  4. MFA
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
28 Posts 4 Posters 1.4k Views 4 Watching
    @tamorgen I asked Lumo to pull together everything that WORKED to get to the end goal (we had a lot of trial and error at times).
    Good luck. YMMV.
    Here's the working procedure — tested end-to-end with your Reactor instance.
    Setting Up MFA for Multi-System Reactor (MSR)
    Problem: Requesting http://<reactor_host>:8111/api/v1/mfa.add/<username>?askauth=1 from a browser or host shell returns ACCESS DENIED, even after entering valid admin credentials.
    Root Cause: When access control is enabled (config/users.yaml exists), MSR restricts API access by default to localhost only. Traffic reaching a Dockerised Reactor from the host appears to come from Docker's bridge gateway (172.17.0.1), not 127.0.0.1, so it fails the default loopback rule and falls through to the catch-all deny.
    Working Setup Procedure
    Prerequisites
    • MSR installed and running in Docker
    • Target user exists in config/users.yaml and is a member of the admin group
    • You have shell access to the host running the container
    Step 1: Enter the Reactor Container
    docker exec -it <container_name> sh
    Replace <container_name> with your container name (e.g., reactor). Find it with:
    docker ps | grep reactor
    Step 2: Request the MFA QR Code From Inside the Container
    Run the following command inside the container:
    curl -s -o /tmp/qrcode.png -u <target_username> \
      http://localhost:8111/api/v1/mfa.add/<target_username>
    When prompted, enter the target user's password.
    Notes:
    • -u <target_username> makes curl prompt for the password interactively (safer than typing it in the command line).
    • The request originates from 127.0.0.1 inside the container, which matches the default ACL allowing loopback.
    • The ?askauth=1 parameter is not needed here — it's only for the browser-based flow.
    Step 3: Verify the Image Was Generated
    ls -la /tmp/qrcode.png
    head -c 8 /tmp/qrcode.png | od -An -tx1
    You should see 89 50 4e 47 0d 0a 1a 0a — the PNG magic bytes. If you see 41 63 63 65 73 73 20 64 ("Access denied"), the file is stale from an earlier failed attempt. Redo step 2.
    Step 4: Copy the QR Code to Your Desktop
    exit
    docker cp <container_name>:/tmp/qrcode.png ~/Desktop/qr-mfa.png
    Or from a separate machine:
    scp root@<host_ip>:/tmp/qrcode.png .
    Step 5: Scan the QR Code
    Open qr-mfa.png in any image viewer and scan it with your authenticator app (Google Authenticator, Authy, Aegis, 1Password, Bitwarden, Ente, etc.).
    Alternative: Manual Entry
    If your viewer can't display the image, install zbar-tools:
    apt update && apt install -y --no-install-recommends zbar-tools
    zbarimg --quiet ~/Desktop/qr-mfa.png
    This outputs an otpauth://totp/... URI. Use the secret= value in your authenticator app's "Manual Entry" or "Setup Key" option.
    Step 6: Test the Login
    Log into the Reactor UI as the target user. You should be prompted for a six-digit code. Enter the code from your authenticator app.
    Step 7: Clean Up the Seed File
    Both the host and container copies contain the TOTP secret in plaintext. Delete them after enrollment:
    rm -f ~/Desktop/qr-mfa.png
    docker exec <container_name> rm -f /tmp/qrcode.png
    Anyone who photographs this image can generate valid codes indefinitely.
    Recovery (If You Lose the Authenticator)
    The same procedure applies for clearing MFA. From inside the container:
    curl -s -o /dev/null -u <admin_user> -w 'HTTP %{http_code}\n' \
      http://localhost:8111/api/v1/mfa.clear/<username_to_clear>
    You'll need admin credentials. The endpoint is subject to the same default ACL rules, so it must be called from inside the container.
