  3. Home Assistant
  4. Home Assistant Fork
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
Home Assistant Fork
1 Posts 1 Posters 1.3k Views 1 Watching
    Opening a thread to discuss updates to my home assistant fork.
    GitHub - rafale77/core: :house_with_garden: Open source home automation that puts local control and privacy first
    :house_with_garden: Open source home automation that puts local control and privacy first - rafale77/core
    I am trying to keep it on par with the official one but have made quite a few tweaks focused on video handling and processing. Home Assistant being developed on python is a great base for integration of machine learning and deep learning models into smarthomes because it is one of the most common languages used in the field.
    As of today, I updated the readme file and the version to match the latest official release.
      154.4k
