  3. Home Assistant
  4. HA Bridge oddity
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
HA Bridge oddity
2 Posts 1 Posters 926 Views 1 Watching
    Any thoughts?
    TIA
      Well not really solved but....
      Copied the device in HA-Bridge. Discovered it in Alexa and it works. Deleted the old one and re-named it.
      Still works
      Go figure.
        148.9k
