  4. MFA
22 Posts 3 Posters 474 Views 3 Watching
    wrote last edited by
    #21
    As part of startup, you have two log messages: httpapi#1 ACLs and httpapi#1 ACL index, one after the other, both with additional data on the same line. Please post those. It looks like your custom ACL is not even being loaded. I would check your users.yaml file against yamllint.com or similar tool... I'm betting you have another error in the file and it's preventing the file from being loaded at all, so the last-known-good version of the configuration (without your ACL change) is being loaded.
      #22
      Okay, that was helpful. There was an error, and now I'm getting more information. I'm still getting Access Denied, for two separate reasons I think.
      [latest-26298]2026-11-03T16:50:01.487Z <wsapi:5:wsapi.js:169> (event handler): sending data
      [latest-26298]2026-11-03T16:50:01.488Z <wsapi:5:wsapi.js:169> (event handler): sending data
      [latest-26298]2026-11-03T16:50:01.510Z <wsapi:5:wsapi.js:152> (event handler) sending update for 5 entities
      [latest-26298]2026-11-03T16:50:01.669Z <httpapi:5:httpapi.js:1122> httpapi#1 starting request from "69.255.234.254" via ::ffff:192.168.1.73 for GET /api/v1/mfa.add/tmorgenthaler?askauth=1 lang en-US,en;q=0.9 (TLSv1.3)
      [latest-26298]2026-11-03T16:50:01.669Z <httpapi:5:httpapi.js:1135> httpapi#1 pass_all_proxy is set, passing proxy req from "69.255.234.254" via ::ffff:192.168.1.73
      [latest-26298]2026-11-03T16:50:01.669Z <httpapi:5:httpapi.js:1154> httpapi#1 auth header Basic dG1vcmdlbnRoYWxlcjohUjNicjNhdGgzciE=
      [latest-26298]2026-11-03T16:50:01.684Z <httpapi:5:httpapi.js:1161> httpapi#1 auth accepted via HTTP Basic user tmorgenthaler
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:INFO> httpapi#1 API request from "69.255.234.254" (TLSv1.3): GET /api/v1/mfa.add/tmorgenthaler
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 checking ACLs for /api/v1/mfa.add/tmorgenthaler user tmorgenthaler authorization basic
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1/mfa.add/tmorgenthaler; reducing path
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1/mfa.add; reducing path
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 no ACLs matched for /api/v1; reducing path
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against /api ACL { "url": "/api", "group": "api_allowed", "source_ip": "192.168.1.1/24", "allow": true, "index": 0 }
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 ACL no match: user tmorgenthaler to group:api_allowed
      [latest-26298]2026-11-03T16:50:01.685Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against /api ACL { "url": "/api", "source_ip": "127/8", "allow": true, "index": 6 }
      [latest-26298]2026-11-03T16:50:01.686Z <httpapi:null> httpapi#1 ACL no match: IP "69.255.234.254" to source_ip:"127/8"
      [latest-26298]2026-11-03T16:50:01.686Z <httpapi:null> httpapi#1 no ACLs matched for /api; reducing path
      [latest-26298]2026-11-03T16:50:01.686Z <httpapi:null> httpapi#1 checking /api/v1/mfa.add/tmorgenthaler against / ACL { "url": "/", "allow": false, "index": 7 }
      [latest-26298]2026-11-03T16:50:01.686Z <httpapi:INFO> httpapi#1 request for /api/v1/mfa.add/tmorgenthaler from "69.255.234.254" user tmorgenthaler auth basic matches / ACL (#7): { "url": "/", "allow": false, "index": 7 }
      [latest-26298]2026-11-03T16:50:01.841Z <wsapi:5:wsapi.js:169> (event handler): sending data
      [latest-26298]2026-11-03T16:50:01.842Z <wsapi:5:wsapi.js:169> (event handler): sending data
      One, it looks like it's seeing my proxy address. I know I set up proxy access in the lastest version of the reactor.yaml file, but it looks like I may need to do the same here.
      From reactor.yaml
      # baseurl - The base URL to access the Reactor system. If you want to use
      #           HTTPS, please see the How-To section of the docs.
      baseurl: "https://192.168.1.70:8554"
      trusted_proxy: "192.168.1.73"
      proxy_baseurl: "https://reactor.notmydomain.com:443"
      pass_all_proxy: true
      Do I need to put a proxy_baseurl and pass all proxy tag in the users.yaml as well?
      The users.yaml file contains the user, so I'm guessing it's hitting the trusted IP filter first?
      groups:
        # This section defines your user groups. Optionally, it defines application
        # and API access restrictions (ACLs) for the group. Users may belong to
        # more than one group. Again, no required or special groups here.
        admin:
          users:
            - admin
            - tmorgenthaler
          applications: true  # special form allows access to ALL applications
          api:
            default: allow
          api_allowed:
            users:
              - admin
              - tmorgenthaler
      api_acls:
        - url: "/api"
          group: api_allowed
          source_ip: 192.168.1.1/24
          allow: true
        474
        151.9k
