Updated doco here.
Hope it works - YMMV.
Hey guys....
long time 😉
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
Hi akbooer,
tnks
donato
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
I totally understand the difficulty with out the device.
The variable target now updates to 1 or 0 depending if switch is on or off.
so
device state off and icon off
press on icon, icon flashes to on then back to off, the variable target updates to 1. Device does not respond
press icon again this time icon stay on, variable target stays at 1 . The devices does not respond.
press icon again this time icon stays at off, variable target updates to 0. The device does not respond.Status never changes form 0
when subscribed to shellies/shelly1-93FC56/rely/0
no messages are received when icon is pressed. -
@Elcid
I'm trying a different approach. Please delete any Shelly-1 devices and then update to 21.4.17b. This will force each Shelly-1 to have a parent device (of generic Shelly type) and a child device (binary light). Actions on the binary light should now work as expected, but, once again, I can't easily test it myself. -
Yes. Noticed they stopped earlier so deleted and reloaded, nothing happened untill I restarted Mosquitto. So I kept an eye on them to see if they stopped again.
Then about 20 mins ago I was messing with the Tasmota's, so I did a reload and after that the shelly 1 stopped working (devices still in ui). So deleted them again and restart Mosquitto and then they reloaded.
Restarting mosquitto this is in log
2021-04-17 20:59:14.986 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=687035184&Timeout=60&MinimumDelay=1500&_=1618687270165 HTTP/1.1 tcp{client}: 0xf5619c8 2021-04-17 20:59:21.613 openLuup.io.server:: MQTT:1884 connection closed tcp{client}: 0xfc60a48 2021-04-17 20:59:21.614 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0xfc60a48 2021-04-17 20:59:21.616 openLuup.mqtt:: localhost.bridge-01 UNSUBSCRIBE from # tcp{client}: 0xfc60a48 2021-04-17 20:59:27.984 openLuup.io.server:: MQTT:1884 connection from 192.168.1.25 tcp{client}: 0xf096c288 2021-04-17 20:59:28.031 openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xf096c288 2021-04-17 20:59:28.033 luup.variable_set:: 30001.shellyix3-front.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.036 luup.variable_set:: 30007.shelly1-93BEFE.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.056 luup.variable_set:: 30002.shelly1-93A847.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.068 luup.variable_set:: 30005.shelly1-93FC56.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.384 openLuup.server:: request completed (4780 bytes, 1 chunks, 13396 ms) tcp{client}: 0xf5619c8 2021-04-17 20:59:28.453 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=687028312&_=1618687270166 HTTP/1.1 tcp{client}: 0xf5619c8 2021-04-17 20:59:28.931 openLuup.server:: request completed (766007 bytes, 48 chunks, 476 ms) tcp{client}: 0xf5619c8 2021-04-17 20:59:32.943 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:32.994 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=687035197&Timeout=60&MinimumDelay=1500&_=1618687270167 HTTP/1.1 tcp{client}: 0xf5619c8 2021-04-17 20:59:33.059 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:33.538 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:33.630 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:34.639 luup.variable_set:: 30004.shellyix3-rear.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:34.763 openLuup.server:: request completed (3732 bytes, 1 chunks, 1767 ms) tcp{client}: 0xf5619c8 2021-04-17 20:59:34.813 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=687028316&_=
Devices still work after mosquitto restart
Will now reload luup and double check If this does infact cause devices to fail.
reload luup devices have now failed
log2021-04-17 21:04:07.840 openLuup.scheduler:: [25] BroadLink-Mk2 device startup completed: status=true, msg=All OK, name=BroadLink_Mk2 2021-04-17 21:04:07.841 openLuup.scheduler:: [46] Shelly device startup 2021-04-17 21:04:07.841 luup.set_failure:: status = 0 2021-04-17 21:04:07.842 luup.variable_set:: 46.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.843 luup.variable_set:: 46.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.843 openLuup.scheduler:: [46] Shelly device startup completed: status=true, msg=OK, name=ShellyBridge 2021-04-17 21:04:07.844 openLuup.scheduler:: [47] Tasmota device startup 2021-04-17 21:04:07.844 luup.set_failure:: status = 0 2021-04-17 21:04:07.844 luup.variable_set:: 47.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.845 luup.variable_set:: 47.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.846 openLuup.scheduler:: [47] Tasmota device startup completed: status=true, msg=OK, name=TasmotaBridge 2021-04-17 21:04:07.847 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.11,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.11,[{
2021-04-17 21:04:21.212 openLuup.server:: request completed (835 bytes, 0 chunks, 0 ms) tcp{client}: 0xfc86dd0 2021-04-17 21:04:21.214 openLuup.server:: GET /luvd/D_GenericShellyDevice.xml HTTP/1.1 tcp{client}: 0xf37a830 2021-04-17 21:04:21.215 openLuup.server:: request completed (293 bytes, 0 chunks, 0 ms) tcp{client}: 0xf37a830 2021-04-17 21:04:21.217 openLuup.server:: GET /luvd/D_Reactor.xml HTTP/1.1 tcp{client}: 0xfe92080 2021-04-17 21:04:21.221 openLuup.server:: request completed (1156 bytes, 0 chunks, 0 ms) tcp{client}: 0xfe92080 2021-04-17 21:04:21.222 openLuup.server:: GET /luvd/D_ReactorSensor.xml HTTP/1.1 tcp{client}: 0xff353d8 2021-04-17 21:04:21.224 openLuup.server:: request completed (1572 bytes, 0 chunks, 0 ms) tcp{client}: 0xff353d8 2021-04-17 21:04:21.226 openLuup.server:: GET /luvd/D_DimmableRGBLight1.xml HTTP/1.1 tcp{client}: 0xfe940f8 2021-04-17 21:04:21.229 openLuup.server:: request completed (1507 bytes, 0 chunks, 0 ms) tcp{client}: 0xfe940f8 2021-04-17 21:04:21.253 openLuup.server:: GET /luvd/D_ShellyBridge.xml HTTP/1.1 tcp{client}: 0xfd25c78
will now restart mosquitto without deleting devices.
