I've seen many of you using Dynamic Group Controller. I'm using it myself for monitoring device battery levels. I've read and re-read the Dynamic Group Controller docs and still cannot come to an answer for my question so let me paint my scenario:
I've migrated from EchoSpeaks in Hubitat ('cause borked and seemingly unmaintained) to Alexa Devices in Home Assistant ('cause not borked in 2026.11.0) to be able to send TTS to my Echo devices.
In EchoSpeaks I could create groups. Sweet.
In Alexa Devices I don't seem to be able to do so. As such, my thought was "wait - isn't there a way in MSR?"
Is this an effective scenario that Dynamic Group Controller can be used for?
AFAIK groups should be enabled in alexa app and you'll find them as device in home assistant. So you can set announcements and volume and such on a single group, instead of separate devices, with the risk of exhausting the api limits.
@therealdb it does and the 2026.11.0 release of Ha fixes the AMZ changes they made that were after affecting login.
Problem: AMZ only allows a device to appear in a single group.
I worked on this last night and found I could write a script to create the groupings I wanted. In testing now.
