  3. SBC
  4. RPi Alternative: ESPRESSObin V7
SBC
The last of four boards I'm trying in this batch is the Orange Pi 4 LTS. I purchased a 3GB RAM + 16GB eMMC model from Amazon for $83, making it the most costly of the four boards tried, but still well under my US$100 limit. This board is powered by a Rockchip RK3399-T processor, ARM-compatible with dual Cortex-A72 cores and quad Cortex-A53 cores at 1.6Ghz (1.8Ghz for the 4GB model); compare this to the RPi 3B+ with four Cortex-A53 and the RPi 4B with four Cortex-A72, this board is a hybrid that I would expect to stand in the performance middle between the two RPi models. It's available in 3GB and 4GB DDR4 RAM configurations, with and without 16GB eMMC storage. It has a MicroSDHC slot, gigabit Ethernet, WiFi and BT, two USB 2.0 type A ports, one USB 3.0 type C port, a mini PCIe ribbon-cable connector (requires add-on board for standard connector), two each RPi-compatible camera and LCD ports, HDMI type A, and can be powered (5VDC/3A) via USB-C or DC type C (3.8mm OD/1.1mm ID) jack (center-positive), an odd and perhaps unwelcome departure from the more common type A (5.5mm/2.1mm). A serial port for console/debug can be connected by using a (not included) USB-TTL adapter (3.3V) via pin headers like the Orange Pi Zero 2. The included dual-band antenna connects via U.FL connector to the board, so it's easy substituting for another if you prefer. The manufacturer recommends use of a heat sink (which was included in the box). A metal cooling case is also offered by the manufacturer (a bundle with the metal case and a power supply is sold on Amazon for $90 as of this writing). The Orange Pi 4 LTS is somewhat longer than the RPi 4B, and although the boards are the same width, the mounting hole placement is different both in length and (oddly) width. Between this and the differences in connector locations, neither board is a drop-in replacecment for the other and their respective cases are not interchangeable. The 26-pin header is a subset of the RPi 4B's 40-pin header, so some HATs for the RPi may work (although the mounting hole differences will make securing them "interesting"), and some HATs will surely not. Models with eMMC storage have an OS installed and boot immediately with SSH daemon running and ready for login. Mine was running Debian Bullseye, which would probably be fine for most users. It had clearly been on there a while, because it needed a lot of updates, but it's a current distro, so you're running out of the box with something that will last. A different OS can be installed by downloading an image (once again I chose Ubuntu Jammy) and writing it to a MicroSD card, then booting the system from the SD card. You can either leave the system in that state (running the OS from the SD card), or copy the OS from the SD card to the eMMC. The latter is done by a script; documentation for the process is best described in the downloadable PDF User Manual. This took about 10 minutes and went smoothly, and I was able to boot the system without the SD card after the process completed. I have lingering questions around the value of the eMMC storage. It's definitely faster than using MicroSD or USB-based storage (I got 311MB/s average on a 4GB write, compared to MicroSD performance around 15MB/s), but it would take a long-term test of this product to determine if the on-board eMMC option has the stamina to take the write counts typical of Linux systems, and if its wear-leveling and error correction are sufficient to assure a long, error-free life. Given the high premium apparently being paid for including eMMC on the board, it should be fast and durable, but only time and experience (perhaps painful) would tell the latter. A careful configuration with other Flash-friendly filesystems could be used to reduce wear, but this is an advanced configuration/cookbook topic and beyond the scope of this writing. This question is also not unique to eMMC — MicroSD cards are also known to fail with high write cycles, so the use of a "high endurance" product is recommended for any and all systems using MicroSD as primary storage. The board has Mini PCIe capability, and that may be a storage alternative, but read on... Also bear in mind that the eMMC storage is fixed-size forever; it cannot be expanded, and 16GB can run out pretty quickly these days. Users of MicroSD cards for primary storage can upgrade to bigger cards, but when users of eMMC primary storage outgrow it, the only choice is to add a MicroSD card or other "external" storage to the system, move part of the filesystem to it, and then manage both storage devices and deal with the limitations and risks of both. As I mentioned with the Orange Pi Zero 2, if you are going to use this board as a home automation controller/gateway or similar role, it should (IMO) have a battery-backed real time clock (RTC), and Orange Pi offers an add-on module that connects directly to the 26-pin header on the