    What Not to Do (Common Pitfalls)
    ❌ Don't ✅ Do
    Run curl from the host shell against localhost or the LAN IP Run the command from inside the container via docker exec
    Use ?askauth=1 with curl Only use it for the browser-based flow
    Edit users.yaml to add ACL rules Not required for the initial setup; stick to stock defaults
    Paste my suggested YAML without validation Use python3 -c "import yaml; yaml.safe_load(open('users.yaml'))" to verify first
    Re-run mfa.add after enrolling It may rotate the secret and invalidate your existing setup
    Leave the QR code PNG anywhere accessible Delete it immediately after enrollment
    Troubleshooting
    Symptom Likely Cause Fix
    HTTP 403 Forbidden Request from host/network interface Use docker exec to run curl inside container
    HTTP 401 Unauthorized Wrong password Verify credentials, use -u <user> for interactive prompt
    Empty qrcode.png or "Access denied" text Stale file from failed attempt Delete old copy and re-run step 2
    File opens as text instead of image curl wrote error body over PNG Check magic bytes with od before scanning
    Optional: Browser-Based MFA Setup (Requires ACL Change)
    If you prefer the browser method from a LAN machine (http://<reactor_host>:8111/api/v1/mfa.add/<user>?askauth=1), you need to add an ACL rule in config/users.yaml:
    api_acls:
      - url: "/api/v1/mfa.add"
        group: admin
        allow: true
      - url: "/api/v1/mfa.clear"
        group: admin
        allow: true
    Place these at the top level of the file (same indent as users: and groups:). Then restart:
    docker restart <container_name>
    Validate the YAML before applying:
    python3 -c "import yaml; yaml.safe_load(open('/var/reactor/config/users.yaml')); print('Valid')"
    Note: This is optional. The docker exec method works on stock defaults and requires no configuration changes.
    Documented based on real-world testing with Reactor in Docker, October 2026.
    wrote last edited by
    When working you'll get this prompt for the code:
      You don't need to run the commands from inside the container. You can add an ACL allowing the IP address of the host system or your LAN subnet (as source_ip). But in any case, once you add the user/group ACL entry to permit the endpoint as suggested above, as long as that entry also doesn't restrict IP (i.e. doesn't contain source_ip), any IP that can log in as that user (or a user in that group, if group), will be allowed from anywhere (i.e. authorized queries from outside the container will work).
      G T 2 Replies Last reply
        @toggledbits I honestly did not recall implementing any ACL or Access Control settings outside of adding a user.
        That to say, this morning when I went in to start that work, I found entries in place. No recollection of adding them - but it made all of the above suddenly make much more sense.
        I can remove the above post if it's way out.
          @toggledbits,
          This is what I see in my reactor.log file:
          [latest-26298]2026-10-28T16:27:53.505Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
          [latest-26298]2026-10-28T16:27:53.505Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
          [latest-26298]2026-10-28T16:27:53.517Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
          [latest-26298]2026-10-28T16:27:53.517Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.123 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
          [latest-26298]2026-10-28T16:27:53.517Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
          I'm assuming the "allow": false is the deny.
          The allowed list in my reactor.yaml covers that IP:
          allowed_ips:
          #  - "127.0.0.1"
          #  - "192.168.0."  # or whatever your local trusted subnet
            - "192.168.1.0/24"
            The allowed list is separate from ACLs. It's just a first check. The ACLs are next. The former doesn't imply the latter, the latter having much more granularity/detail.
