  3. SBC
  4. RPi Alternative: Libre Computer AML-S905X-CC "Le Potato" (2GB RAM)
SBC
The last of four boards I'm trying in this batch is the Orange Pi 4 LTS. I purchased a 3GB RAM + 16GB eMMC model from Amazon for $83, making it the most costly of the four boards tried, but still well under my US$100 limit. This board is powered by a Rockchip RK3399-T processor, ARM-compatible with dual Cortex-A72 cores and quad Cortex-A53 cores at 1.6Ghz (1.8Ghz for the 4GB model); compare this to the RPi 3B+ with four Cortex-A53 and the RPi 4B with four Cortex-A72, this board is a hybrid that I would expect to stand in the performance middle between the two RPi models. It's available in 3GB and 4GB DDR4 RAM configurations, with and without 16GB eMMC storage. It has a MicroSDHC slot, gigabit Ethernet, WiFi and BT, two USB 2.0 type A ports, one USB 3.0 type C port, a mini PCIe ribbon-cable connector (requires add-on board for standard connector), two each RPi-compatible camera and LCD ports, HDMI type A, and can be powered (5VDC/3A) via USB-C or DC type C (3.8mm OD/1.1mm ID) jack (center-positive), an odd and perhaps unwelcome departure from the more common type A (5.5mm/2.1mm). A serial port for console/debug can be connected by using a (not included) USB-TTL adapter (3.3V) via pin headers like the Orange Pi Zero 2. The included dual-band antenna connects via U.FL connector to the board, so it's easy substituting for another if you prefer. The manufacturer recommends use of a heat sink (which was included in the box). A metal cooling case is also offered by the manufacturer (a bundle with the metal case and a power supply is sold on Amazon for $90 as of this writing). The Orange Pi 4 LTS is somewhat longer than the RPi 4B, and although the boards are the same width, the mounting hole placement is different both in length and (oddly) width. Between this and the differences in connector locations, neither board is a drop-in replacecment for the other and their respective cases are not interchangeable. The 26-pin header is a subset of the RPi 4B's 40-pin header, so some HATs for the RPi may work (although the mounting hole differences will make securing them "interesting"), and some HATs will surely not. Models with eMMC storage have an OS installed and boot immediately with SSH daemon running and ready for login. Mine was running Debian Bullseye, which would probably be fine for most users. It had clearly been on there a while, because it needed a lot of updates, but it's a current distro, so you're running out of the box with something that will last. A different OS can be installed by downloading an image (once again I chose Ubuntu Jammy) and writing it to a MicroSD card, then booting the system from the SD card. You can either leave the system in that state (running the OS from the SD card), or copy the OS from the SD card to the eMMC. The latter is done by a script; documentation for the process is best described in the downloadable PDF User Manual. This took about 10 minutes and went smoothly, and I was able to boot the system without the SD card after the process completed. I have lingering questions around the value of the eMMC storage. It's definitely faster than using MicroSD or USB-based storage (I got 311MB/s average on a 4GB write, compared to MicroSD performance around 15MB/s), but it would take a long-term test of this product to determine if the on-board eMMC option has the stamina to take the write counts typical of Linux systems, and if its wear-leveling and error correction are sufficient to assure a long, error-free life. Given the high premium apparently being paid for including eMMC on the board, it should be fast and durable, but only time and experience (perhaps painful) would tell the latter. A careful configuration with other Flash-friendly filesystems could be used to reduce wear, but this is an advanced configuration/cookbook topic and beyond the scope of this writing. This question is also not unique to eMMC — MicroSD cards are also known to fail with high write cycles, so the use of a "high endurance" product is recommended for any and all systems using MicroSD as primary storage. The board has Mini PCIe capability, and that may be a storage alternative, but read on... Also bear in mind that the eMMC storage is fixed-size forever; it cannot be expanded, and 16GB can run out pretty quickly these days. Users of MicroSD cards for primary storage can upgrade to bigger cards, but when users of eMMC primary storage outgrow it, the only choice is to add a MicroSD card or other "external" storage to the system, move part of the filesystem to it, and then manage both storage devices and deal with the limitations and risks of