  4. Can you run MSR on Home Assistant OS ?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
12 Posts 5 Posters 1.7k Views 5 Watching
    Looking at using Home Assistant for the first time, either on a Home Assistant Green, their own hardware or buying a cheap second hand mini PC.
    Sounds like Home Assistant OS is linux based using Docker for HA etc.
    Would I also be able to install things like MSR as well on their OS ? On the same box?
    PablaP 1 Reply Last reply
      Docker is the way to go. I have two distinct hosts (one mainly as failover) and dozens of docker containers running alongside. The best feature is separation between them, so that if you mess with them, your system will run stable anyway and just the problematic containers will be impacted. Also, using docker compose file setup is a breeze. Not an easy learning curve, but doable.
        You can't (sensibly) install additional, non supported things on HAOS
        Docker is powerful, but feels rather like a steep learning curve in this case (as mentioned) I'd either get a couple of old NUCs from ebay, or get a decent(ish) NAS with VM capability. Much simpler IMHO
          It’s just the first phase that’s complicated. In terms of every day operations, it’s very easy to manage and automate. Plus, no need to backup the entire vm but you’re good with just data and less memory/cpu intensive by design. Worth to explorer when doing a major re-design imho.
            @therealdb said in Can you run MSR on Home Assistant OS ?:
            It’s just the first phase that’s complicate.
            Spot on! For most Linux systems, docker is just a package with a one-line install process. From there, life is simple if you install and use docker-compose, for which I include sample configurations in both the documentation and the distribution.
              Yes. It’s just the part where you need to understand paths and ports mapping. The a couple of cli command with docker compose and you’re good to go. Portability and backups are super easy (and fast).
                @toggledbits And Docker can be made even easier with Portainer on top!
                • cw-kidC cw-kid
                  @cw-kid Initially, I wanted to run MSR on HA. But HA OS keeps a lot of things locked down (for better and worse) and occasionally you have to go into the container's directory to make changes and HA OS basically makes that impossible.
                    @Pabla said in Can you run MSR on Home Assistant OS ?:
                    If you have to go into the container to make changes, something is wrong in the configuration. Nothing inside the container should ever need to be changed. Everything that is "mutable" and configurable by the user should be in the data directory external to the container. So... this comment has me puzzled...
                    Not a fan, but I can see the utility. And there's a Portainer add-on for HA OS.
                      @toggledbits said in Can you run MSR on Home Assistant OS ?:
                      Had to edit entity config file recently to batch update entity names
                        You mean in the storage directory?
                          Sounds like you all just defined steep learning curve 😉
                            163.3k
