  3. Home Assistant
  4. Alexa not connecting to my Vizio soundbar via bluetooth
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
alexaviziosoundbarsmart home
4 Posts 2 Posters 3.5k Views 2 Watching
    alikamali
      theabraham90
      To remedy connectivity woes when linking and connecting your Vizio soundbar to Alexa via Bluetooth, a reboot of both devices often works wonders. Ensure they’re in close proximity, unpaired with other devices. If troubles linger, a factory reset of the soundbar might just be the needed charm.
      Also make sure the distance between your Alexa device and your Soundbar is within the appropriate range
        theabraham90
        Also make sure the devices are within the appropriate range
          alikamali
          thanks for the advice, the issue was simply solved by forgetting and repairing the device, I'm not sure, but there was an interference from my bluetooth headphones that I tried switching off, anyway the article below helped a lot with tackling the issue, I put it here so others can use it if ever encountering this issue:
          Erfan Askari  /  Jan 29, 2024  /  Voice Assistants
          How To Connect Alexa To Vizio Soundbar: Ultimate Guide | Smart Home Scope
          Trying to connect Alexa to Vizio soundbar? Here’s a guide that’ll help you do it by Bluetooth and AUX, the choice is yours!
            1.1k
            158.7k