both. As I mentioned with the Orange Pi Zero 2, if you are going to use this board as a home automation controller/gateway or similar role, it should (IMO) have a battery-backed real time clock (RTC), and Orange Pi offers an add-on module that connects directly to the 26-pin header on the board. An available expansion board provides a standard Mini PCIe interface and SIM card slot (hmm...), but it connects to the main board via a short ribbon cable, and its mounting holes have no complement on the main board, so it seems like it would be a fragile dangly thing that's a nuisance to deal with. I want to like this board more, and it's very capable, but I'm concerned about value. The limited options for eMMC (16GB or none), the question mark of the eMMC's longevity vs cost, the strange DC power connector choice, the lack of 40-pin GPIO on a full-size (plus) board, the inconsistent hole placement, and the fragile Mini PCIe arrangement, are all "cons" that devalue this board in my view. The price point is clearly driven by the additional capabilities of the board (camera support, ports, six core CPU, extra RAM, on-board eMMC storage), but unfortunately, a great many of these features may not be useful for home automation, and therefore potentially a waste of money. In terms of overall value, I still believe the Libre "Le Potato" seems a better choice to me, and the Orange Pi Zero 2 (very) a close second, but I'll admit I'm focused on a particular application and your needs may be better suited to what this board offers than mine. Passmark Results: OrangePi 4 LTS Cortex-A72 (aarch64) 6 cores @ 1200 MHz | 2.9 GiB RAM Number of Processes: 6 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------- CPU Mark: 583 Integer Math 12037 Million Operations/s Floating Point Math 2542 Million Operations/s Prime Numbers 4.5 Million Primes/s Sorting 3141 Thousand Strings/s Encryption 153 MB/s Compression 4049 KB/s CPU Single Threaded 154 Million Operations/s Physics 80.5 Frames/s Extended Instructions (NEON) 244 Million Matrices/s Memory Mark: 498 Database Operations 551 Thousand Operations/s Memory Read Cached 2524 MB/s Memory Read Uncached 2602 MB/s Memory Write 3182 MB/s Available RAM 1947 Megabytes Memory Latency 119 Nanoseconds Memory Threaded 6243 MB/s --------------- eMMC storage write 311MB/s average for 4GB; MicroSD (Samsung 32GB class 10) storage write 15MB/s.
SBC
SBC
SBC
For comparison to other processors mentioned recently and in future: Configuration: RPi 4B (maker board) 8GB RAM running Raspbian Bullseye Raspberry Pi 4 Model B Rev 1.5 Cortex-A72 (aarch64) 4 cores @ 1800 MHz | 7.6 GiB RAM Number of Processes: 4 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------- CPU Mark: 619 Integer Math 11693 Million Operations/s Floating Point Math 4524 Million Operations/s Prime Numbers 3.1 Million Primes/s Sorting 3474 Thousand Strings/s Encryption 78.1 MB/s Compression 8676 KB/s CPU Single Threaded 479 Million Operations/s Physics 73.6 Frames/s Extended Instructions (NEON) 781 Million Matrices/s Memory Mark: 706 Database Operations 610 Thousand Operations/s Memory Read Cached 5942 MB/s Memory Read Uncached 3811 MB/s Memory Write 2900 MB/s Available RAM 6783 Megabytes Memory Latency 94 Nanoseconds Memory Threaded 3812 MB/s -------------------------------------------------------------------------- Configuration: Raspberry Pi 4 Compute Module Rev. 1.0 1GB RAM Raspbian Bullseye Note the difference in clock speed between the Compute Module and maker board! Raspberry Pi Compute Module 4 Rev 1.0 Cortex-A72 (aarch64) 4 cores @ 1500 MHz | 909 MiB RAM Number of Processes: 4 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------- CPU Mark: 520 Integer Math 9745 Million Operations/s Floating Point Math 3769 Million Operations/s Prime Numbers 3.2 Million Primes/s Sorting 3283 Thousand Strings/s Encryption 64.1 MB/s Compression 7155 KB/s CPU Single Threaded 402 Million Operations/s Physics 74.9 Frames/s Extended Instructions (NEON) 651 Million Matrices/s Memory Mark: 528 Database Operations 222 Thousand Operations/s Memory Read Cached 5269 MB/s Memory Read Uncached 4651 MB/s Memory Write 2911 MB/s Available RAM 794 Megabytes Memory Latency 97 Nanoseconds Memory Threaded 4659 MB/s --------------------------------------------------------------------------
SBC
SBC
SBC
Jetson Nano
SBC
Inconsistent
propheadP
SBC
RPi 2
SBC
Portable pi power
propheadP
SBC
PSA upgrade your Pi’s to ssd
propheadP
SBC
6 Posts 3 Posters 4.6k Views 3 Watching
      PassMark Performance Test result:
      Cortex-A53 (aarch64)
      4 cores @ 1512 MHz  |  1.9 GiB RAM
      CPU Mark:                          430
        Integer Math                     9262 Million Operations/s
