  3. Home Assistant
  4. Home Assistant Voice
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
21 Posts 6 Posters 11.2k Views 6 Watching
    Has anyone had a play with the local voice control for HA? I've got one on order because... 🙂
    Home Assistant Voice Preview Edition
    Bring choice to voice - the best way to get started with voice
      Not yet!! I have been waiting for something with a little bit better audio, think Sonos level. Do report back though
        I won't be using it for music. I have a full Cyrus stack with Vienna Acoustics for music 🙂 Only want the interactive voice options
          @CatmanV2 not yet - I'm letting other kinds go in the pool first.
            Oh god! Am I a trail blazer? This won't end well!
            Voice control / interaction is very much my thing. It's the future I was promised, and I'm still tapping away on 102 switches 😞
              Well, so far so 'OK' Took a fair while to set up. One of the wake phrases absolutely does not work for me 'Hey Jarvis'
              I think getting all the devices I have decent aliases so it knows what to control may take some time.
              Local processing on a VM with 2 CPUs and 4G of RAM is pretty slow. Takes about 10 seconds to action an switch and fails to understand about 20% of the time. Hybrid is much faster.
              Audio quality of the voice response is really not great. There are plenty voices to chose from, but none of them as polished as Alexa (so far)
              I think I have much to learn so not writing it off just yet.
                I didn’t go the HA route, but have voice control through Apple HomeKit and Siri. Works OK, but don’t use it much.
                  I'm in. Let's see what we can get done with this, shall we?
                  I'm also looking at some other open source solutions that aren't HA-specific.
                    @akbooer I have Alexa that works really well for most voice control, but doesn't interact with HA. I have virtual switches in OpenLuup that are exposed HA bridge, so effectively I simply ask to flip a switch and the automation follows.
                    The exception is my Logitech Elite hubs which integrate with Alexa directly (and also work really well)
                    @toggledbits that would be awesome. I'm keen on the more interactive stuff (i.e. where the VA prompts for activity)
                    Certainly I can make Alexa speak, but a simple 'yes' or 'no' response isn't going to get anything from her.
                    • V Offline
                      V Offline
                      Venom
                      I set one of these up a few months ago. I got it working pretty easily. It controls everything My Amazon Echo Alexa could do. My Logitech Harmony Hubs work better with the Home Assistant Voice. Alexa seems to have a problem here and there telling me the device is not responding. Then I give the same command to HAV and it works. I did activate Alexa in Home assistant and it works pretty well. As mentioned the lag with the HAV was pretty long. As a test I tried the Home Assistant cloud service. That cut down the lag a lot. Now it is only slightly slower than Alexa. I am going to try building a dedicated AI PC. That should cut the lag to zero and I can get rid of the cloud service. Once I get the HAV to react quickly and do everything as I would like I will move on to improving sound quality.
                        Given I'm starting from zero on this particular path it would be interestting to see how you set it up. Took me about 90 minutes to get a light to turn on! The documentation I've found so far is, well, poor
                        TIA
                        • V Offline
                          V Offline
                          Venom
                          This morning I noticed an update was available for Home Assistant Voice. I did the update and it broke the HAV. I had to re-enable it along with the Cloud Service to get it working again.
                          I got mine working by watching a lot of Youtube Videos. I would start by watching the newest videos you find. That is important. The one thing I noticed with Home Assistant in general, Updates come very often and instructions you find today may be different after an update. I also read lots in the Home Assistant Forum. Same goes there, read the latest posts first. What I did 6 months ago, if I could remember what I did, probably would not be the way to do it today. I keep planning on really learning the most I can about Home Assistant but life keeps getting in the way. So I continue to stumble my way through it..
                            Cheers! I shall try and make some time 🙂
                            (Is it just me that hates having to watch videos? Can't we just have instructions written down? 🙂 )
                            V akbooerA 2 Replies Last reply
                              V Offline
                              V Offline
                              Venom
                              @CatmanV2
                              You can find lots of written instructions in the Home Assistant forums. The problem I found was that when I went into the HA Settings I could not find many of the items the instructions mentioned. They had already been changed by updates to HA. That is why I mentioned looking at the newest posts and videos. I found that the Youtube videos seem to have the latest tips and instructions. While I love all the frequent advancements and updates being made in HA, it can be rather difficult for someone new to HA to jump in and get everything working.
                                Thanks (again) I have found this 🙂
                                  OK, so digging through stuff. Definite progress. I've got an OpenAI integration running, but just been told that 'Max output tokens reached' which seems a little odd as I've used precisely $0.01
                                  Must go out now!
                                    @CatmanV2 said in Home Assistant Voice:
                                    Not just you! Such a lot of very poor narration and not so easy to refer back to! A modern disease.
                                      @akbooer I just don't get it. I guess it's less effort to make a video than actually write down the instructions. Sure, for somethings they can be useful but a 15 minute video for a 5 minute config. Grrr!
                                        I got my HAV a couple of days ago. Out of the box, setup was actually pretty easy. I agree with others that watching videos isn't my favorite way to do that kind of thing, but there are written instructions behind the QR code they provide in the box.
                                        It deemed my HA host system (NUC) insufficient to do speech-to-text/conversation locally, so I signed up for Home Assistant Cloud and set it up that way. I'll circle around to that again later and see if I can free myself from the cloud, but the small monthly or annual fee is within my sensibilities for ensuring high Wife Acceptability on functionality.
                                        Lights on an off is easy. This is the most basic thing to get right, I guess, and it works great. With a few small tweaks to HassController (future build/release) I was able to get TTS output working very easily. Also playing media is pretty straightforward. It's also easy to control the brightness and color of the LED ring (maybe some future purpose for this will arise).
                                        Most challenging so far was getting it to recognize a custom sentence. Actually, configuring the custom sentence was not really hard, but getting HA to do something other than speak "Intent does not exist" took some trial and error -- a classic HA trial of getting the right configuration magic into the right places, restarting untold numbers of times, while combing through inconsistent examples in the pages of their online documentation. Finally got it, although I swear my last attempt was the same as a half-dozen prior that didn't work. But I can finally say "Hey Jarvis, bark like a dog" and have it cause Reactor to reliably launch the play of an MP3 file on my living room Sonos SL1. Woof!
                                        I also was able, from Reactor, to get it to speak a question, recognize a response from a list of expected responses, and store the response data in a Reactor variable. Seems useful, although I'm not yet sure how. That also took a little HassController modification (again, future release) to fully realize, and some tribal knowledge of how the HA API wants data structured for certain fields of that call. This isn't the kind of knowledge we normally encounter when calling HA services, so I'll write that up separately somewhere.
                                        These minor successes are actually very encouraging. I think this thing is going to create a lot of opportunities.
                                          @toggledbits I'm watching all of this play out for now. "Leading edge vs bleeding edge" atm.
                                          I'm very encouraged to see this doing as well in testing as it is. Anything to get me able to move off of non-privacy/non-cloud Echo devices is def getting my attention.
