  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 126.9k Views 6 Watching
    @akbooer said in openLuup: MQTT server:
    I don't have any HT devices,
    ...but I do now, and I've just updated the Shelly plugin to support individual temperature and humidity child devices for each H&T, and also a battery level for the parent device.
    A bit disappointed with the quality of the H&T case, it seems inferior to the excellent Button 1 – but it's so small and innocuous that perhaps it doesn't matter. Aside from that, it's a fine little device (although I've not checked the calibration accuracy, I see that they do include a user-definable offset for both H & T readings.) If the battery lasts as well as they say, that'l be fine.
      ArcherS
      @akbooer today I added a Shelly Dimmer2 replacing a really old Fibaro dimmer that died. The Shelly dimmer seems like a nice device so far. 🙂
      It is added into OpenLuup as it should:
      The following variables are mapped:
      announce:
      {"id":"shellydimmer2-nnn","model":"SHDM-2","mac":"nnn","ip":"192.168.1.nn","new_fw":false,"fw_ver":"20210226-115010/v1.9.6-dimmer2@1873d25e"}
      light/0/status:
      {"ison":true,"source":"http","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":80}
      However no child devices are created for the dimmer. Could this be added to the Shelly bridge?
      (I am running OpenLuup v 21.8.16.)
        Yes, I don't believe that I've implemented the dimmer... I certainly haven't got one!
        I'll take a look – thanks for the excellent configuration information!
          @ArcherS
          This is going to be hard without having a dimmer. You're not in the UK, are you? I didn't really want to buy one (£22 UK price) because I have absolutely no need of one.
          Any chance that anyone has got a spare one they can send me?
          therealdbT A 2 Replies Last reply
            @ArcherS
            @akbooer I have a virtual server just to test my own integration. I think it’s a safer investment for you to validate any device you don’t have access to. The doc is pretty good and it’s not complex to replicate both http and mqtt messages in a fake implementation.
              @ArcherS
              ArcherS
              @akbooer sorry, no I am in Sweden.
              I only have one dimmer unit so far and it is in my son's room, he will not like being without ceiling lights this time of the year in our parts of the world. 🙂
                OK, so we’ll have to do this in an iterative way, with me making a few mistakes.
                  @ArcherS
                  Just for you, I’ve bought one of my own. Hasn’t arrived yet, but I’ll be right on it when it does.
                  AK
                    @ArcherS
                    AK
                    ArcherS
                    @akbooer top notch service as always! Hopefully you will get good use of it also. 🙂
                    So far I am happy with mine. The dimmer supports all kind of switches. I use it with a spring loaded wall switch in "one button mode", i.e. as a push button with push-and-hold for dimming.
                    As a side note I am still on 1.9.x on my Shellies since I did not get mqtt to work with the new firmware. On the EU Shelly support site it is very easy to set up an ota-url for flashing older versions on a device.
                      @therealdb
                      I missed your post, somehow. As you see, I’ve gone for the hardware rather than a virtual solution, but I certainly won’t be doing that for all new Shellies!
                      Any details to share on how you’ve done this?
                        @therealdb
                        @akbooer I just wrote a super simple http server replying the same way Shelly devices are doing. Plus, I send mqtt messages every x secs to my dev mqtt broker, to replicate the same behavior. I was using this while developing the support for mqtt inside my own system.
                        I’ve done the same way for opensprinkler, in order to avoid messing with my sprinklers.
                        It’s done in C#, but it should be easy with anything else.
                        • B Offline
                          B Offline
                          Buxton
                          @akbooer is there any chance on you decoupling the tasmota and shelly bridges from openLuup. I'm asking because if the bridges were stand alone plugins, they could be used as quasi templates for other MQTT devices. For example, my BlueIris server MQTT messaging now maps to individual Vera devices that represent BlueIris cameras (created with the Tasmota bridge), but the functionality of each vera device is limited, due to the way in which the tasmota bridge creates its child devices. With a stand alone plugin, I could revise a clone of the plugin to include more specific functionality for a given MQTT source.
                          Everything MQTT wise works well now, so no real need to do this, but it strikes me that it would be a cleaner approach to handling MQTT in openLuup and the myriad IOT devices that will make use of the protocol.
                            They're closely coupled so that they can auto-install if any of their devices are detected, rather than having to download a bridge plugin separately. As such, I consider them to be an integral part of the system (a change, certainly, from my previous device-agnostic approach, but part of my personal move away from ZWave.)
                            The MQTT bridge functionality is totally general, and I would have thought that this was a better place to start.
                            ...or am I missing your point, here?
                            B 1 Reply Last reply
                            • A ArcherS
                              @archers said in openLuup: Shelly Bridge plugin:
                              Well, we'll see (the device arrived yesterday)...
                              Latest development version of openLuup (v21.11.2) has an initial attempt to service the Dimmer2 device:
                              • inputs are handled exactly as the switch device – so, essentially, as a scene controller showing the latest activated scene: short press; long press; etc... This should work for both input switches (if you have any with two.)
                              • on/off button on the control panel should work for the dimmer bulb.
                              • slider control is not yet implemented.