        Floating Point Math              994 Million Operations/s
        Prime Numbers                    3.4 Million Primes/s
        Sorting                          2643 Thousand Strings/s
        Encryption                       125 MB/s
        Compression                      3064 KB/s
        CPU Single Threaded              204 Million Operations/s
        Physics                          61.7 Frames/s
        Extended Instructions (NEON)     170 Million Matrices/s
      Memory Mark:                       459
        Database Operations              438 Thousand Operations/s
        Memory Read Cached               2822 MB/s
        Memory Read Uncached             2243 MB/s
        Memory Write                     3592 MB/s
        Available RAM                    1079 Megabytes
        Memory Latency                   124 Nanoseconds
        Memory Threaded                  5116 MB/s
        CPU Mark:                          430
          Encryption                       125 MB/s
        Memory Mark:                       459
        Was looking at running PassMark on a RasPi 4 to get a general reference against the other PCBs being trialed as possible replacements for the RasPi:
        Downloaded PassMark from RasPi 64 bit OS from PassMark. I'm using the 64 bit OS.
        Put the executable "pt_linux_arm64" into /bin/user and changed the permissions to 0755.
        Run the executable and get:
        pt_linux_arm64: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
        Download page for PassMark Linux says "ncurses 5, newer distributions with ncurses 6 will need to install the ncurses 5 library for compatability ".
        So I do this but it installs ver 6 not 5:
         sudo apt-get install libncurses5-dev
        Any ideas on how I get PassMark to work? I thought it would be useful to post the results here.
          Have you tried installing lib64ncurses5-dev or libncursesw5 ?
            Going OT here a bit... I just posted benchmarks for RPi 4 maker board and Compute Module
              UPDATE — JANUARY 2026
              Since this Libre Le Potato board is still a good lower-cost alternative to RPis (especially for running Reactor), I pulled it out and did an update on the OS (Ubuntu 22.04.1). It had been in storage since I wrote the first post in November 2022, so it was... ahem... a little behind.
              My first attempt at apt update semi-failed because a signature for one repository had changed, so that had to be fixed (easy):
              wget https://deb.libre.computer/repo/pool/main/libr/libretech-keyring/libretech-keyring_2024.05.19_all.deb
              dpkg -i libretech-keyring_2024.05.19_all.deb
              From there, I was able to update the OS as usual. After the update, Ubuntu offered an upgrade to the current 24.04.3 LTS release. In the interest of science, I went for it (do-release-upgrade). That went less well. The system came up, but without networking and ssh access. I had to fix that with a locally-connected HDMI monitor and keyboard by adding (as root) a /etc/netplan/01-netcfg.yaml file as follows:
              network:
                version: 2
                renderer: networkd
                ethernets:
                  end0:
                    dhcp4: true
              Then run (still in a shell as root) netplan apply to bring the network up (you should be able to ping something at that point), and then systemctl enable ssh to re-enable sshd at startup. I then rebooted the unit, and all was well and it was ssh accessible.
              I then upgraded nodejs to the current v24 LTS, and ran Reactor, no problem.
              As of this writing, the price of this board at that large, well-known online retailer is around US$45. A heatsink for the CPU may be needed.
              An upgraded/newer Sweet Potato model AML-S905X-CC-V2 runs about US$60 (with 2GB RAM). Same CPU; changes include heatsink now included/installed, DDR4 RAM, UEFI BIOS, USB C power input (5V/3A), support for a PoE hat, and an eMMC 5.x SM interface. A 16GB eMMC (flash disk) 5.x module is available (same source) for around US$10. Direct OS support includes Debian 13 and Ubuntu 24.04 LTS).
              Since eMMC 5.x modules are available for the Sweet Potato, I highly recommend it (I wasn't able to find a seller of eMMC 4.x modules compatible with the older Le Potato at this point). MicroSD cards are notoriously failure prone (they're not up to the sustained, frequent writes of general purpose OSs). The NAND flash will do much better and likely be faster. Alternately, you could use an overlay filesystem. Maybe I'll write a post about that separately, if anyone wants to know.
                165.6k