              wrote last edited by tamorgen
              @toggledbits said in MFA:
              Okay, I added my /24 to the allowed api in users.yaml
              groups:
                api_allowed:
                  users:
                    - admin
                    - tmorgenthaler
              api_acls:
                - url: "/api/"
                  group: api_allowed
                  source_IP: 192.168.1.1/24
                  allow: true
              but I'm still not getting anywhere:
              [latest-26298]2026-10-28T18:22:12.362Z <wsapi:5:wsapi.js:169> (event handler): sending data
              [latest-26298]2026-10-28T18:22:12.379Z <wsapi:5:wsapi.js:152> (event handler) sending update for 20 entities
              [latest-26298]2026-10-28T18:22:13.139Z <wsapi:5:wsapi.js:169> (event handler): sending data
              [latest-26298]2026-10-28T18:22:13.164Z <wsapi:5:wsapi.js:152> (event handler) sending update for 1 entities
              root@docker:/home/tmorgenthaler/reactor/logs# cat httpapi.log | grep auth
              [latest-26298]2026-10-28T18:18:50.085Z <httpapi:CRIT> httpapi#1 ACLs Array(7) [{ "url": "/api/v1/authorize", "allow": true, "index": 0 }, { "url": "/api/v1/deauthorize", "allow": true, "index": 1 }, { "url": "/api/v1/systime", "allow": true, "index": 2 }, { "url": "/api/v1/alive", "allow": true, "index": 3 }, { "url": "/api/v1/lang", "allow": true, "index": 4 }, { "url": "/api", "source_ip": "127/8", "allow": true, "index": 5 }, { "url": "/", "allow": false, "index": 6 }]
              [latest-26298]2026-10-28T18:18:50.086Z <httpapi:CRIT> httpapi#1 ACL index Map(7) {"/api/v1/authorize": Array(1) [0], "/api/v1/deauthorize": Array(1) [1], "/api/v1/systime": Array(1) [2], "/api/v1/alive": Array(1) [3], "/api/v1/lang": Array(1) [4], "/api": Array(1) [5], "/": Array(1) [6] }
              [latest-26298]2026-10-28T18:18:52.748Z <httpapi:5:httpapi.js:820> httpapi#1 purging expired authorizations; default delay 7200000
              [latest-26298]2026-10-28T18:18:52.748Z <httpapi:5:httpapi.js:848> httpapi#1 setting timer for next authorization purge in 7200000ms
              [latest-26298]2026-10-28T18:19:12.395Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:19:12.396Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
              [latest-26298]2026-10-28T18:19:12.407Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
              [latest-26298]2026-10-28T18:19:12.408Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
              [latest-26298]2026-10-28T18:19:34.975Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:19:34.975Z <httpapi:5:httpapi.js:1221> httpapi#1 askauth!
              [latest-26298]2026-10-28T18:19:47.485Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:19:47.485Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
              [latest-26298]2026-10-28T18:19:47.495Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
              [latest-26298]2026-10-28T18:19:47.495Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
              [latest-26298]2026-10-28T18:19:54.970Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:19:54.970Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
              [latest-26298]2026-10-28T18:19:54.979Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
              [latest-26298]2026-10-28T18:19:54.979Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
              [latest-26298]2026-10-28T18:20:01.600Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:20:01.600Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
              [latest-26298]2026-10-28T18:20:01.607Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
              [latest-26298]2026-10-28T18:20:01.607Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
              [latest-26298]2026-10-28T18:20:10.938Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:20:10.938Z <httpapi:5:httpapi.js:1221> httpapi#1 askauth!
              [latest-26298]2026-10-28T18:20:54.025Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
              [latest-26298]2026-10-28T18:20:54.025Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
              [latest-26298]2026-10-28T18:20:54.040Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
              [latest-26298]2026-10-28T18:20:54.040Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
              root@docker:/home/tmorgenthaler/reactor/logs# cat httpapi.log | grep 18:20:54
              [latest-26298]2026-10-28T18:20:54.040Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.123 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
              [latest-26298]2026-10-28T18:20:54.042Z <wsapi:5:wsapi.js:169> (event handler): sending data
              [latest-26298]2026-10-28T18:20:54.067Z <wsapi:5:wsapi.js:152> (event handler) sending update for 2 entities
              [latest-26298]2026-10-28T18:20:54.749Z <wsapi:5:wsapi.js:169> (event handler): sending data
              [latest-26298]2026-10-28T18:20:54.775Z <wsapi:5:wsapi.js:152> (event handler) sending update for 1 entities
              [latest-26298]2026-10-28T18:20:54.836Z <wsapi:5:wsapi.js:169> (event handler): sending data
              [latest-26298]2026-10-28T18:20:54.861Z <wsapi:5:wsapi.js:152> (event handler) sending update for 2 entities
                Are you requesting from a browser or curl?
