  3. Plugins
  4. AltUi
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
AltUi
Scheduled Pinned Locked Moved Solved Plugins
10 Posts 2 Posters 3.5k Views 1 Watching
  • C Offline
    C Offline
    christian_fabre
      Not seen that one before.
      A few more details please:
      • log from the start to the point where you have this error
      • how did you reinstall AltUI (and why – was this just to update it?)
      • I don't have a record of a 2021.05.08 version... do you mean 2021.05.09?
      • C Offline
        C Offline
        christian_fabre
        I reinstalled AltUi because it was not working properly the last few days.
        When I made changes, it didn't take them into account or else it crashed the interface.
        I uninstalled AltUi, the module then the plugin in OpenLuup.
        I reinstalled the plugin in OpenLuup and since then I have the above error.
        My OpenLuup version is the testing version 2021.05.08
        2021-06-01 13:26:08.426   openLuup.server:: GET /data_request?id=lr_ALTUI_Handler&command=home HTTP/1.1 tcp{client}: 0x1c72bb8
        2021-06-01 13:26:08.427   luup.variable_get:: No such device/serviceId/name 26.urn:upnp-org:serviceId:altui1.PluginConfig
        2021-06-01 13:26:08.428   openLuup.context_switch::  ERROR: [dev #26] ./dkjson.lua:397: bad argument #1 to 'strfind' (string expected, got nil)
        2021-06-01 13:26:08.428   openLuup.servlet:: error in callback [lr_ALTUI_Handler] : ./dkjson.lua:397: bad argument #1 to 'strfind' (string expected, got nil)
        2021-06-01 13:26:08.428   openLuup.server:: request completed (224 bytes, 0 chunks, 1 ms) tcp{client}: 0x1c72bb8
          OK, this is a bit difficult without the full log.
          • What is device #26 (AltUI??)
          • how did you reinstall AltUI?
          • Ah, testing, you can switch to the latest development version now (but this will not fix it)
          • C Offline
            C Offline
            christian_fabre
            If I go through AltAppStore.
            I have this log
            2021-06-01 20:31:44.251   openLuup.server:: GET /openLuup?page=app_store HTTP/1.1 tcp{client}: 0x1fee240
            2021-06-01 20:31:44.272   openLuup.server:: request completed (20931 bytes, 0 chunks, 19 ms) tcp{client}: 0x1fee240
            2021-06-01 20:31:47.649   openLuup.server:: POST /openLuup? HTTP/1.1 tcp{client}: 0x1fee240
            2021-06-01 20:31:47.652   luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin
            2021-06-01 20:31:47.653   luup_log:4: AltAppStore : starting <run> phase...
            2021-06-01 20:31:47.655   luup_log:4: AltAppStore : downloading amg0/ALTUI [master] to trash/AltAppStore/
            2021-06-01 20:31:47.655   luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=master
            2021-06-01 20:31:48.012   luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contentsblockly?ref=master
            2021-06-01 20:31:48.285   luup_log:4: AltAppStore : getting contents of version: master
            2021-06-01 20:31:48.285   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: Downloading... now: Downloading... #hooks:0
            2021-06-01 20:31:48.285   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI failed now: ALTUI #hooks:0
            2021-06-01 20:31:48.285   luup_log:4: AltAppStore : scheduling <job> phase...
            2021-06-01 20:31:48.286   openLuup.wsapi.cgi:: /openLuup : {"JobID":"3741"}
            2021-06-01 20:31:48.300   openLuup.server:: request completed (20976 bytes, 0 chunks, 649 ms) tcp{client}: 0x1fee240
            2021-06-01 20:31:48.411   luup_log:4: AltAppStore : starting <job> phase...
            2021-06-01 20:31:48.411   luup_log:4: AltAppStore : (1 of 32)   5860 D_ALTUI.json
            2021-06-01 20:31:48.412   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI now: ALTUI 3% #hooks:0
            2021-06-01 20:31:48.413   luup.variable_set:: 10048.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1622572282 now: 1622572308 #hooks:0
            2021-06-01 20:31:48.526   luup_log:4: AltAppStore : (2 of 32)   1086 D_ALTUI.xml
            2021-06-01 20:31:48.527   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI 3% now: ALTUI 6% #hooks:0
            2021-06-01 20:31:48.600   luup_log:4: AltAppStore : (3 of 32)   6730 D_ALTUI_UI7.json
            2021-06-01 20:31:48.600   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI 6% now: ALTUI 9% #hooks:0
            2021-06-01 20:31:48.945   luup_log:4: AltAppStore : (4 of 32)   2425 I_ALTUI.xml
            2021-06-01 20:31:48.946   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI 9% now: ALTUI 12% #hooks:0
            2021-06-01 20:31:48.982   luup.variable_set:: 10048.urn:micasaverde-com:serviceId:EnergyMetering1.Watts was: 7.89 now: 7.05 #hooks:0
            2021-06-01 20:31:48.983   luup.variable_set:: 10048.urn:micasaverde-com:serviceId:EnergyMetering1.Log was: 7,7,8,1622572282,83 now: 7,7,8,1622572308,109 #hooks:0
            2021-06-01 20:31:49.232   luup_log:4: AltAppStore : (5 of 32)  15421 J_ALTUI.js
            2021-06-01 20:31:49.233   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI 12% now: ALTUI 16% #hooks:0
            2021-06-01 20:31:51.337   luup_log:4: AltAppStore : download failed, status: Operation already in progress
            2021-06-01 20:31:51.337   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: ALTUI 16% now: ALTUI failed #hooks:0
              Did you press the download button twice??
              I’m still guessing, but if the ALTUI device is #26, then try deleting the PluginConfig variable and then restart.
              • C Offline
                C Offline
                christian_fabre
                I no longer have a device 26.
                it was the old AltUi device that I removed with the AltUi plugin.
                After the new installation, the new AltUi device is now 97.
                But the error seems to be that it is still looking for device 26.
                see log
                2021-06-02 08:58:07.522   luup.variable_get:: No such device/serviceId/name 26.urn:upnp-org:serviceId:altui1.PluginConfig
                2021-06-02 08:58:07.522   openLuup.context_switch::  ERROR: [dev #26] ./dkjson.lua:397: bad argument #1 to 'strfind' (string expected, got nil)
                2021-06-02 08:58:07.522   openLuup.servlet:: error in callback [lr_ALTUI_Handler] : ./dkjson.lua:397: bad argument #1 to 'strfind' (string expected, got ni
                  This is why I asked for the whole log. Little snippets simply don’t capture the whole picture. I’d like all the Startup log, as well as the main one from the start up to the point of the error.
                  • C Offline
                    C Offline
                    christian_fabre
                    I do not know by what miracle, but after a new start (power cut), I found AltUi (device 26) and functioning normal.
                    Thank you for your help and for the time spent for your advice.
                    Kindly
                      Well, that’s good... we’ll never know what that was all about!
                        157.7k
