  3. Home Assistant
  4. Odd behavior in HA
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
Odd behavior in HA
4 Posts 2 Posters 1.7k Views 2 Watching
    RogerO
    Hello,
    Roger
    • N Offline
      N Offline
      Nameless
      What version of HA are you running? There were breaking changes starting with 2021.4.1 and updates had to be made. Pretty sure more breaking changes since, as well.
        RogerO
        On 2021.10.6. I just started playing with HA so no idea if it ever worked.
        • N Offline
          N Offline
          Nameless
          There's an updated blueprint posted in the HA forum, but not easy to find. It's midway through a large thread.
          I don't have this device, so can't say if it's 100% working now.
          You can try contacting The Smartest House through their website. If they don't have something posted, they may point you in the right direction.
            1.1k
            158.7k
