  3. Home Assistant
  4. https not allowed in reactor?
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
9 Posts 2 Posters 2.7k Views 2 Watching
  • F Offline
    Hi!
      Not enough detail here to respond.
      • F Offline
        What I meant was; is it possible for MSR to access HA if the HA-address is a https://192.168.x.x:8123? With the "s"? Because I couldn't.
        • F Offline
          To clarify; If I use "Let's encrypt", MSR is not able to connect to HA. Without it, there's no problem. I don't understand why, and is it possible to use HA in MSR with "Let's Encrypt"?
            Let'sEncrypt works fine; I use them exclusively myself. I was hoping you'd tell me what platform you're on (in addition to other things, like maybe that you've looked at the logs and snipped the messages around the request), but in case you're on Raspian, even new versions carry some pretty old data in annoying places. Make sure your system is up to date -- like any other system, there are OS and package updates that need to be followed. Also make sure you've updated the CA chain as well (on RPi, you can run update-ca-certificates).
            • F Offline
              I have two platforms and HA-instances; on a VM on Windows 10 and another on "Home assistant blue"/Odroid N2+.
                OK. You'll need to work out how to make sure your CA chain is up to date on those platforms; I don't know.
                Also, have you tried the request with "Ignore self-signed/invalid SSL certificates" checked on?
                • F Offline
                  I seem to have solved it.
                  In the MSR config file, I had to add another "s" i the ws --> wss:
                  source: 'wss://fananXX.duckdns.org'
                  It works now, so I'm happy.
                    OK. Of course, I was assuming, because of your example in reply to me, that you were making an HTTP request (via the HTTP Request action in reactions) to HA, not trying to use the secure websocket at the Controller interface level. This is why details in reports are important. More better than less. Also, if you have posted information from log files, it also would have been obvious that I was thinking about the wrong connection.
