Updated doco here.
Hope it works - YMMV.
Hey guys....
long time 😉
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
Hi akbooer,
tnks
donato
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
Try v21.4.18 to see if the plug now works (it will create a separate child device.)
@akbooer all set now for shelly plug!
EDIT: I think category_num and subcategory_num should be set to at least 3/0, so the UI could filter them better.
So, the recommendation for Shelly 1 PM used as detached relay (input separated from relay) is to manually use the variables?
Good news on the plug. I haven't yet considered setting the (sub)category automatically, but it should be easy enough.
For any Shelly with switches, the generic device has the raw variables but also they're treated as a scene controller, so you have
sl_SceneActivated
andLastSceneTime
available to you. -
@akbooer I have a Shelly Plug (not the "S" variant) that I now finally setup on my test Pi to try the Shelly bridge.
The plug shows as it should in the Shellies room:
The following variables are mapped:
The payload is:
{"id":"shellyplug-6CC126","model":"SHPLG2-1","mac":"xxx","ip":"192.168.1.30","new_fw":false,"fw_ver":"20201124-092420/v1.9.0@57ac4ad8"}
However no child devices show up for the plug what I can see.
Is this something that can be added to the bridge, or have I missed anything in my setup?(running OpenLuup v 21.4.18)
@akbooer now on to my second Shelly, a Shelly Uni.
Same thing here, I assume, no child devices are created some mapping is required.
(For my Uni I have the two relays connected to two relays reading two states from the alarm, and no buttons connected to control the two inputs. In other words in my application I do not really need the input child devices.)The temperature gets mapped correctly.
The two "relay" variables are the outputs for each channel are also as they should from what I can see.Payload:
{"id":"shellyuni-483FDA82C252","model":"SHUNI-1","mac":"xxx","ip":"192.168.1.31","new_fw":false,"fw_ver":"20201124-093042/v1.9.0@57ac4ad8"}
I think the "input" variables are the two buttons that you can control as a user that need child devices.
If I remember it correctly @therealdb also has a Uni if you need more input from a second use case.
@archers said in openLuup: Shelly Bridge plugin:
I literally have bought anything from them, but I've not fully deployed every device. I'm still waiting for my Uni and EM to be inserted. the EMs will soon monitor my AC, so I could detect if it's running or not (I have to use two switchbots to turn it on/off, because it's still under warranty and I could not mess with the original thermostat).
All that said, I'm voting for automatic creation of child temp/humidity sensors, and for Uni to create relays and inputs separately. That's what most people will do, anyway.
@therealdb said in openLuup: Shelly Bridge plugin:
@therealdb I still have an EM that I will setup over time to monitor the consumption of the spa and the HVAC.
I also have a few more Shellies inbound in the mail; some Shelly 1's, a few 1PMs and a Button1. The plan is to replace a few aeging Aeotec relays that do not behave properly with the 1PMs.
The Button1 I plan to use instead of a really old Zwave.me wall controller.All that said, I'm voting for automatic creation of child temp/humidity sensors, and for Uni to create relays and inputs separately. That's what most people will do, anyway.
I can second the thought on autocreation of temp/humidity and relay/input for the Uni if it is feasible to maintain. However not being a developer I am happy with what I get!
The native Shelly and Tasmota support in OpenLuup together with the Mqtt support is a huge and really cool addition to the platform!
@akbooer said in openLuup: Shelly Bridge plugin:
Yup, done that too. OK if you can get used to the 2 second delay (unless on USB power.)
I have now included the Button1 and it works ok, it added without problems in OpenLuup. No child devices, but I assume that is the way it should be.
I think I will keep it attached to USB power. I have power available where the button is located and this gives more or less instant actions. I also noticed that if it is not on USB in some cases it does not connect as it should when going out of sleep when you push the button.
I assume that wifi is not the best technology for battery powered devices.
So far I am using a direct action from the button to the 1PM that it should control. -
No, not really. That’s what Zwave and Zigbee were supposed to be about. But I have to say that in terms of all the HA technology I’ve had (X10 / Zwave / Zigbee) it all pales into insignificance compared to Shellies and WiFi – especially in terms of setup and the fact that you don’t need a controller at all.
yep, I've them inside my cars, so USB powered. It will takes about 3-4 seconds at boot for them to jon the WiFi network and send an MQTT message. My use case is not normal and I'll probably swap them with nodemcu devices in the future, but overall for 10 eur battery included I'm very satisfied.
I'll install Shellies into my sister-in-law house this year, because they really want home control and not home automation, and Shelly is the least overkill solution to this problem. No hub required for very basic automation is not bad, for "normal" users.
@akbooer said in openLuup: MQTT server:
I don't have any HT devices,
...but I do now, and I've just updated the Shelly plugin to support individual temperature and humidity child devices for each H&T, and also a battery level for the parent device.
A bit disappointed with the quality of the H&T case, it seems inferior to the excellent Button 1 – but it's so small and innocuous that perhaps it doesn't matter. Aside from that, it's a fine little device (although I've not checked the calibration accuracy, I see that they do include a user-definable offset for both H & T readings.) If the battery lasts as well as they say, that'l be fine.
@akbooer today I added a Shelly Dimmer2 replacing a really old Fibaro dimmer that died. The Shelly dimmer seems like a nice device so far.
It is added into OpenLuup as it should:
announce:
{"id":"shellydimmer2-nnn","model":"SHDM-2","mac":"nnn","ip":"192.168.1.nn","new_fw":false,"fw_ver":"20210226-115010/v1.9.6-dimmer2@1873d25e"}
light/0/status:
{"ison":true,"source":"http","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":80}
However no child devices are created for the dimmer. Could this be added to the Shelly bridge?
(I am running OpenLuup v 21.8.16.)
@akbooer I have a virtual server just to test my own integration. I think it’s a safer investment for you to validate any device you don’t have access to. The doc is pretty good and it’s not complex to replicate both http and mqtt messages in a fake implementation.
