reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Posters
183
Views
Watching
@toggledbits thanks again for the reverse proxy support! I was wondering whether MSR's login functionality could be further secured, for example by implementing features similar to those Synology uses for DSM (see below).
Interesting exercise. I decided that that alone wasn't sufficient, so I added MFA to the mix. I recommend using both with exposed Reactor systems, and in particular, enable required MFA for all users, so no accounts can accidentally be left open.
