  4. Can you run MSR on Home Assistant OS ?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
11 Posts 5 Posters 92 Views 5 Watching
    wrote last edited by cw-kid
    PablaP 1 Reply Last reply
      Docker is the way to go. I have two distinct hosts (one mainly as failover) and dozens of docker containers running alongside. The best feature is separation between them, so that if you mess with them, your system will run stable anyway and just the problematic containers will be impacted. Also, using docker compose file setup is a breeze. Not an easy learning curve, but doable.
        You can't (sensibly) install additional, non supported things on HAOS
        Docker is powerful, but feels rather like a steep learning curve in this case (as mentioned) I'd either get a couple of old NUCs from ebay, or get a decent(ish) NAS with VM capability. Much simpler IMHO
          wrote last edited by therealdb
          It’s just the first phase that’s complicated. In terms of every day operations, it’s very easy to manage and automate. Plus, no need to backup the entire vm but you’re good with just data and less memory/cpu intensive by design. Worth to explorer when doing a major re-design imho.
            @therealdb said in Can you run MSR on Home Assistant OS ?:
            It’s just the first phase that’s complicate.
            Spot on! For most Linux systems, docker is just a package with a one-line install process. From there, life is simple if you install and use docker-compose, for which I include sample configurations in both the documentation and the distribution.
              Yes. It’s just the part where you need to understand paths and ports mapping. The a couple of cli command with docker compose and you’re good to go. Portability and backups are super easy (and fast).
                @toggledbits And Docker can be made even easier with Portainer on top!
                  @cw-kid Initially, I wanted to run MSR on HA. But HA OS keeps a lot of things locked down (for better and worse) and occasionally you have to go into the container's directory to make changes and HA OS basically makes that impossible.
                    @Pabla said in Can you run MSR on Home Assistant OS ?:
                    If you have to go into the container to make changes, something is wrong in the configuration. Nothing inside the container should ever need to be changed. Everything that is "mutable" and configurable by the user should be in the data directory external to the container. So... this comment has me puzzled...
                    Not a fan, but I can see the utility. And there's a Portainer add-on for HA OS.
                      @toggledbits said in Can you run MSR on Home Assistant OS ?:
                      Had to edit entity config file recently to batch update entity names
                        You mean in the storage directory?
                          3.5k
                          3.1k
                          370
                        • Self test