board. An available expansion board provides a standard Mini PCIe interface and SIM card slot (hmm...), but it connects to the main board via a short ribbon cable, and its mounting holes have no complement on the main board, so it seems like it would be a fragile dangly thing that's a nuisance to deal with. I want to like this board more, and it's very capable, but I'm concerned about value. The limited options for eMMC (16GB or none), the question mark of the eMMC's longevity vs cost, the strange DC power connector choice, the lack of 40-pin GPIO on a full-size (plus) board, the inconsistent hole placement, and the fragile Mini PCIe arrangement, are all "cons" that devalue this board in my view. The price point is clearly driven by the additional capabilities of the board (camera support, ports, six core CPU, extra RAM, on-board eMMC storage), but unfortunately, a great many of these features may not be useful for home automation, and therefore potentially a waste of money. In terms of overall value, I still believe the Libre "Le Potato" seems a better choice to me, and the Orange Pi Zero 2 (very) a close second, but I'll admit I'm focused on a particular application and your needs may be better suited to what this board offers than mine. Passmark Results: OrangePi 4 LTS Cortex-A72 (aarch64) 6 cores @ 1200 MHz | 2.9 GiB RAM Number of Processes: 6 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------- CPU Mark: 583 Integer Math 12037 Million Operations/s Floating Point Math 2542 Million Operations/s Prime Numbers 4.5 Million Primes/s Sorting 3141 Thousand Strings/s Encryption 153 MB/s Compression 4049 KB/s CPU Single Threaded 154 Million Operations/s Physics 80.5 Frames/s Extended Instructions (NEON) 244 Million Matrices/s Memory Mark: 498 Database Operations 551 Thousand Operations/s Memory Read Cached 2524 MB/s Memory Read Uncached 2602 MB/s Memory Write 3182 MB/s Available RAM 1947 Megabytes Memory Latency 119 Nanoseconds Memory Threaded 6243 MB/s --------------- eMMC storage write 311MB/s average for 4GB; MicroSD (Samsung 32GB class 10) storage write 15MB/s.
SBC
SBC
SBC
For comparison to other processors mentioned recently and in future: Configuration: RPi 4B (maker board) 8GB RAM running Raspbian Bullseye Raspberry Pi 4 Model B Rev 1.5 Cortex-A72 (aarch64) 4 cores @ 1800 MHz | 7.6 GiB RAM Number of Processes: 4 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------- CPU Mark: 619 Integer Math 11693 Million Operations/s Floating Point Math 4524 Million Operations/s Prime Numbers 3.1 Million Primes/s Sorting 3474 Thousand Strings/s Encryption 78.1 MB/s Compression 8676 KB/s CPU Single Threaded 479 Million Operations/s Physics 73.6 Frames/s Extended Instructions (NEON) 781 Million Matrices/s Memory Mark: 706 Database Operations 610 Thousand Operations/s Memory Read Cached 5942 MB/s Memory Read Uncached 3811 MB/s Memory Write 2900 MB/s Available RAM 6783 Megabytes Memory Latency 94 Nanoseconds Memory Threaded 3812 MB/s -------------------------------------------------------------------------- Configuration: Raspberry Pi 4 Compute Module Rev. 1.0 1GB RAM Raspbian Bullseye Note the difference in clock speed between the Compute Module and maker board! Raspberry Pi Compute Module 4 Rev 1.0 Cortex-A72 (aarch64) 4 cores @ 1500 MHz | 909 MiB RAM Number of Processes: 4 | Test Iterations: 1 | Test Duration: Medium -------------------------------------------------------------------------- CPU Mark: 520 Integer Math 9745 Million Operations/s Floating Point Math 3769 Million Operations/s Prime Numbers 3.2 Million Primes/s Sorting 3283 Thousand Strings/s Encryption 64.1 MB/s Compression 7155 KB/s CPU Single Threaded 402 Million Operations/s Physics 74.9 Frames/s Extended Instructions (NEON) 651 Million Matrices/s Memory Mark: 528 Database Operations 222 Thousand Operations/s Memory Read Cached 5269 MB/s Memory Read Uncached 4651 MB/s Memory Write 2911 MB/s Available RAM 794 Megabytes Memory Latency 97 Nanoseconds Memory Threaded 4659 MB/s --------------------------------------------------------------------------
SBC
SBC
SBC
Jetson Nano
SBC
Inconsistent
propheadP
SBC
RPi 2
SBC
Portable pi power
propheadP
SBC
PSA upgrade your Pi’s to ssd
propheadP
SBC
3 Posts 2 Posters 2.1k Views 2 Watching
    I purchased a GlobalScale ESPRESSObin V7 with case on Amazon for US$79. In its white case, the unit is 110mm x 85mm x 35mm (about 4-1/4 x 3-3/8 x 1-3/8 inches) on its rubber feet. It looks like a small router (because it is), with three Ethernet ports and two USB ports on the "front" side, a MicroUSB connector, power jack, and slot for MicroSD card on the "back" side, and three LEDs on top. The Ethernet ports are arranged in one-WAN two-LAN (switched) configuration (again, like a small router -- it would be perfect for running pfSense). The unit requires a 12VDC power supply with the ubiquitous 5.5mm center-positive male plug. The MicroUSB connector provides a serial console to the board.
