  3. Plugins
  4. Openluup: Datayours
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
Openluup: Datayours
18 Posts 2 Posters 6.2k Views 2 Watching
  • D Offline
    D Offline
    Donato
    Hi akbooer,
    tnks
    donato
      This should be straightforward enough. The Whisper library in openLuup has all the needed functionality, I believe. You’d want to run this as a stand-alone command line utility?
      Do you have some example of the files you want to merge?
      D 2 Replies Last reply
        D Offline
        D Offline
        Donato
        @akbooer
        a stand-alone command line utility is ok possibly with the option to indicate a date interval. The files to fill for a remote DY may be more than one all with the same Openluup/Whisper ID.
        At the moment I haven't an example of files to fill . I'll simulate a network outage so I produce the files.
        Can I send you meanwhile the schema to verify if the openluup/DY configuration remote and centralized are correct (destinations, udp receiver ports, line receiver port)
        tnks
        donato
          Yes, send away. Not quite sure what you’re asking, but perhaps it will become clear!
          D 1 Reply Last reply
            D Offline
            D Offline
            Donato
            @akbooer excuse me how can i send you the schema ?
              Message sent.
                D Offline
                D Offline
                Donato
                @akbooer
                Hi akbooer, I've simulated on a test installation a network outage of the remote DY and I've produced two sets of whisper files : one updated (remote DY) and the other one to update (central DY) if possible with a routine similar to Whisper-fill.py from Graphite tool.
                In the files I'll send you by email you find :
                1. whisper file Updated ;
                2. whisper file To Update ;
                3. L_DataUser.lua used for both that processes and creates different metric names;
                4. Storage-aggregation.conf and Storage-schema.conf files.
                  I remain at your disposal for any clarification.
                tnks
                donato
                • D Offline
                  D Offline
                  Donato
                  Hi akbooer,
                  i hope all is well.
                  I've a question about datayours and the aggregation e schemas parameters.
                  I've these configurations :
                  1. aggregation :
                    [Power_Calcolata_Kwatt]
                    pattern = .Variable
                    xFilesFactor = 0
                    aggregationMethod = average
                  2. schemas:
                    pattern = .Variable
                    retentions = 1m:1d,5m:90d,10m:180d,1h:2y,1d:10y
                  In the cache history of openluup console for example i see these values :
                  2024-06-27 09:17:57 46.73
                  2024-06-27 09:17:25 16.55
                  and in the whisper file (it contains a point every minute) i see :
                  1719472620, 46.73 (17119472620 is 09.17 time for my zone)
                  It seems that is considered the last value and not the average of two value registered at 9.17 time.
                  Is it correct ?
                  tnks
                  donato
                    Hi Donato
                    Hope that things are going well for you.
                    Yes, this is expected behaviour. Your shortest aggregation interval is one minute, so any updates faster than that only retain the latest value.
                    There are two possible options:
                    1. Use a schema with an even shorter initial interval, for example 10s.
                    2. Write a custom aggregator which collects and averages values before writing to the variable.
                    I think I gave you the means to do option 2 a while ago, by allowing user-defined actions… but it’s so long ago, I’ve forgotten what we called that! The newest versions of openLuup actually allows you to add a user defined function to any variable to modify the value before it is written, so you could also do it that way.
                    • D Offline
                      D Offline
                      Donato
                      Hi akbooer,
                      tnks now things is going well for me too.
                      You wrote for me the following L_DataUser.lua that I'm using :
                      local function run (metric, value, time)
                        local target = "Variable"
                        local names = {"kwdaily", "kwhourly", "kwmaxhourly"}
                        local metrics = {metric}
                        for i, name in ipairs (names) do
                          local x,n = metric: gsub (target, name)
                          metrics[#metrics+1] = n>0 and x or nil
                        local i = 0
                        return function ()
                          i = i + 1
                          return metrics[i], value, time
                      return {run = run}
                      that write for every value of "Variablex" variable to other whisper files with different aggregation and schemas.
                        Ah yes, that's how we did it!
                        So, the question is how do you want to proceed? Option #1 is by far the easiest, unless other considerations preclude this. It would allow configuration on a per-file basis.
                        What is it that concerns you, that you're really trying to avoid? Are variations within a one-minute interval too much for you? Or is the issue that for the longer durations (one hour, one day) you are not averaging over those correctly?
                        • D Offline
                          D Offline
                          Donato
                          In my installation sensors measure at least a value every 20/30s (in my case is electric power) and I'd like to register the average value every minute (if possible).
                          Can I change the retention schemas of the actual whisper files without loosing the actual data or do I have to start from zero?
                          Over hour and daily period the aggregation is different for the whisper files created by L_DataUser routine :
                          [Power_Daily_DataWatcher]
                          pattern = .kwdaily
                          xFilesFactor = 0
                          aggregationMethod = sum
                          [Power_Hourly_DataWatcher]
                          pattern = .kwhourly
                          xFilesFactor = 0
                          [Power_MaxHourly_DataWatcher]
                          pattern = .kwmaxhourly
                          xFilesFactor = 0
                          aggregationMethod = max
                          For the "Variable" whisper files seems correct the average calculation for 5m, 10m, 1h .. etc based on :
                          and the value registered every minute.
                            So it would be enough to make all the variables handled by L_DataUser.lua output one minute averages, under the assumption that there is at least one per minute?
                            • D Offline
                              D Offline
                              Donato
                              Yes, but all the variables with the name "Variable" (local target = "Variable")
                                Yes, indeed.
                                  @Donato
                                  I think this will do what you need:
                                  local avg_time = 60   -- average over 60 seconds
                                  local caches = {}
                                  local function average (metric, value, time)
                                    local stale = time - avg_time
                                    local cache = caches[metric] or {}      -- find the right cache
                                    caches[metric] = cache
                                    cache[time] = value                     -- update latest value
                                    local n,sum = 0,0
                                    for t,v in pairs(cache) do
                                      if t <= stale then                    -- clear stale values from the cache
                                        cache[t] = nil
                                      else                                  -- add to total
                                        n = n + 1
                                        sum = sum + v
                                    return sum / n
                                    if metric: match(target) then
                                      value = average(metric, value, time)
                                    local i = 0
                                    return function ()
                                      i = i + 1
                                  return {run = run}
                                  • D Offline
                                    D Offline
                                    Donato
                                    Hi akbooer,
                                    excuse me for late answer. Tnks for your precious support as usual.
                                    I'll test your code asap.
                                    A question for my clarity: does the routine register only a value every minute in the whisper file (average of values in a minute) ? Are the different values in a minute momentarily memorized in a DY cache ?
                                    tnks
                                      No, a new 60 second average is calculated, and emitted, on every new measurement.
                                      However, there is still an issue that the averaging window for the internal cache may not be aligned with the one that DataYours is using.
                                      Also, how accurately is the acquisition machine timestamp synchronised with the one doing the averaging and storage?
                                      It’s actually not a trivial problem for these reasons, but there are different options, so do try it, investigate the results, and report back!
                                      Good luck,
                                      AK
                                        164.4k
