  3. Home Assistant
  4. Anyone having expience writing an ZHA quirk? Would love some pointers.
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
1 Posts 1 Posters 1.1k Views 1 Watching
    Andr
    Hi
    My latest try was to chat with Gemini AI 😰 (programmers, rest assured that your job will be safe for the foreseeable future 😁 )
    Any help would be much appreciated. 🙏
      343
      151.2k
