  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 115.1k Views 6 Watching
    #121
    Had a quick look at the Shelly pro 3em. Looks like it gets ignored at line 643:
    if not shelly: match "^shellyplus" then return end ...
    The H&T device publishes: "shellyplusht-MAC_address". However the Shelly pro 3em publishes: "shellypro3em-MAC_address". So no "plus" found. And the user can change this label in the device's web page under "MQTT prefix". I changed the prefix so it included "plus" but that didn't seem to help. EDIT: it did help - I had just plugged the "plus" in the wrong spot. See post further below.
    On the shelly-gen2-cmd/rpc topic I only see the H&T device - not the shellypro3em.
    I don't have a Gen 1 device, so I can't see what would identify one from the other. Could have a numeric value associated with each known device indicating its generation. Also the RPC communication seems to be purely Gen 2?
      #122
      My strong recommendation is not to change the default device MQTT prefix. It would just make setting up each device a total hassle. I've gone with defaults wherever possible, the only mandatory chamge being the IP address of openLuup's MQTT server.
      I hadn't appreciated that the Pro devices don't identify as "shellyplus" and I can fix that.
        Shelly firmware has changed considerably since the early versions. I should probably revisit the Gen 1 handling and make it more generic.
          "not to change the default device MQTT prefix". I always leave things at default if possible. This was just for test purposes. Below is the resulting log of the device being created with a few edits. Note that "shellypro3em" was temporarily replaced with "shellypluspro3em" in order to get some action:
          2024-03-28 13:09:35.516   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x558f264ee8
          2024-03-28 13:09:35.546   openLuup.mqtt:: shellypluspro3em-MAC_address_redacted UNSUBSCRIBE from ALL tcp{client}: 0x558f264ee8
          2024-03-28 13:09:38.357   openLuup.io.server:: MQTT:1883 connection from Shelly_IP_redacted tcp{client}: 0x5590804a28
          2024-03-28 13:09:38.392   openLuup.mqtt:: shellypro3em-MAC_address_redacted SUBSCRIBE to shellypluspro3em-MAC_address_redacted/rpc tcp{client}: 0x5590804a28
          2024-03-28 13:09:38.410   openLuup.mqtt:: shellypro3em-MAC_address_redacted SUBSCRIBE to shellypluspro3em-MAC_address_redacted/command/sys tcp{client}: 0x5590804a28
          2024-03-28 13:09:38.413   openLuup.mqtt:: shellypro3em-MAC_address_redacted SUBSCRIBE to shellypluspro3em-MAC_address_redacted/command tcp{client}: 0x5590804a28
          2024-03-28 13:09:38.425   openLuup.mqtt:: shellypro3em-MAC_address_redacted SUBSCRIBE to shellies/command tcp{client}: 0x5590804a28
          2024-03-28 13:09:38.427   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/online true
          2024-03-28 13:09:38.427   luup.register_handler:: global_function_name=Shelly_Plus_Handler, request=mqtt:shellypluspro3em-MAC_address_redacted/#
          2024-03-28 13:09:38.429   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/rpc {
            "id":"0x55902bb480",
            "method":"Shelly.GetConfig",
            "src":"shelly-gen2-cmd"
          2024-03-28 13:09:38.432   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/ble {}
          2024-03-28 13:09:38.460   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/cloud {"connected":false}
          2024-03-28 13:09:38.463   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/em:0 {
              "id": 0,
              "a_current": 0.115,
              "a_voltage": 0,
              "a_act_power": 0,
              "a_aprt_power": 0,
              "a_pf": 0,
              "a_freq": 0,
              "b_current": 0.109,
              "b_voltage": 0,
              "b_act_power": 0,
              "b_aprt_power": 0,
              "b_pf": 0,
              "b_freq": 0,
              "c_current": 0.104,
              "c_voltage": 239.7,
              "c_act_power": 0,
              "c_aprt_power": 25.2,
              "c_pf": 0,
              "c_freq": 50,
              "n_current": null,
              "total_current": 0.328,
              "total_act_power": 0,
              "total_aprt_power": 25.234,
              "user_calibrated_phase": []
          2024-03-28 13:09:38.466   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/emdata:0 {
              "id": 0,
              "a_total_act_energy": 0.04,
              "a_total_act_ret_energy": 0,
              "b_total_act_energy": 0.05,
              "b_total_act_ret_energy": 0,
              "c_total_act_energy": 0.07,
              "c_total_act_ret_energy": 0.2,
              "total_act": 0.16,
              "total_act_ret": 0.2
          2024-03-28 13:09:38.468   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/eth {"ip":null}
          2024-03-28 13:09:38.470   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/modbus {}
          2024-03-28 13:09:38.475   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/mqtt {"connected":true}
          2024-03-28 13:09:38.477   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/sys {
              "mac": "MAC_address_redacted",
              "restart_required": false,
              "time": "13:09",
              "unixtime": 1711591778,
              "uptime": 1,
