allow: true
                                    @tamorgen said in MFA:
                                    • url: "/api/"
                                    Remove the trailing slash.
                                      • url: "/api/"
                                      • url: "/api/"
                                      Just getting back to this.
                                      I removed the trailing slash, and I'm still getting the same result. I get prompted for my user name and password (same as before), but as soon as I put it in, I get Access Denied. I'm using Chrome incognito mode.
                                      [latest-26298]2026-11-02T16:22:39.572Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      [latest-26298]2026-11-02T16:22:39.596Z <wsapi:5:wsapi.js:152> (event handler) sending update for 1 entities
                                      [latest-26298]2026-11-02T16:22:39.983Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                      [latest-26298]2026-11-02T16:22:39.984Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                      [latest-26298]2026-11-02T16:22:39.995Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                      [latest-26298]2026-11-02T16:22:39.995Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.123 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                      [latest-26298]2026-11-02T16:22:39.995Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                                      [latest-26298]2026-11-02T16:22:41.549Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      [latest-26298]2026-11-02T16:22:41.550Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      groups:
                                        api_allowed:
                                          users:
                                            - admin
                                            - tmorgenthaler
                                      api_acls:
                                        - url: "/api"
                                          group: api_allowed
                                          allow: true
                                        Turn on ACL debug. The log will then show why your ACL isn't matched.
                                        Also look in your startup messages for any errors (specifically, search for "ignoring config").
                                          I changed the debug to true, this is what I'm seeing in the logs now:
                                          [latest-26298]2026-11-03T16:31:21.448Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:31:21.449Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:31:21.472Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                                          [latest-26298]2026-11-03T16:31:21.820Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "69.255.234.254" via ::ffff:192.168.1.73 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                          [latest-26298]2026-11-03T16:31:21.820Z <httpapi:5:httpapi.js:1135> httpapi#1 pass_all_proxy is set, passing proxy req from "69.255.234.254" via ::ffff:192.168.1.73
                                          [latest-26298]2026-11-03T16:31:21.820Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                          [latest-26298]2026-11-03T16:31:21.829Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                          [latest-26298]2026-11-03T16:31:21.830Z <httpapi:INFO> httpapi#1 API request from "69.255.234.254" (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                          [latest-26298]2026-11-03T16:31:21.830Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from "69.255.234.254" user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                                          [latest-26298]2026-11-03T16:31:21.834Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:31:21.835Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:31:21.836Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          I tried again using my local IP, and not using the Cloudflared tunnel
                                          [latest-26298]2026-11-03T16:34:36.924Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:34:36.949Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                                          [latest-26298]2026-11-03T16:34:36.987Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                          [latest-26298]2026-11-03T16:34:36.987Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                          [latest-26298]2026-11-03T16:34:36.996Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                          [latest-26298]2026-11-03T16:34:36.996Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.127 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                          [latest-26298]2026-11-03T16:34:36.996Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.127 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                                          [latest-26298]2026-11-03T16:34:36.997Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:34:36.998Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:34:36.999Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:34:37.023Z <wsapi:5:wsapi.js:152> (event handler) sending update for 2 entities
                                          [latest-26298]2026-11-03T16:34:37.099Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /favicon.ico lang en-US,en;q=0.9 (TLSv1.3)
                                          [latest-26298]2026-11-03T16:34:37.237Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:34:37.238Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                          [latest-26298]2026-11-03T16:34:37.239Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                            157.4k
