  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 122.2k Views 6 Watching
    Ah, no, sorry. I meant specifically the announce message (first one after bridge starts up.)
    ElcidE Offline
    ElcidE Offline
    Elcid
    @akbooer
    Ok,sorry again for the image, this stupid app will not allow copy of text, I will have to look for another
      @Elcid
      OK, that's great, exactly what I needed. The latest development version v21.4.17 should have fixed this.
      ElcidE 1 Reply Last reply
        @Elcid
        ElcidE Offline
        ElcidE Offline
        Elcid
        wrote on last edited by Elcid
        #23
        @akbooer
        Have installed the latest, seems set target is working but the device does not respond and status is still 0
        The action sends and gets an OK response
          It's so hard to debug without the actual hardware. So the Shelly device itself does respond to the SetTarget, but the openLuup device doesn't update its status?
          • ElcidE Offline
            ElcidE Offline
            Elcid
            #25
            I totally understand the difficulty with out the device.
            The variable target now updates to 1 or 0 depending if switch is on or off.
            so
            device state off and icon off
            press on icon, icon flashes to on then back to off, the variable target updates to 1. Device does not respond
            press icon again this time icon stay on, variable target stays at 1 . The devices does not respond.
            press icon again this time icon stays at off, variable target updates to 0. The device does not respond.
            Status never changes form 0
            when subscribed to shellies/shelly1-93FC56/rely/0
            no messages are received when icon is pressed.
              @Elcid
              I'm trying a different approach. Please delete any Shelly-1 devices and then update to 21.4.17b. This will force each Shelly-1 to have a parent device (of generic Shelly type) and a child device (binary light). Actions on the binary light should now work as expected, but, once again, I can't easily test it myself.
              • ElcidE Offline
                ElcidE Offline
                Elcid
                #27
                Bingo. That did it the devices now have a master and a slave and respond to actions.
                Will setting the master invisible have any bad effects?
                  No, shouldn't matter at all.
                    ...or just put them in a different room.
                    • ElcidE Offline
                      ElcidE Offline
                      Elcid
                      @akbooer
                      Seems a luup reload breaks the devices, only way to get them back is to delete them and restart Mosquitto.
                      • ElcidE Elcid
                        @akbooer
                        @elcid said in openLuup: Shelly Bridge plugin:
                        Can you exapnd on that?
                        You mean that they work in the session that they are created, but do a restart and they don't work (but are still there) ??
                        • ElcidE Offline
                          ElcidE Offline
                          Elcid
                          Yes. Noticed they stopped earlier so deleted and reloaded, nothing happened untill I restarted Mosquitto. So I kept an eye on them to see if they stopped again.
                          Then about 20 mins ago I was messing with the Tasmota's, so I did a reload and after that the shelly 1 stopped working (devices still in ui). So deleted them again and restart Mosquitto and then they reloaded.
                            I'm not seeing this, but, then again, I've not bridged to Mosquitto. What happens if you just restart Mosquitto? Is there anything shown in the log?
                            • ElcidE Offline
                              ElcidE Offline
                              Elcid
                              #34
                              Restarting mosquitto this is in log
                              2021-04-17 20:59:14.986   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=687035184&Timeout=60&MinimumDelay=1500&_=1618687270165 HTTP/1.1 tcp{client}: 0xf5619c8
                              2021-04-17 20:59:21.613   openLuup.io.server:: MQTT:1884 connection closed  tcp{client}: 0xfc60a48
                              2021-04-17 20:59:21.614   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0xfc60a48
                              2021-04-17 20:59:21.616   openLuup.mqtt:: localhost.bridge-01 UNSUBSCRIBE from # tcp{client}: 0xfc60a48
                              2021-04-17 20:59:27.984   openLuup.io.server:: MQTT:1884 connection from 192.168.1.25 tcp{client}: 0xf096c288
                              2021-04-17 20:59:28.031   openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xf096c288
                              2021-04-17 20:59:28.033   luup.variable_set:: 30001.shellyix3-front.online was: EMPTY now: true #hooks:0
                              2021-04-17 20:59:28.036   luup.variable_set:: 30007.shelly1-93BEFE.online was: EMPTY now: true #hooks:0
                              2021-04-17 20:59:28.056   luup.variable_set:: 30002.shelly1-93A847.online was: EMPTY now: true #hooks:0
                              2021-04-17 20:59:28.068   luup.variable_set:: 30005.shelly1-93FC56.online was: EMPTY now: true #hooks:0
                              2021-04-17 20:59:28.384   openLuup.server:: request completed (4780 bytes, 1 chunks, 13396 ms) tcp{client}: 0xf5619c8
                              2021-04-17 20:59:28.453   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=687028312&_=1618687270166 HTTP/1.1 tcp{client}: 0xf5619c8
                              2021-04-17 20:59:28.931   openLuup.server:: request completed (766007 bytes, 48 chunks, 476 ms) tcp{client}: 0xf5619c8
                              2021-04-17 20:59:32.943   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                              2021-04-17 20:59:32.994   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=687035197&Timeout=60&MinimumDelay=1500&_=1618687270167 HTTP/1.1 tcp{client}: 0xf5619c8
                              2021-04-17 20:59:33.059   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                              2021-04-17 20:59:33.538   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                              2021-04-17 20:59:33.630   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                              2021-04-17 20:59:34.639   luup.variable_set:: 30004.shellyix3-rear.online was: EMPTY now: true #hooks:0
                              2021-04-17 20:59:34.763   openLuup.server:: request completed (3732 bytes, 1 chunks, 1767 ms) tcp{client}: 0xf5619c8
                              2021-04-17 20:59:34.813   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=687028316&_=
                              Devices still work after mosquitto restart
                              Will now reload luup and double check If this does infact cause devices to fail.
