  4. Reverse proxy & API ACL
9 Posts 3 Posters 356 Views 3 Watching
    wrote last edited by
    reactor.yaml:
    trusted_proxy: "192.168.1.12"
    users.yaml:
    - url: "/api/v1/log"
        method: "GET"
        source_ip: 172.18.0.0/24
        allow: true
      wrote last edited by toggledbits
      Show me your request URL (local network)
        @toggledbits here you go:
        http://192.168.1.12:8111/api/v1/log
          OK. Whatever the docker container on your NAS is doing is different from my test environment (Linux/Ubuntu). With the network set to bridge mode, the only time I see the container's internal address is when a request is made to 127.0.0.1 on the docker host into the Reactor container. Otherwise, I'm seeing real host addresses (LAN or external), not the container internal address.
          I assume 192.168.1.12 is your NAS host address, not some other assigned address?
          I would try reconfiguring your container's networking for host mode.
            OK. I asked an AI friend if Synology works differently, and it reports that yes, indeed, Synology's Docker package does not handle network routing the same as the docker standard (Ubuntu, Debian, Raspberry Pi OS, etc.). It offered the following as a workaround:
            Yes. Synology’s Docker / Container Manager implementation has a well-known difference from standard Docker Engine on Linux.
            On a normal Docker install (Ubuntu, Debian, Raspberry Pi OS, etc.), published-port traffic that arrives via pure iptables DNAT usually preserves the original client source IP (or at least behaves in the ways we discussed earlier). On Synology DSM, the default setup for bridge-mode containers is different: inbound connections almost always appear inside the container as coming from the Docker bridge gateway (typically something like 172.17.0.1 or the gateway of whatever network the container is on).
            What people actually observe on Synology
            Multiple independent reports (Synology Community, Reddit, blogs about AdGuard Home, Pi-hole, Stalwart, etc.) describe the same behavior:
            • Client on the LAN connects to NAS-IP:published-port.
            • The application inside the container logs the source as 172.17.0.1 (or the equivalent gateway), not the real client IP and not the NAS’s LAN IP.
            Your customer describing it as “the container’s internal IP” is very likely referring to this same phenomenon (they may simply be seeing a 172.x address and calling it the container’s IP). It is extremely common on Synology and uncommon on vanilla Docker.
            Why Synology behaves differently
            Synology’s Docker package does not install (or does not keep) the same PREROUTING → DOCKER jump rules that stock Docker uses. As a result, traffic is handled more like a userland proxy that rewrites the source address to the bridge gateway before it reaches the container. Disabling IP masquerading alone does not fix it.
            The classic one-line workaround that many Synology users apply (via SSH) is:
            sudo iptables -t nat -A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER
            sudo iptables -t nat -A PREROUTING -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER
            After adding these rules, the real client IP usually starts appearing. The change is not permanent across reboots, so people typically put it in a Task Scheduler script that runs at boot. Note that it can interact with DSM’s own firewall, so it must be tested carefully.
            Other Synology-specific factors
            • DSM’s built-in reverse proxy is frequently used in front of containers. In that case you also need to configure “Trusted Proxies” and ensure X-Forwarded-For / X-Real-IP are set, otherwise the container (or DSM itself) still sees the proxy’s IP.
            • Host network mode or a macvlan network bypasses the problem entirely (the container sees real client IPs), which is why many Synology users switch to those for apps that require accurate source IPs (DNS filters, rate-limiting, geolocation, etc.).
            In short: this is a known Synology Docker quirk caused by missing/different iptables handling of published ports. The customer’s observation matches the widely reported default behavior on DSM.
            -- end of response --
            Following the advice above is entirely at your own risk. I obviously can't vouch for the accuracy or effects (including undesirable side-effects) of what it suggests.
            Another approach here would be to use LLATs for your local access to the API, and write your ACLs accordingly.
              I use synology reverse proxy since forever and as I've said before, X-Forwarded-For is the key.
                @toggledbits thanks, this is exactly the behavior I'm seeing. Not going to go that iptables route, but need to check if that X-Forwarded-For is the answer.
                  The X-Forwarded-For header is only handled for the trusted_proxy list IPs.
                    wrote last edited by tunnus
                    @therealdb just to clarify that my reverse proxy setup works perfectly except for this one tiny issue of trying to allow (unauthenticated) /api/v1/log connections from the local lan but not via proxy.
                    I tried the following Synology configuration:
                    But it didn't have the effect I was looking for, so I reverted to the "minimum" working setup (and working setup meaning that I can at least access MSR UI):
                    In the logs there's always Docker internal gw address instead of lan or remote IP (in this case the connection was allowed to demostrate the behavior / show gw IP):
                    [latest-26298]2026-10-30T14:29:45.374Z <wsapi:INFO> wsapi: connection from "84.xxx.xxx.xxx" via proxy ::ffff:172.18.0.1
                    [latest-26298]2026-10-30T14:29:45.418Z <wsapi:INFO> wsapi#1 client "84.xxx.xxx.xxx#2" authorized
                    [latest-26298]2026-10-30T14:48:02.743Z <httpapi:INFO> httpapi#1 API request from ::ffff:172.18.0.1: GET /api/v1/log
                    false[latest-26298]2026-10-30T14:48:02.744Z <httpapi:null> httpapi#1 checking ACLs for /api/v1/log user anonymous authorization none
                    false[latest-26298]2026-10-30T14:48:02.744Z <httpapi:null> httpapi#1 checking /api/v1/log against /api/v1/log ACL { "url": "/api/v1/log", "method": "GET", "source_ip": "172.18.0.0/24", "allow": true, "index": 3 }
                    false[latest-26298]2026-10-30T14:48:02.759Z <httpapi:INFO> httpapi#1 request for /api/v1/log from ::ffff:172.18.0.1 user anonymous auth none matches /api/v1/log ACL (#3): { "url": "/api/v1/log", "method": "GET", "source_ip": "172.18.0.0/24", "allow": true, "index": 3 }
                      157.4k