                Edit: also source_IP must be source_ip (all lower case).
                  This is from a browser
                    See edit above
                      DOH! I'll fix it and try again.
                        Still no joy. I'm still getting Access Denied after entering my username and password
                        [latest-26298]2026-10-30T11:39:27.726Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-30T11:39:27.735Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                        [latest-26298]2026-10-30T11:39:27.982Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                        [latest-26298]2026-10-30T11:39:27.982Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                        [latest-26298]2026-10-30T11:39:27.990Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                        [latest-26298]2026-10-30T11:39:27.991Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.127 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                        [latest-26298]2026-10-30T11:39:27.991Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.127 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                        [latest-26298]2026-10-30T11:39:28.264Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        [latest-26298]2026-10-30T11:39:28.265Z <wsapi:5:wsapi.js:169> (event handler): sending data
                        groups:
                          api_allowed:
                            users:
                              - admin
                              - tmorgenthaler
                        api_acls:
                          - url: "/api/"
                            group: api_allowed
                            source_ip: 192.168.1.1/24
                            allow: true
                        • T tamorgen
                          groups:
                            api_allowed:
                              users:
                                - admin
                                - tmorgenthaler
                          api_acls:
                            - url: "/api/"
                              group: api_allowed
                              allow: true
                          @tamorgen said in MFA:
                          • url: "/api/"
                          Remove the trailing slash.
                            • url: "/api/"
                            • url: "/api/"
                            Just getting back to this.
                            I removed the trailing slash, and I'm still getting the same result. I get prompted for my user name and password (same as before), but as soon as I put it in, I get Access Denied. I'm using Chrome incognito mode.
                            [latest-26298]2026-11-02T16:22:39.572Z <wsapi:5:wsapi.js:169> (event handler): sending data
                            [latest-26298]2026-11-02T16:22:39.596Z <wsapi:5:wsapi.js:152> (event handler) sending update for 1 entities
                            [latest-26298]2026-11-02T16:22:39.983Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.123" via ::ffff:192.168.1.123 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                            [latest-26298]2026-11-02T16:22:39.984Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                            [latest-26298]2026-11-02T16:22:39.995Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                            [latest-26298]2026-11-02T16:22:39.995Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.123 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                            [latest-26298]2026-11-02T16:22:39.995Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.123 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                            [latest-26298]2026-11-02T16:22:41.549Z <wsapi:5:wsapi.js:169> (event handler): sending data
                            [latest-26298]2026-11-02T16:22:41.550Z <wsapi:5:wsapi.js:169> (event handler): sending data
                            groups:
                              api_allowed:
                                users:
                                  - admin
                                  - tmorgenthaler
                            api_acls:
                              - url: "/api"
                                group: api_allowed
                                allow: true
                              Turn on ACL debug. The log will then show why your ACL isn't matched.
                              Also look in your startup messages for any errors (specifically, search for "ignoring config").