              "ram_size": 240520,
              "ram_free": 121936,
              "fs_size": 524288,
              "fs_free": 192512,
              "cfg_rev": 11,
              "kvs_rev": 0,
              "schedule_rev": 0,
              "webhook_rev": 0,
              "available_updates": {},
              "reset_reason": 3
          2024-03-28 13:09:38.479   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/temperature:0 {
              "id": 0,
              "tC": 47.7,
              "tF": 117.8
          2024-03-28 13:09:38.482   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/wifi {"sta_ip":"Shelly_IP_redacted","status":"got ip","ssid":"SID_redacted","rssi":-62}
          2024-03-28 13:09:38.484   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/ws {"connected":false}
          2024-03-28 13:09:38.487   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/status/mqtt {"connected":true}
          2024-03-28 13:09:38.490   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/events/rpc {
              "src": "shellypro3em-MAC_address_redacted",
              "dst": "shellypluspro3em-MAC_address_redacted/events",
              "method": "NotifyFullStatus",
              "params": {
                  "ts": 1711591778.07,
                  "ble": {},
                  "cloud": {
                      "connected": false
                  "em:0": {
                      "id": 0,
                      "a_current": 0.115,
                      "a_voltage": 0,
                      "a_act_power": 0,
                      "a_aprt_power": 0,
                      "a_pf": 0,
                      "a_freq": 0,
                      "b_current": 0.109,
                      "b_voltage": 0,
                      "b_act_power": 0,
                      "b_aprt_power": 0,
                      "b_pf": 0,
                      "b_freq": 0,
                      "c_current": 0.104,
                      "c_voltage": 239.7,
                      "c_act_power": 0,
                      "c_pf": 0,
                      "c_freq": 50,
                      "n_current": null,
                  "emdata:0": {
                      "id": 0,
                      "total_act": 0.16,
                  "eth": {
                      "ip": null
                  "modbus": {},
                  "mqtt": {
                      "connected": true
                  "sys": {
                      "time": "13:09",
                      "uptime": 1,
                      "ram_size": 240596,
                      "ram_free": 123484,
                      "fs_size": 524288,
                      "fs_free": 192512,
                      "cfg_rev": 11,
                      "kvs_rev": 0,
                      "schedule_rev": 0,
                      "webhook_rev": 0,
                      "reset_reason": 3
                  "temperature:0": {
                      "id": 0,
                      "tC": 47.7,
                      "tF": 117.8
                  "wifi": {
                      "sta_ip": "Shelly_IP_redacted",
                      "status": "got ip",
                      "ssid": "SID_redacted",
                      "rssi": -62
                  "ws": {
                      "connected": false
          2024-03-28 13:09:38.493   luup.shelly:207: ShellyPlus: shellypluspro3em-MAC_address_redacted/events/rpc
              "method": "NotifyStatus",
              "params": {
                  "mqtt": {
                      "connected": true
          2024-03-28 13:09:38.539   luup.shelly:207: ShellyGen2: shelly-gen2-cmd/rpc {
              "id": "0x55902bb480",
              "dst": "shelly-gen2-cmd",
              "result": {
                  "ble": {
                      "enable": false,
                      "rpc": {
                          "enable": false
                      "observer": {
                          "enable": false
                  "cloud": {
                      "enable": false,
                      "server": "iot.shelly.cloud:6012/jrpc"
                  "em:0": {
                      "id": 0,
                      "name": null,
                      "blink_mode_selector": "active_energy",
                      "phase_selector": "all",
                      "monitor_phase_sequence": false,
                      "reverse": {}
                  "emdata:0": {},
                  "eth": {
                      "enable": true,
                      "ipv4mode": "dhcp",
                      "ip": null,
                      "netmask": null,
                      "gw": null,
                      "nameserver": null
                  "modbus": {
                      "enable": false
                  "mqtt": {
                      "enable": true,
                      "server": "server_IP_address_redacted:1883",
                      "client_id": "shellypro3em-MAC_address_redacted",
                      "user": null,
                      "ssl_ca": null,
                      "topic_prefix": "shellypluspro3em-MAC_address_redacted",
                      "rpc_ntf": true,
                      "status_ntf": true,
                      "use_client_cert": false,
                      "enable_rpc": true,
                      "enable_control": true
                  "sys": {
                      "device": {
                          "name": null,
                          "fw_id": "20240223-141900/1.2.2-g7c39781",
