  3. Home Assistant
  4. Play Audio through Home Assistant Voice Unit
HA and AI
Migrating from Vera Plus to Home Assistant (or other?)
New HA instance
PerHP
Lovelace initial setup
PerHP
MatohlM
PerHP
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
1 Posts 1 Posters 1.1k Views 1 Watching
    Starting with the basics...
    Via the Home Assistant Developer Tools UI:
    Select the HAV device on which to play the media. Specify the URL to the media as the media_id. For most media played on HAV units, you'll want to select music as the media_type.
    Via Reactor:
    There will be an entity specifically for the HAV unit's media player. On that entity, run the x_hass_media_player.play_media action. Parameters are the same as those described above. The image below shows a direct run of the action from the Entities list; in a Reaction the action and parameters would be the same.
      163.3k