                                I changed the debug to true, this is what I'm seeing in the logs now:
                                [latest-26298]2026-11-03T16:31:21.448Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:31:21.449Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:31:21.472Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                                [latest-26298]2026-11-03T16:31:21.820Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "69.255.234.254" via ::ffff:192.168.1.73 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                [latest-26298]2026-11-03T16:31:21.820Z <httpapi:5:httpapi.js:1135> httpapi#1 pass_all_proxy is set, passing proxy req from "69.255.234.254" via ::ffff:192.168.1.73
                                [latest-26298]2026-11-03T16:31:21.820Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                [latest-26298]2026-11-03T16:31:21.829Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                [latest-26298]2026-11-03T16:31:21.830Z <httpapi:INFO> httpapi#1 API request from "69.255.234.254" (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                [latest-26298]2026-11-03T16:31:21.830Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from "69.255.234.254" user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                                [latest-26298]2026-11-03T16:31:21.834Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:31:21.835Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:31:21.836Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                I tried again using my local IP, and not using the Cloudflared tunnel
                                [latest-26298]2026-11-03T16:34:36.924Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:34:36.949Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                                [latest-26298]2026-11-03T16:34:36.987Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                [latest-26298]2026-11-03T16:34:36.987Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                [latest-26298]2026-11-03T16:34:36.996Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                [latest-26298]2026-11-03T16:34:36.996Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.127 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                [latest-26298]2026-11-03T16:34:36.996Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.127 user tmorgenthaler auth basic matches / ACL (#6): { "url": "/", "allow": false, "index": 6 }
                                [latest-26298]2026-11-03T16:34:36.997Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:34:36.998Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:34:36.999Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:34:37.023Z <wsapi:5:wsapi.js:152> (event handler) sending update for 2 entities
                                [latest-26298]2026-11-03T16:34:37.099Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /favicon.ico lang en-US,en;q=0.9 (TLSv1.3)
                                [latest-26298]2026-11-03T16:34:37.237Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:34:37.238Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                [latest-26298]2026-11-03T16:34:37.239Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                  #21
                                  As part of startup, you have two log messages: httpapi#1 ACLs and httpapi#1 ACL index, one after the other, both with additional data on the same line. Please post those. It looks like your custom ACL is not even being loaded. I would check your users.yaml file against yamllint.com or similar tool... I'm betting you have another error in the file and it's preventing the file from being loaded at all, so the last-known-good version of the configuration (without your ACL change) is being loaded.
                                    #22
                                    Okay, that was helpful. There was an error, and now I'm getting more information. I'm still getting Access Denied, for two separate reasons I think.
                                    [latest-26298]2026-11-03T16:50:01.487Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                    [latest-26298]2026-11-03T16:50:01.488Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                    [latest-26298]2026-11-03T16:50:01.510Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
                                    [latest-26298]2026-11-03T16:50:01.669Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "69.255.234.254" via ::ffff:192.168.1.73 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                    [latest-26298]2026-11-03T16:50:01.669Z <httpapi:5:httpapi.js:1135> httpapi#1 pass_all_proxy is set, passing proxy req from "69.255.234.254" via ::ffff:192.168.1.73
                                    [latest-26298]2026-11-03T16:50:01.669Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                    [latest-26298]2026-11-03T16:50:01.684Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:INFO> httpapi#1 API request from "69.255.234.254" (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 checking ACLs for /api/v1/mfa.add/tmorgenthaler user tmorgenthaler authorization basic
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1/mfa.add/tmorgenthaler; reducing path
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1/mfa.add; reducing path
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1; reducing path
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against /api ACL { "url": "/api", "group": "api_allowed", "source_ip": "192.168.1.1/24", "allow": true, "index": 0 }
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 ACL no match: user tmorgenthaler to group:api_allowed
                                    [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against /api ACL { "url": "/api", "source_ip": "127/8", "allow": true, "index": 6 }
                                    [latest-26298]2026-11-03T16:50:01.686Z <httpapi:null> httpapi#1 ACL no match: IP "69.255.234.254" to source_ip:"127/8"
                                    [latest-26298]2026-11-03T16:50:01.686Z <httpapi:null> httpapi#1 no ACLs matched for /api; reducing path
                                    [latest-26298]2026-11-03T16:50:01.686Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against / ACL { "url": "/", "allow": false, "index": 7 }
                                    [latest-26298]2026-11-03T16:50:01.686Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from "69.255.234.254" user tmorgenthaler auth basic matches / ACL (#7): { "url": "/", "allow": false, "index": 7 }
                                    [latest-26298]2026-11-03T16:50:01.841Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                    [latest-26298]2026-11-03T16:50:01.842Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                    One, it looks like it's seeing my proxy address. I know I set up proxy access in the lastest version of the reactor.yaml file, but it looks like I may need to do the same here.
                                    From reactor.yaml
                                    # baseurl - The base URL to access the Reactor system. If you want to use
                                    #           HTTPS, please see the How-To section of the docs.
                                    baseurl: "https://192.168.1.70:8554"
                                    trusted_proxy: "192.168.1.73"
                                    proxy_baseurl: "https://reactor.notmydomain.com:443"
                                    pass_all_proxy: true
                                    Do I need to put a proxy_baseurl and pass all proxy tag in the users.yaml as well?