                          "discoverable": true,
                          "eco_mode": false,
                          "profile": "triphase",
                          "addon_type": null
                      "location": {
                          "tz": "redacted",
                          "lat": redacted,
                          "lon": redacted
                      "debug": {
                          "level": 2,
                          "file_level": null,
                          "mqtt": {
                              "enable": false
                          "websocket": {
                              "enable": false
                          "udp": {
                              "addr": null
                      "ui_data": {},
                      "rpc_udp": {
                          "dst_addr": null,
                          "listen_port": null
                      "sntp": {
                          "server": "time.google.com"
                      "cfg_rev": 11
                  "temperature:0": {
                      "id": 0,
                      "name": null,
                      "report_thr_C": 5,
                      "offset_C": 0
                  "wifi": {
                      "ap": {
                          "ssid": "ShellyPro3EM-MAC_address_redacted",
                          "is_open": true,
                          "enable": false,
                          "range_extender": {
                              "enable": false
                      "sta": {
                          "is_open": false,
                          "enable": true,
                          "ipv4mode": "dhcp",
                          "ip": null,
                          "netmask": null,
                          "gw": null,
                          "nameserver": null
                      "sta1": {
                          "ssid": null,
                          "is_open": true,
                          "enable": false,
                          "ipv4mode": "dhcp",
                          "ip": null,
                          "netmask": null,
                          "gw": null,
                          "nameserver": null
                      "roam": {
                          "rssi_thr": -80,
                          "interval": 60
                  "ws": {
                      "enable": false,
                      "server": null,
                      "ssl_ca": "ca.pem"
          2024-03-28 13:09:38.540   luup.shelly:207: New Shelly announced: shellypro3em-MAC_address_redacted
          2024-03-28 13:09:38.542   luup.create_device:: [30004] D_GenericShellyDevice.xml /  / D_GenericShellyDevice.json   (GenericShellyDevice)
          2024-03-28 13:09:38.542   luup.attr_set:: 30004.ip =
          2024-03-28 13:09:38.542   luup.attr_set:: 30004.mac = Shelly_IP_redacted <-- loaded with correct value
          2024-03-28 13:09:38.542   luup.attr_set:: 30004.model = shellypro3em
          2024-03-28 13:09:38.542   luup.attr_set:: 30004.firmware = 20240223-141900/1.2.2-g7c39781
          2024-03-28 13:09:38.956   openLuup.server:: request completed (6784 bytes, 1 chunks, 11054 ms) tcp{client}: 0x558fe2b248
          A few notes.
          • You have to enable "Generic status update over MQTT" in the device's web page to get things to work. Same as for the H&T device. It defaults to disabled from the factory.
          • Subscribing to "ShellyPlus: shellypluspro3em-MAC_address_redacted/events/rpc" and looking for "method": "NotifyFullStatus" results in pretty much all the information needed. Same as for the H&T device.
          • It would be nice if the log pretty printed big json blocks. Could possibly just pretty print if the json string was say greater than 40 characters?
          Here is the "method": "NotifyFullStatus" for the H&T device:
            "src": "shellyplusht-MAC_address_redacted",
            "dst": "shellyplusht-MAC_address_redacted/events",
            "params": {
              "ts": 1.47,
              "ble": {},
              "cloud": {
                "connected": false
              "devicepower:0": {
                "id": 0,
                "battery": {
                  "V": 0.43,
                  "percent": 0
                "external": {
                  "present": true
              "ht_ui": {},
              "humidity:0": {
                "id": 0,
                "rh": 50.9
              "mqtt": {
                "connected": true
              "sys": {
                "time": null,
                "unixtime": null,
                "uptime": 1,
                "ram_size": 246472,
                "ram_free": 167120,
                "fs_size": 458752,
                "fs_free": 192512,
                "cfg_rev": 15,
                "kvs_rev": 0,
                "webhook_rev": 0,
                "wakeup_reason": {
                  "boot": "deepsleep_wake",
                  "cause": "status_update"
                "wakeup_period": 600,
                "reset_reason": 8
              "temperature:0": {
                "id": 0,
                "tC": 24,
                "tF": 75.2
              "wifi": {
                "status": "got ip",
                "rssi": -68
              "ws": {
                "connected": false
          Immediately above is the "method": "NotifyFullStatus" for the H&T device.
