Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Synology Docker installation
Seems like everything is correct. The log timestamps are always UTC. The master timer tick log entry looks correct for about the time of your posting and the time zone you show set below.
I was not able to import entities from Ezlo Plus and I was thinking about a problem between time zone and access token.
Now I have also ezlo entities imported ok but only after putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call.In all this ways nothing:
config:username: "somebody" # put your username here betw quotes password: "????????" # and password
then config
set_anonymous_access: true <--- add this line, same indent as previous
then with
“offlineInsecureAccess” enabled:true
the log was:
2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" } 2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-04T00:08:25.667Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure 2021-08-04T00:08:25.669Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled! 2021-08-04T00:08:25.696Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-04T00:08:25.743Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/ 2021-08-04T00:08:25.743Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate 2021-08-04T00:08:25.744Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/ 2021-08-04T00:08:25.750Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-04T00:08:25.856Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub... 2021-08-04T00:08:25.905Z <Controller:ERR> EzloController#ezlo stopping; hub's offline insecure access is disabled, and cloud auth info is not configured 2021-08-04T00:08:25.906Z <Controller:ERR> EzloController#ezlo failed to complete inventory: Error: hub offline anonymous access is disabled, and cloud auth info is not configured 2021-08-04T00:08:25.907Z <Controller:CRIT> Error: hub offline anonymous access is disabled, and cloud auth info is not configured Error: hub offline anonymous access is disabled, and cloud auth info is not configured at /opt/reactor/server/lib/EzloController.js:895:27 at processTicksAndRejections (internal/process/task_queues.js:95:5) 2021-08-04T00:08:25.915Z <Controller:NOTICE> EzloController#ezlo websocket closing, 1002
After putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call, all entities are imported OK. The problem was hub.offline.insecure_access . This is now the log:
2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" } 2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-04T01:01:18.593Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure 2021-08-04T01:01:18.596Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled! 2021-08-04T01:01:18.626Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-04T01:01:18.675Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/ 2021-08-04T01:01:18.675Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate 2021-08-04T01:01:18.677Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/ 2021-08-04T01:01:18.682Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-04T01:01:18.790Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub... 2021-08-04T01:01:18.896Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items. 2021-08-04T01:01:18.897Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 105ms 2021-08-04T01:01:18.897Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-04T01:01:19.152Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via , fi", "color": "006e45", "latitude": "437930", "longitude": "11210", "name": "testi, fi", "status": --null-- } ] }) for user 1520131, user not in user list 2021-08-04T01:01:20.388Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online. 2021-08-04T01:01:22.993Z <VeraController:NOTICE> Controller VeraController#vera is now online.
OK. So first, you need to learn to post code correctly on this site so I can actually see what you're posting. Any code that you post here (including config and log snippets) should have ``` on a line by itself both before and after.
Please repost your controller config, from the
- id:
line to the end of the section, just XXX out your username and password. It looks like your config isn't (and wasn't to start) correctly set up. -
thanks for your advice.
Now seems I'm able to import entities from EzloPlus and to access token.
I put the ezlo plus again with previous API set and did some test againmodel: "h2.1" offlineAnonymousAccess: false offlineInsecureAccess: false serial: "90000XXX"
in config
controllers: - id: vera enabled: true implementation: VeraController name: My Vera Lite Hub config: source: 'http://10.0.4.44:3480' - id: ezlo enabled: true implementation: EzloController name: My Ezlo Hub config: source: "wss://10.0.4.119:17000" # change the IP address serial: "90000xxx" # put your hub's serial # here username: "xxx" # put your username here betw quotes password: "xxx" # and password
in the log:
2021-08-05T18:00:23.085Z <app:null> Reactor "1.0.0-21200-16a604f" starting on v14.17.3 2021-08-05T18:00:23.086Z <app:INFO> Process ID 1; platform linux/x64 #41890 SMP Thu Jul 15 03:37:40 CST 2021 2021-08-05T18:00:23.086Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage 2021-08-05T18:00:23.131Z <Plugin:null> Module Plugin v21173 2021-08-05T18:00:23.138Z <default:INFO> Module Entity v21177 2021-08-05T18:00:23.141Z <Controller:null> Module Controller v21191 2021-08-05T18:00:23.141Z <default:null> Module Structure v21196 2021-08-05T18:00:23.148Z <default:null> Module Ruleset v21096 2021-08-05T18:00:23.148Z <default:null> Module Rulesets v21096 2021-08-05T18:00:23.166Z <default:null> Module Rule v21168 2021-08-05T18:00:23.173Z <default:null> Module Engine v21197 2021-08-05T18:00:23.173Z <default:null> Module httpapi v21197 2021-08-05T18:00:23.175Z <default:null> Module httpproxy v21054 2021-08-05T18:00:23.187Z <default:null> Module wsapi v21196 2021-08-05T18:00:23.212Z <app:NOTICE> Starting Structure... 