                                    The users.yaml file contains the user, so I'm guessing it's hitting the trusted IP filter first?
                                    groups:
                                      # This section defines your user groups. Optionally, it defines application
                                      # and API access restrictions (ACLs) for the group. Users may belong to
                                      # more than one group. Again, no required or special groups here.
                                      admin:
                                        users:
                                          - admin
                                          - tmorgenthaler
                                        applications: true  # special form allows access to ALL applications
                                        api:
                                          default: allow
                                        api_allowed:
                                          users:
                                            - admin
                                            - tmorgenthaler
                                    api_acls:
                                      - url: "/api"
                                        group: api_allowed
                                        allow: true
                                      #23
                                      Okay, this is not making any sense. I'm trying directly from my local workstation, going to the local IP, and I'm still seeing no match on IP.
                                      This is the command I'm using in a browser, in incognito mode, after restarting my docker instance of reactor.
                                      https://192.168.1.70:8554/api/v1/mfa.add/tmorgenthaler?askauth=1
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 ACL no match: IP ::ffff:192.168.1.127 to source_ip:"127/8"
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 no ACLs matched for /api; reducing path
                                      The api_acl list has the whole /24 as allowed.
                                      api_acls:
                                        - url: "/api"
                                          group: api_allowed
                                          allow: true
                                      [latest-26298]2026-11-04T12:43:45.776Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      [latest-26298]2026-11-04T12:43:45.777Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      [latest-26298]2026-11-04T12:43:45.801Z <wsapi:5:wsapi.js:152> (event handler) sending update for 4 entities
                                      [latest-26298]2026-11-04T12:43:45.804Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "192.168.1.127" via ::ffff:192.168.1.127 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
                                      [latest-26298]2026-11-04T12:43:45.805Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
                                      [latest-26298]2026-11-04T12:43:45.817Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
                                      [latest-26298]2026-11-04T12:43:45.817Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.1.127 (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 checking ACLs for /api/v1/mfa.add/tmorgenthaler user tmorgenthaler authorization basic
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1/mfa.add/tmorgenthaler; reducing path
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1/mfa.add; reducing path
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1; reducing path
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against /api ACL { "url": "/api", "group": "api_allowed", "source_ip": "192.168.1.1/24", "allow": true, "index": 0 }
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 ACL no match: user tmorgenthaler to group:api_allowed
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against /api ACL { "url": "/api", "source_ip": "127/8", "allow": true, "index": 6 }
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against / ACL { "url": "/", "allow": false, "index": 7 }
                                      [latest-26298]2026-11-04T12:43:45.818Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from ::ffff:192.168.1.127 user tmorgenthaler auth basic matches / ACL (#7): { "url": "/", "allow": false, "index": 7 }
                                      [latest-26298]2026-11-04T12:43:46.137Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      [latest-26298]2026-11-04T12:43:46.138Z <wsapi:5:wsapi.js:169> (event handler): sending data
                                      My username is in the admin users group, and in the api_allowed users group. My workstation IP of 192.168.1.127 is in the 192.168.1.1/24 network range.
                                      What am I missing that the debug logs are telling me?
                                      • T tamorgen
                                        api_acls:
                                          - url: "/api"
                                            group: api_allowed
                                            allow: true
                                        wrote last edited by tunnus
                                        #24
                                        @tamorgen you could try the canonical CIDR notation of 192.168.1.0/24 and see if it makes any difference (replace last 1 with 0)
                                          #25
                                          The indenting of your groups section is very goofed up. api_allowed and everything below it should be outdented two spaces... same alignment as admin, not underneath it as you've shown. Also the two lines showing after applications under admin... no idea where that comes from or what it's supposed to do. Not sure what the intent was, but that's not anything Reactor will see or care about.
                                          proxy_baseurl and pass_all_proxy do not go in users.yaml.
                                            163.0k