            #125
            Could you give the latest development version a go?
            It should work without your above edits, but I haven’t customised the device yet.
            What variables does that give you?
              #126
              Using the default prefix "shellypro3em" I now get these variables. Previously there were none. See below. For the attributes I get firmware version, model number, MAC address but no IP address.
              em/0/a_act_power	0
              em/0/a_aprt_power	0
              em/0/a_current	0.028
              em/0/a_freq	0
              em/0/a_pf	0
              em/0/a_voltage	0
              em/0/b_act_power	0
              em/0/b_aprt_power	0
              em/0/b_current	0.027
              em/0/b_freq	0
              em/0/b_pf	0
              em/0/b_voltage	0
              em/0/c_act_power	0
              em/0/c_aprt_power	6.4
              em/0/c_current	0.027
              em/0/c_freq	50
              em/0/c_pf	0
              em/0/c_voltage	236.6
              em/0/id	0
              em/0/total_act_power	0
              em/0/total_aprt_power	6.409
              em/0/total_current	0.082
              em/0/user_calibrated_phase	[]
              emdata/0/a_total_act_energy	0.06
              emdata/0/a_total_act_ret_energy	0
              emdata/0/b_total_act_energy	0.06
              emdata/0/b_total_act_ret_energy	0
              emdata/0/c_total_act_energy	0.12
              emdata/0/c_total_act_ret_energy	0.38
              emdata/0/id	0
              emdata/0/total_act	0.24
              emdata/0/total_act_ret	0.38
              temperature/0/id	0
              temperature/0/tC	46.7
              temperature/0/tF	116
              Note the device does not have the current clamps connected around anything. ie it's just powered up.
                "I hadn't appreciated that the Pro devices don't identify as "shellyplus" and I can fix that." Works OK now. All the DIN rail mounted devices are "shellyproXYZ".
                  Just testing a 12V DC Shelly configuration with an RGBW driver and a i4 DC set of switches...
                  ...firmware for the switch is shown as:
                  20211101-134319/i4prod0-g2345cff-279-i4-production-bundles-2143-dirty
                  Doesn't look good!
                    I've got a few RGBW2s. See you have been working on this one. If I can help in any way, let me know.
                      ...using as RGB(W) or four separate white strips?
                        @akbooer said in openLuup: Shelly Bridge plugin:
                        I usually modify them in order to better track/debug them. No need to include shelly in the device name, when you already have to base topic.
                          #132
                          Using them as RGBW at the moment. But I can see them also being used just as white strips. Whether that would be four strips - don't think so. One strip would be enough at each location for my needs.
                          It's surprising how much current they can run through the device given its size.
                          • A a-lurker
                            Just to complicate things: in addition to the 3em pro - I've got a shelly pro em 50 turning up in the mail.
                              I’ve rationalised a lot of the ShellyBridge handling of Gen 2+ devices, so this shouldn’t be too much of an issue.
                                #135
                                I tried out the new update: "Development Branch: 2024 Release 4.5". Nothing too badly broken so that's good. I notice the H&T devices now have new variable names ie humidity/0/rh and temperature/0/tC, etc. These no longer show up in AltUI or console at Home-->Devices. Likewise with the 3em pro: em/0/a_voltage, etc
                                No doubt a work in progress but the forward slashes are a bit problematic eg they can't be part of a whisper filename.
                                  Delimiters are always a problem. I tried initially with ‘:’, but UPnP already took that. However, it’s not intended that you use these directly; they are simply transcriptions from the MQTT topics. As with other Shellies, the key variables get copied to the MiOS equivalents, possibly in child devices, so that everything works.
                                  I am making progress with the RGBW, and remember just how much I hate the way MiOS tries to handle them… and on top of that, AltUI has its own quirks.
                                    Lots of work done refactoring things - should "Eclipse" the older versions. Code still working here - thank you.
                                      Yes, thanks.
                                      BTW, "Generic status update over MQTT" should not need to be ticked, now.
                                      You will also have seen that you can use luup.openLuup.pretty() directly.
                                        Yes, thanks.
                                        #139
                                        I've got something about pretty printing here. No doubt in my writings, I have made a few errors here and there but that can happen. OK on the "Generic status update over MQTT" - I'll fix that in the paragraph immediately above here.
                                          Ah, OK, that’s great.
                                          Whilst on documentation, the bit on Quick graph view is incorrect where it says:
                                          ”Uses Google Charts, so an internet connection is required..”
                                          This used to be the case, but now it’s all local SVG, so no external connection needed.
                                            141.3k
