  3. Home Assistant
  4. Migration Vera to HA > how to send sensor data from Vera to HA?
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
7 Posts 3 Posters 2.2k Views 3 Watching
    Maipensato
    wrote on last edited by Maipensato
    CrilleC 1 Reply Last reply
    • M Maipensato
      Have you considered Reactor - Multi-hub Automation version?
      If not I strongly recommend this path for your automations as it has controllers for both Home Assistant and Vera.
      You can still use HA as UI but do all logic in Reactor Multi-hub, no learning curve when you are familiar with Reactor for Vera, you can import your Reactor for Vera into Reactor Multi-hub and set sensor data and variables directly to HA entities.
      • CrilleC Crille
        @Crille @Maipensato I cannot possibly endorse more positively the standalone MSR. https://reactor.toggledbits.com/docs
        I recommend the containered approach having done so just this week after using an RPi for years (since MSR was released). Just a much easier approach.
          Maipensato
          @Crille @gwp1 Thanks for your quick replies and recommendations.
          For sure I have considered MSR. Reasons why I did not opt for this:
          1. in the end I want to do everything within HA incl UI so transferring data from Vera to HA is temporary . HA offers a huge amount of integrations and a big community of users and developers
          2. I run the all inclusive HA OS on a HP thin client. I know there is a Reactor for Home Assistant add-on but read there are issues with it
          3. Switching from the Vera Reactor to MSR is doable but takes time and it is different. The biggest disadvantage in my case is that MSR can not handle LUA code and my most complex Reactors use quite some LUA code
          So this is why I opened a topic here with my specific question.
          Any help /'advice ?
            Maipensato
            Another option (maybe more simple? is to retrieve the sensor data from Vera within Home Assistant.
            This is the code to switch on a switch:
            http://192.168.1.xxx:3480/data_request?id=lu_action&output_format=xml&DeviceNum=185&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1
            How do I get the CurrentLevel of a temperature sensor:
            serviceId = =urn:upnp-org:serviceId:TemperatureSensor1
            How to define the action ?
            • M Maipensato
              Any help /'advice ?
              @Maipensato
              @Maipensato said in Migration Vera to HA > how to send sensor data from Vera to HA?:
              Yep. And it's all available in MSR when you configure the connection between them.
              You may find that MSR replaces the need for this level of hand-coding.
              IIRC, there's a script to migrate Vera's Reactor to MSR. I used it several years ago.
              I use MSR as my rules engine between Hubitat and HA. HA provides many great integrations as well as controlling some ZWave devices and has the dashboarding I want. Hubitat controls most devices and has some integrations it does better than HA.
              In the end it's up to you, of course. I have everything running in Proxmox containers.
                Maipensato
                @gwp1 I have no doubts that MSR is a great tool for sure when you use more than one platform.
                But sorry I repeat myself... my goal is to only use Home Assistant in the near future and I will migrate step by step from Vera.
                If I can not do all automations in HA I will most certainly seriously consider combining HA with MSR.
                In the meantime I have found the answers on my question myself.
                http luup request to get values of sensor data/variables from Vera.
                Example for a rain sensor:
                http://192.168.1.xxx:3480/data_request?id=variableget&DeviceNum=xx&serviceId=urn:upnp-org:serviceId:RainSensor1&Variable=CurrentRain
                Within Home Assistant I created RESTful sensors to get the data in.
                And it works great.
                  165.3k