2021-08-05T18:00:23.216Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping 2021-08-05T18:00:23.217Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController) 2021-08-05T18:00:23.221Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController) 2021-08-05T18:00:23.222Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController) 2021-08-05T18:00:23.223Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-08-05T18:00:23.265Z <default:null> Module VeraController v21195 2021-08-05T18:00:23.269Z <default:null> Module EzloController v21199 2021-08-05T18:00:23.272Z <default:null> Module OWMWeatherController v21140 2021-08-05T18:00:23.273Z <default:null> Module SystemController v21102 2021-08-05T18:00:23.277Z <VeraController:NOTICE> VeraController#vera starting 2021-08-05T18:00:23.326Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice 2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000xxx", "username": "xxx", "password": "xxx" } 2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-05T18:00:23.360Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure 2021-08-05T18:00:23.362Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-05T18:00:23.458Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-05T18:00:23.505Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-05T18:00:23.945Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via xxx, xxx", "color": "006e45", "latitude": "43xxx", "longitude": "11xxx", "name": "xxx, xxx", "status": --null-- } ] }) for user 1520131, user not in user list 2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired) 2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo opening local hub connection to "90000464" at wss://10.0.4.119:17000 2021-08-05T18:00:25.771Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("90000464") certificate 2021-08-05T18:00:25.772Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000 2021-08-05T18:00:25.886Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory 2021-08-05T18:00:25.969Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items. 2021-08-05T18:00:25.970Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 83ms 2021-08-05T18:00:25.972Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-05T18:00:27.923Z <VeraController:NOTICE> Controller VeraController#vera is now online. 2021-08-05T18:00:33.533Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online. 2021-08-05T18:00:33.534Z <app:NOTICE> Starting Reaction Engine... 2021-08-05T18:00:33.535Z <Engine:INFO> Reaction Engine starting 2021-08-05T18:00:33.535Z <Engine:INFO> Checking rule sets... 2021-08-05T18:00:33.537Z <Engine:INFO> Checking rules... 2021-08-05T18:00:33.537Z <Engine:INFO> Data check complete; no corrections. 2021-08-05T18:00:33.539Z <Engine:5:Engine.js:1081> _process_reaction_queue() entry 628 2021-08-05T18:00:33.540Z <Engine:NOTICE> Reaction Engine running! 2021-08-05T18:00:33.540Z <app:NOTICE> Starting HTTP server and API... 2021-08-05T18:00:33.545Z <app:NOTICE> Startup complete 2021-08-05T18:00:33.546Z <Engine:5:Engine.js:1144> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting 2021-08-05T18:00:33.548Z <httpapi:NOTICE> HTTP API v1 21197 base URL http://10.0.4.71:8111; listening 2021-08-05T18:00:33.568Z <app:NOTICE> HTTP server running; registering proxy endpoints. 2021-08-05T18:00:33.568Z <app:NOTICE> Starting WSAPI... 2021-08-05T18:00:33.569Z <wsapi:NOTICE> wsapi: starting version 21196 2021-08-05T18:00:33.639Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 8:00:33 PM" (TZ offset 120 mins from UTC) 2021-08-05T18:00:35.984Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:00:36.874Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:08:33.852Z <wsapi:INFO> client "172.17.0.1#2" closed, code=1001, reason= 2021-08-05T18:08:34.228Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:35:24.207Z <wsapi:INFO> client "172.17.0.1#3" closed, code=1006, reason= 2021-08-05T18:35:24.208Z <wsapi:INFO> client "172.17.0.1#1" closed, code=1006, reason= 2021-08-05T18:49:28.209Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:49:38.215Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T19:00:05.004Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 9:00:05 PM" (TZ offset 120 mins from UTC)
and the dashboard is so fluid and immediate! I love it!
just to ask, Is there Importing ReactorSensors from Vera Reactor in synology docker method?
@noelab said in Synology Docker installation:
So far as I know, the answer is "Yes" - because that's a built-in feature of MSR, and not dependent on the platform on which it is installed.
Coincidentally, I never used the "Import" feature despite having dozens of rather involved Rules back on Reactor for Vera. My reasoning was, (a) I will likely build them better from scratch, (b) this is my chance to re-think a lot of my logic, and (c) with MSR being immensely more powerful, it was a good excuse to learn lexpjs and contribute (as I wound up doing far more than anticipated) to the bug/suggestion log along the way.
MSR 1.0.0 is a masterpiece. Hope you enjoy the transition.
@librasun yes, of course I agree with you. In Vera I based my logic using a virtual dimmer (Switchboard Plugin) per room to interact with Alexa commands behind conditions/rules in a Reactorsensor per room and only some global reactor for the house. In this way it is possible to have until 100 voice commands per room associated to 100 preset rules per dimmer, controlling them in web gui, in mobile app or alexa. So at the moment trying to understand if there is a new approach in MSR to emulate virtual devices or to find another way.
OK. Now that you have a successful cloud authentication, you can enable anonymous access if you wish on the hub using the procedure described here:
Getting Rid of the Ezlo Cloud Login Requirement
Follow the directions carefully -- they will guide you through telling MSR to set the hub flags for you, and then how to reconfigure MSR so that it stops using cloud authentication for access. Also read the warning about the risks of using anonymous access. The risks of not using it are also described; only you can judge which is the right path for you.
For the record, I'm using "Hyper Backup" - a native Synology NAS app - to backup my entire /REACTOR folder structure to a folder in my Google Drive cloud account. Suggest other MSR users consider doing something similar, in the event of a local NAS drive malfunction.
