  3. Home Assistant
  4. Home Assistant Voice TTS is Easy
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
3 Posts 2 Posters 2.3k Views 2 Watching
    TTS announcements with Home Assistant Voice are about as easy as they can be (once you have your HAV unit configured).
    Via the Home Assistant Developer Tools UI:
    Choose the announce action, and then the HAV "satellite" unit on which to play the announcement. Enter the text, and go!
    Via Reactor:
    Pretty much the same... select the HAV satellite's entity, and the x_hass_assist_satellite.announce action. Supply the message text and go:
    In a Reaction, the entity, action, and parameters are the same.
      I must have missed something in the Voice preview set up then as I can't get TTS working (at least from the test situation)
      I might try from your state
        I take it back. Worked immediately!
          154.3k