                              • ElcidE Offline
                                ElcidE Offline
                                Elcid
                                #35
                                reload luup devices have now failed
                                log
                                2021-04-17 21:04:07.840   openLuup.scheduler:: [25] BroadLink-Mk2 device startup completed: status=true, msg=All OK, name=BroadLink_Mk2
                                2021-04-17 21:04:07.841   openLuup.scheduler:: [46] Shelly device startup
                                2021-04-17 21:04:07.841   luup.set_failure:: status = 0
                                2021-04-17 21:04:07.842   luup.variable_set:: 46.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                                2021-04-17 21:04:07.843   luup.variable_set:: 46.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                                2021-04-17 21:04:07.843   openLuup.scheduler:: [46] Shelly device startup completed: status=true, msg=OK, name=ShellyBridge
                                2021-04-17 21:04:07.844   openLuup.scheduler:: [47] Tasmota device startup
                                2021-04-17 21:04:07.844   luup.set_failure:: status = 0
                                2021-04-17 21:04:07.844   luup.variable_set:: 47.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                                2021-04-17 21:04:07.845   luup.variable_set:: 47.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                                2021-04-17 21:04:07.846   openLuup.scheduler:: [47] Tasmota device startup completed: status=true, msg=OK, name=TasmotaBridge
                                2021-04-17 21:04:07.847   luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.11,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.11,[{
                                2021-04-17 21:04:21.212   openLuup.server:: request completed (835 bytes, 0 chunks, 0 ms) tcp{client}: 0xfc86dd0
                                2021-04-17 21:04:21.214   openLuup.server:: GET /luvd/D_GenericShellyDevice.xml HTTP/1.1 tcp{client}: 0xf37a830
                                2021-04-17 21:04:21.215   openLuup.server:: request completed (293 bytes, 0 chunks, 0 ms) tcp{client}: 0xf37a830
                                2021-04-17 21:04:21.217   openLuup.server:: GET /luvd/D_Reactor.xml HTTP/1.1 tcp{client}: 0xfe92080
                                2021-04-17 21:04:21.221   openLuup.server:: request completed (1156 bytes, 0 chunks, 0 ms) tcp{client}: 0xfe92080
                                2021-04-17 21:04:21.222   openLuup.server:: GET /luvd/D_ReactorSensor.xml HTTP/1.1 tcp{client}: 0xff353d8
                                2021-04-17 21:04:21.224   openLuup.server:: request completed (1572 bytes, 0 chunks, 0 ms) tcp{client}: 0xff353d8
                                2021-04-17 21:04:21.226   openLuup.server:: GET /luvd/D_DimmableRGBLight1.xml HTTP/1.1 tcp{client}: 0xfe940f8
                                2021-04-17 21:04:21.229   openLuup.server:: request completed (1507 bytes, 0 chunks, 0 ms) tcp{client}: 0xfe940f8
                                2021-04-17 21:04:21.253   openLuup.server:: GET /luvd/D_ShellyBridge.xml HTTP/1.1 tcp{client}: 0xfd25c78
                                will now restart mosquitto without deleting devices.
                                • ElcidE Offline
                                  ElcidE Offline
                                  Elcid
                                  #36
                                  Restarting mosquitto brings devices back to life.