    The system has a Marvell Armada 3700LP dual core ARM Cortex-A53 processor at 1.2Ghz, so it's a little slower and has half the cores of an RPi 3B+ or my previously-reviewed Libre "Le Potato". Naturally, one can expect less performance as a result, but depending on the purpose, you may never notice.
    Getting the thing up and running has a bit of a learning curve. The installation of an OS on the chosen media is well-documented, but not all of the docs are up-to-date, and they assume a few bits of knowledge that aren't obvious if you're not a bit of a techie -- you have to set parameters in the boot firmware manually to get it to look at the right storage device and load the correct kernel, etc. I tried both OpenWRT and Ubuntu 16.04 at first. I had no trouble getting OpenWRT up and running. Ubuntu 16.04 was a different story -- it would not start up, and right as I was about to give up on it, I tried overwriting the kernel on the provided Ubuntu image with another version they had available for separate download (not in the instructions, literally just a random kernel file and three data files). I got that to boot. Unfortunately, once 16.04 was up and running, I could not run a modern version of nodejs because the core libraries are too old. I could have run older versions of nodejs, but none that are current LTS, so why bother? The purpose is to build a lasting configuration! I then decided to try to get ARMbian Jammy (22.08) running, to push on it and see how modern I could go. That turned out to be the easiest of all: I downloaded the image from the ARMbian web site and wrote it to a USB Flash drive, stuck it into the ESPRESSObin, powered it up, set the firmware boot parameters, reset the system, and it booted immediately. I then got nodejs 18.12.1 installed and Reactor up and running in a couple of minutes after.
    So it's not a quick startup like an RPi/Libre, but I attribute some of my time to the learning curve, and by the time I got to trying ARMbian, I understood better what the settings meant, and it was pretty easy to get it up and running. And once I "got" it, I also realized how bullet-proof that actually makes the thing, because you can, with sufficient know-how, get it to boot just about anything the ARM CPU will take. The serial console interface gives you a ton of useful commands, and it stays connected even when power to the board is removed -- the USB connection powers the serial interface separately, so you never lose the link to the board, even when power-cycling it.
    As expected, it's not a speed demon, but it's not bad. With the case, the form factor is good and doesn't leave you with bare connectors and spaghetti wiring, and that, for some, may be a good trade-off for a little performance. The included case incorporates a heat sink for the memory and CPU, so you don't have to worry about that, either. It has two USB ports (one 2.0, one 3.0), so in theory you could run ZWave-JS UI and/or Zigbee2MQTT on it. The only issue I had with the hardware was that the case clearance for the MicroSD slot is a little tight, so I could insert a MicroSD card, but I could not get it to "pop out" without removing the board from the case. I fixed that by adjusting the slot size (somewhat inelegantly).
    The unit I bought, which included the case, was the only ESPRESSObin configuration available on Amazon at the time, and was priced at US$79. On GlobalScale's web site, the bare board alone was priced much higher at US$99 at the time of this writing. So the Amazon package is a good value, but if you can't get it in that configuration, the benefits of the case are lost and that further devalues the ESPRESSObin, in my view.
    My verdict: the ESPRESSObin works, but overall I would not recommend it over, for example, the Libre Computer "Le Potato". I think many users will find the ESPRESSObin a bit too technical to get running, and for less than half the price, Le Potato gives you better performance and easy setup.
    Next up: Orange Pi (two models)
      Thanks for the run down - will be waiting on the next installment for the Orange Pi.
      Looks like the OS problems lets the Espresso down. Any sockets for an internal SSD or would the USB 3 socket be taken up with an external SSD?
      @toggledbits said in RPi Alternative: ESPRESSObin V7:
      Need to keep an eye on these: Some take a 2 mm central pin and others use a 2.5 mm pin.
      • A a-lurker
        @a-lurker said in RPi Alternative: ESPRESSObin V7:
        The OS issue redeemed itself pretty quickly using ARMbian, and after getting comfortable with what I was doing (I hate just typing in commands from a set of instructions), but from the perspective of documentation, I'd have to agree: GlobalScale lets itself down with dated OS images and incomplete instructions. Anyone who would not find that the ARMbian project separately publishes an up-to-date Debian/ARMbian for this board would be really disappointed and may discard or return it.
        The V7 boards have a SATA port inside. A common complaint about the case is that it leaves almost no room for any SATA drive or module. The SATA connector is vertical on the board, and indeed, the SATA modules I have would all be too tall to fit in the case without chopping a hole in it. But it's there. There's also a Mini PCIe connector, but I can't find any statement that it can be used for storage (I suspect it could, perhaps with work, as detection is more of an kernel/software issue than a hardware issue). USB 3.0 would also be an option.
        The board has provision for eMMC, and more RAM, but I don't see any models that have it. That may be something they make available when you order a custom lot.
        Indeed! This is a 2.1mm inner.
