  3. Home Assistant
  4. Using HA Harmony Hub to control volume
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
4 Posts 2 Posters 1.6k Views 2 Watching
    Very impressed by Harmony hub on HA. Seems to suck all of my network goodness in 🙂
    <edit?> There should be a screen capture here, but I'm getting a Parse error 😞
    @DesT ....
    TIA
      Instead of using a call service command just use the remote entity and invoke the x_hass_remote.send_command and fill in the info as needed. Device is the name of the device you wish to control (in this case your TV), command is the command (Volume Up) and the num_repeats etc. can be left untouched if you don't need it. Device info and commands can be found in the /config folder in HA. It will be labelled harmony_[hub number].conf.
        Ahh, that seems to easy 🙂 I shall give it a whirl!
          Well that was far too easy. Thanks for the pointer at /config makes it really simple!
            164.4k