                                  log
                                  2021-04-17 21:09:39.969   openLuup.io.server:: MQTT:1884 connection closed  tcp{client}: 0xff53448
                                  2021-04-17 21:09:39.972   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0xff53448
                                  2021-04-17 21:09:39.973   openLuup.mqtt:: localhost.bridge-01 UNSUBSCRIBE from # tcp{client}: 0xff53448
                                  2021-04-17 21:09:45.774   openLuup.io.server:: MQTT:1884 connection from 192.168.1.25 tcp{client}: 0xf527b20
                                  2021-04-17 21:09:45.823   openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xf527b20
                                  2021-04-17 21:09:45.826   luup.shelly:46: New Shelly announced: shellyix3-rear
                                  2021-04-17 21:09:45.827   luup.attr_set:: 30004.ip = 192.168.1.105
                                  2021-04-17 21:09:45.828   luup.attr_set:: 30004.mac = E8DB84D6E80A
                                  2021-04-17 21:09:45.829   luup.attr_set:: 30004.model = SHIX3-1
                                  2021-04-17 21:09:45.829   luup.attr_set:: 30004.firmware = 20210413-154502/v1.10.2-gb89901a
                                  2021-04-17 21:09:45.906   luup.shelly:46: New Shelly announced: shelly1-93A847
                                  2021-04-17 21:09:45.907   luup.attr_set:: 30002.ip = 192.168.1.102
                                  2021-04-17 21:09:45.908   luup.attr_set:: 30002.mac = BCDDC293A847
                                  2021-04-17 21:09:45.908   luup.attr_set:: 30002.model = SHSW-1
                                  2021-04-17 21:09:45.909   luup.attr_set:: 30002.firmware = 20210415-125832/v1.10.3-g23074d0
                                  2021-04-17 21:09:46.040   luup.shelly:46: New Shelly announced: shelly1-93FC56
                                  2021-04-17 21:09:46.041   luup.attr_set:: 30005.ip = 192.168.1.100
                                  2021-04-17 21:09:46.042   luup.attr_set:: 30005.mac = BCDDC293FC56
                                  2021-04-17 21:09:46.043   luup.attr_set:: 30005.model = SHSW-1
                                  2021-04-17 21:09:46.043   luup.attr_set:: 30005.firmware = 20210415-125832/v1.10.3-g23074d0
                                  2021-04-17 21:09:46.360   luup.shelly:46: New Shelly announced: shellyix3-front
                                  2021-04-17 21:09:46.361   luup.attr_set:: 30001.ip = 192.168.1.106
                                  2021-04-17 21:09:46.362   luup.attr_set:: 30001.mac = E8DB84D6C6C8
                                  2021-04-17 21:09:46.363   luup.attr_set:: 30001.model = SHIX3-1
                                  2021-04-17 21:09:46.363   luup.attr_set:: 30001.firmware = 20210413-154502/v1.10.2-gb89901a
                                  2021-04-17 21:09:51.275   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                  2021-04-17 21:09:51.594   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                  2021-04-17 21:09:51.647   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                  2021-04-17 21:09:51.936   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                  2021-04-17 21:09:54.170   luup.shelly:46: New Shelly announced: shelly1-93BEFE
                                  2021-04-17 21:09:54.171   luup.attr_set:: 30007.ip = 192.168.1.101
                                  2021-04-17 21:09:54.172   luup.attr_set:: 30007.mac = BCDDC293BEFE
                                  2021-04-17 21:09:54.172   luup.attr_set:: 30007.model = SHSW-1
                                  2021-04-17 21:09:54.173   luup.attr_set:: 30007.firmware = 20210415-125832/v1.10.3-g23074d0
                                  2021-04-17 21:10:00.117   luup_log:0: 13Mb, 0.8%cpu, 0.0days
                                    so this does seem to be something to do with bridging with Mosquitto, rather than anything else...
                                    Is it just that you've recently noticed this, or did a recent update break this, I wonder?
                                    • ElcidE Offline
                                      ElcidE Offline
                                      Elcid
                                      Did not notice as the variables in the I3's are not as easy to notice as a switch moving position
                                      i can return to previous version and check if you wish, what should i type instead of development is it 21.4.17?
                                        No, don't try that yet. I need to think rather than just react. I reboot all the time and the Shellies just keep on working.
                                        • ElcidE Offline
                                          ElcidE Offline
                                          Elcid
                                          #40
                                          I was thinking that the bridge may be starting a new clean session when open luup reconnects after a reload, maybe that's an issue.
                                            155.9k