                              ...my current issue is that, although I now have the Shelly Dimmer2 device, I don't have any dimmable bulbs! Everything I have is LED, and they're either non-dimmable or smart devices anyway. In particular, I can't tell whether the power and Watts parameters work correctly for the dimmer.
                              So I'd appreciate a listing of any bugs that you find, and I'll continue to work on the slider control.
                              Incidentally, I've update to the latest firmware for this device: 20210909-150154/v1.11.4-DNSfix-ge6b2f6d since it came with a very old version that didn't even publish the model number. It seems to work fine, but I've not updated any other of my devices.
                                B Offline
                                B Offline
                                Buxton
                                @akbooer It's just easier to understand the code/ what's occurring in a plugin as opposed to openLuup, mainly because of the typical plugin structure and its place on top of the openLuup subsystem. That's probably a trivial distinction to you, but for me it's a huge difference in understanding as I'm not in any way fluent with the inside baseball of the OLuup object model.
                                Per your MQTT comment, though it can be done (https://github.com/jziolkowski/tdm), it would be difficult to have functional device bridges if you took away MQTT, as you'd have to interrogate a router in some fashion to find out if these devices exist on one's network, and then use http commands to control the devices. So I see MQTT handling as more an innate part of the OL subsystem, like http, than a device profile like tasmota or shelly, device profiles that are typically handled as stand alone plugins.
                                  ArcherS
                                  @akbooer said in openLuup: Shelly Bridge plugin:
                                  @akbooer thank you for the effort, I installed v21.11.2 and have tested this a bit. 🙂
                                  For a start I have my switch connected to "sw 1". It is a single button switch, defined as a "one button mode" in the Shelly GUI.
                                  "sw 1" seems to report as "light/0" in the Mqtt message.
                                  It does not work fully in OpenLuup yet, below I list what I have found.
                                  Turning on/off with the physical switch:
                                  • The status in AltUI does change when turning the light on and off.
                                  • When I turn the light "off" with the physical switch I have:
                                    light/0:
                                    off
                                    light/0/status: {"ison":false,"source":"input","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":80}
                                  • When I turn the light "on" with the physical switch (at 80%) I have:
                                    light/0:
                                    on
                                    light/0/status:
                                    {"ison":true,"source":"input","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":80}
                                  Turning the light on/off in AltUI:
                                  • The light does not turn on/off when I turn it on/off in AltUI.
                                  • When I turn it "on" in AltUI I have:
                                    light/0:
                                    off
                                    light/0/status:
                                    relay/0/command:
                                    on
                                  • When I turn it "off" in AltUI I have:
                                    light/0:
                                    off
                                    light/0/status:
                                    relay/0/command:
                                    off
                                  When I turn it "on" in AltUI it looks like this:
                                  When I turn on the light with the physical switch it looks like this:
                                  In Mqtt Explorer I have the following:
                                  Light on (i.e. turned on with the physical switch):
                                  Light off (i.e. turned off with the physical switch):
                                  Turning on in AltUI (but light off):
                                  Turning off in AltUI (light still off):
                                  The "relay/0/command" command that is sent from AltUI does in other words not to give any effect on the Shelly device. In fact with a fresh Mqtt Explorer session it only emerges when turning on/off in AltUI.
                                  Hopefully this gives some hints to what is wrong. Let me know if you need more information.
                                  Dimmable LED lights are a bit tricky still. Some of them work and some of then do not work very well. It can be a bit of a pain to find good ones. The upside is that the Shelly dimmer can be changed from trailing and leading edge dimming (under "Calibration"). This should hopefully mean that it can be a little bit better to adapt to different lights.
                                  Excellent news that the latest FW seems to work, I will test it later on one of my devices. 🙂
                                    More than enough to be going on with! Brilliant. Thanks.
                                      #78
                                      @ArcherS
                                      Can you give latest development (v21.11.8) a try?
                                      I don't think I'm quite there yet, but the dimmer control should work to some extent.
                                      This is surprisingly hard, since the status/control aspect of the Shelly dimmer is not quite the same as that of a ZWave one... I've always hated the way that Vera handled dimmers anyway! But I'm doing the best I can.
                                        @ArcherS
                                        ArcherS
                                        I installed v21.11.8 and now it almost seem to work. 🙂
                                        In short what is not entirely in place is that the dimmer slider on the AltUI desktop in some cases does not follow the set value.
                                        Example:
                                        When I change the dim value in the Shelly GUI it updates in OpenLuup inside the dimmer but the slider on the desktop does not update.
                                        Starting with the dimmer off and all sliders on 1% and then dim to 40% on the Shelly GUI gives:
                                        In the Shelly GUI:
                                        On the desktop in AltUI:
                                        Inside the dimmer controller in AltUI:
                                        Variables:
                                        light/0/status:
                                        {"ison":true,"source":"http","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":40}
                                        If I instead change the dim value from AltUI either from inside the dimmer controller or from the desktop it works and everything is updated. Also the slider inside the AltUI dimmer seems to work as it should.
                                        Based on your input I tested the latest fw (v1.11.4) on a Shelly Plug and it does indeed seem to work with Mqtt. Great news that it actually works now.
                                          Yes, that’s really weird, isn’t it?
                                          I must try harder…
                                            163.6k
