  3. Home Assistant
  4. Hosting web interface inside HA?
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
2 Posts 2 Posters 1.1k Views 2 Watching
      Images and cams are proxied by HA. You’ll definitely need something specific. I’m using synology’s ability to relay an internal address with a private dns to avoid using a vpn while at the office (or anywhere, when using my laptop). I’ve exposed Vera, reactor and ha this way and the normal tweaking is easy.
      The complex route will be to add ngnix, an authentication layer and route everything.
        165.3k
