  3. Home Assistant
  4. Home Assistant Door Locks via Keymaster - Adding Second Lock Not Working
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
17 Posts 3 Posters 6.9k Views 3 Watching
    sammy2
    I have set up HA in a VM Box Virtual Machine and am progressing along.
    I got new Kwikset Connect 620 door locks and got one connected to HA via Z-Wave JS and automated via Keymaster which is quite convoluted but I got it done.
    I went to install the second lock and got it connected to HA via Z-Wave JS but am not being successful getting it to work properly in Keymaster.
    Screenshot above is the second lock for the laundry room. It shows it is set up but the codes don't seem to be working.
    I have not installed the lock yet and have not set the handing either. Maybe this is the issue but IDK.
    Anyone have experience setting up locks in HA using Keymaster that can help would be great!
      Check if the lock was included securely, if it wasn't then you cannot change codes
      S 1 Reply Last reply
        sammy2
        @Pabla
        I'm pretty sure I included it securely but where can I check?
          wrote on last edited by Pabla
          Go to settings -> devices -> Z-Wave -> <your lock name> -> under "Device Info" click the chevron for "Z Wave Info" and it should have security info there
            sammy2
            Looks good to me!
              Are you able to set the code via the zwave_js.set_lock_usercode service call?
                sammy2
                @Pabla said in Home Assistant Door Locks via Keymaster - Adding Second Lock Not Working:
                Break it down for me as in HomeAssistant / Linux CLI for Dummies!
                  Performing actions
                  Performing actions
                  Instructions on how to perform actions in Home Assistant.
                  Service call were renamed to actions but its the same thing
                    Performing actions
                    Performing actions
                    sammy2
                    Performing actions
                    Performing actions
                    couldn't get anything returned here (Not sure what I'm doing wrong):
                    Although the lock shows up in the separate "Lock" Dashboard:
                    I'm seeing this in the main dashboard:
                    And have these Repair Notifications:
                      heres an example of what the service call should look like. I prefer to call services on the entity and not device. Have you also recently renamed the lock? Go to the lock in question and click it and take a look at the entity id, not the name.
                        sammy2
                        That worked..
                        I think I need to actually install the lock on the door and see if the codes stick after setting the handing up.
                          sammy2
                          @sammy2 said in Home Assistant Door Locks via Keymaster - Adding Second Lock Not Working:
                          That worked..
                          So I installed the lock and the codes sent from HA/Keymaster do work but I'm having issues with the Dashboard in that the Lock Badge at the top is not there like it is in the Front Door Dashboard:
                          I tried to install it manually but it isn't working. I'd like to have feedback in the Dashboard of the lock status. It does show in the Home Dashboard but doesn't work and neither does the one for the Front Door:
                            sammy2
                            Just reporting back that with help of firstof9 on GitHub and the HA forums I got this sorted except for one lock which is probably out of range of my Z-Wave Controller. I need to put in more powered devices to get better hops.
                            • S sammy2
                              Or, try priority routes. In my cases, it helped a lot with a powered devices refusing to working correctly, but that I know is near others that are able to be used as repeaters.
                                sammy2
                                @therealdb said in Home Assistant Door Locks via Keymaster - Adding Second Lock Not Working:
                                Where do you do this? Is it in Z-Wave JS UI? I haven't gone through the steps to set that up yet as it looks to take a little time from what I've read.
                                • S sammy2
                                  @sammy2 yep, see for an explanation:
                                  DrZWave  /  Jul 13, 2021
                                  Z-Wave Mesh Priority Routes Explained
                                  Brief explanation of how to use Application Priority Routes in the Z-Wave Mesh to optimize delivery
                                  It's under network graph (left menu). You need to set return routes. I have a couple of nodes that went from 10 sec to instantly, because of an horrible set of dynamic routes calculated automatically.
                                    sammy2
                                    That sounds like a work day and a potential to bork my system! I think physically re-routing is probably more practical.
                                    My locks are all now set up and working. I had to move my NUC / Controller to a high location more central in my house and put in a wired repeater to help route around a massive masonry fireplace that goes from the floor to above the roof and is about 2 or more feet thick and the full width of the wall separating the Family Room from the Laundry Room to get the lock between the laundry room and garage to show up on the network.
                                    Very pleased thus far with Keymaster and now I need to set up notifications so I know when certain people are coming through the locks and into my house.
                                      164.4k
