  4. Reverse proxy & API ACL
Unable to add new groups in DGC, Reactor latest-26318
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 3 Posters 592 Views 3 Watching
    wrote last edited by
    I'm trying to allow anonymous access from a local network to /api/v1/log, but the problem now with the reverse proxy configuration is that this access is open via proxy to the internet. At least I wasn't able to configure ACL so that only an access from a local network would be permitted.
    reactor.yaml:
    baseurl: "http://192.168.1.12:8111"
    proxy_baseurl: "https://external.com:30000"
    trusted_proxy: "192.168.1.12"
    Local traffic would originate from 192.168.1.0/24 network. Synology is acting as a reverse proxy and hosting MSR as a docker container (which has its own network and IP 172.18.0.5). MSR build is latest-26298-fbb75fb8
    users.yaml:
    - url: "/api/v1/log"
        method: "GET"
        source_ip: 172.18.0.0/24
        allow: true
    Using the above ACL works, but it enables access via proxy also. If I use source_ip: 192.168.1.0/24, then it doesn't work either locally or remotely. So I'm kinda lost what should I use as source_ip in this case?
      Show me your request URL (local network)
        @toggledbits here you go:
        http://192.168.1.12:8111/api/v1/log
          OK. Whatever the docker container on your NAS is doing is different from my test environment (Linux/Ubuntu). With the network set to bridge mode, the only time I see the container's internal address is when a request is made to 127.0.0.1 on the docker host into the Reactor container. Otherwise, I'm seeing real host addresses (LAN or external), not the container internal address.
          I assume 192.168.1.12 is your NAS host address, not some other assigned address?
          I would try reconfiguring your container's networking for host mode.
            OK. I asked an AI friend if Synology works differently, and it reports that yes, indeed, Synology's Docker package does not handle network routing the same as the docker standard (Ubuntu, Debian, Raspberry Pi OS, etc.). It offered the following as a workaround:
            Yes. Synology’s Docker / Container Manager implementation has a well-known difference from standard Docker Engine on Linux.
            On a normal Docker install (Ubuntu, Debian, Raspberry Pi OS, etc.), published-port traffic that arrives via pure iptables DNAT usually preserves the original client source IP (or at least behaves in the ways we discussed earlier). On Synology DSM, the default setup for bridge-mode containers is different: inbound connections almost always appear inside the container as coming from the Docker bridge gateway (typically something like 172.17.0.1 or the gateway of whatever network the container is on).
            What people actually observe on Synology
            Multiple independent reports (Synology Community, Reddit, blogs about AdGuard Home, Pi-hole, Stalwart, etc.) describe the same behavior:
            • Client on the LAN connects to NAS-IP:published-port.
            • The application inside the container logs the source as 172.17.0.1 (or the equivalent gateway), not the real client IP and not the NAS’s LAN IP.
            Your customer describing it as “the container’s internal IP” is very likely referring to this same phenomenon (they may simply be seeing a 172.x address and calling it the container’s IP). It is extremely common on Synology and uncommon on vanilla Docker.
            Why Synology behaves differently
            Synology’s Docker package does not install (or does not keep) the same PREROUTING → DOCKER jump rules that stock Docker uses. As a result, traffic is handled more like a userland proxy that rewrites the source address to the bridge gateway before it reaches the container. Disabling IP masquerading alone does not fix it.
            The classic one-line workaround that many Synology users apply (via SSH) is:
            sudo iptables -t nat -A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER
            sudo iptables -t nat -A PREROUTING -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER
            After adding these rules, the real client IP usually starts appearing. The change is not permanent across reboots, so people typically put it in a Task Scheduler script that runs at boot. Note that it can interact with DSM’s own firewall, so it must be tested carefully.
            Other Synology-specific factors
            • DSM’s built-in reverse proxy is frequently used in front of containers. In that case you also need to configure “Trusted Proxies” and ensure X-Forwarded-For / X-Real-IP are set, otherwise the container (or DSM itself) still sees the proxy’s IP.
            • Host network mode or a macvlan network bypasses the problem entirely (the container sees real client IPs), which is why many Synology users switch to those for apps that require accurate source IPs (DNS filters, rate-limiting, geolocation, etc.).
            In short: this is a known Synology Docker quirk caused by missing/different iptables handling of published ports. The customer’s observation matches the widely reported default behavior on DSM.
            -- end of response --
            Following the advice above is entirely at your own risk. I obviously can't vouch for the accuracy or effects (including undesirable side-effects) of what it suggests.
            Another approach here would be to use LLATs for your local access to the API, and write your ACLs accordingly.
              I use synology reverse proxy since forever and as I've said before, X-Forwarded-For is the key.
                @toggledbits thanks, this is exactly the behavior I'm seeing. Not going to go that iptables route, but need to check if that X-Forwarded-For is the answer.
                  The X-Forwarded-For header is only handled for the trusted_proxy list IPs.
                    wrote last edited by tunnus
                    @therealdb just to clarify that my reverse proxy setup works perfectly except for this one tiny issue of trying to allow (unauthenticated) /api/v1/log connections from the local lan but not via proxy.
                    I tried the following Synology configuration:
                    But it didn't have the effect I was looking for, so I reverted to the "minimum" working setup (and working setup meaning that I can at least access MSR UI):
                    In the logs there's always Docker internal gw address instead of lan or remote IP (in this case the connection was allowed to demostrate the behavior / show gw IP):
                    [latest-26298]2026-10-30T14:29:45.374Z <wsapi:INFO> wsapi: connection from "84.xxx.xxx.xxx" via proxy ::ffff:172.18.0.1
                    [latest-26298]2026-10-30T14:29:45.418Z <wsapi:INFO> wsapi#1 client "84.xxx.xxx.xxx#2" authorized
                    [latest-26298]2026-10-30T14:48:02.743Z <httpapi:INFO> httpapi#1 API request from ::ffff:172.18.0.1: GET /api/v1/log
                    false[latest-26298]2026-10-30T14:48:02.744Z <httpapi:null> httpapi#1 checking ACLs for /api/v1/log user anonymous authorization none
                    false[latest-26298]2026-10-30T14:48:02.744Z <httpapi:null> httpapi#1 checking /api/v1/log against /api/v1/log ACL { "url": "/api/v1/log", "method": "GET", "source_ip": "172.18.0.0/24", "allow": true, "index": 3 }
                    false[latest-26298]2026-10-30T14:48:02.759Z <httpapi:INFO> httpapi#1 request for /api/v1/log from ::ffff:172.18.0.1 user anonymous auth none matches /api/v1/log ACL (#3): { "url": "/api/v1/log", "method": "GET", "source_ip": "172.18.0.0/24", "allow": true, "index": 3 }
                    • tunnusT tunnus referenced this topic
                      164.4k
