  4. Updated to latest MSR 21243 and no entities are being executed I Hubitat
47 Posts 6 Posters 16.5k Views 6 Watching
    Matteburk
    ok... what does that line do?
    got this
    pi@raspberrypi:~ $ sudo systemctl enable reactor
    Created symlink /etc/systemd/system/multi-user.target.wants/reactor.service \u2192 /etc/systemd/system/reactor.service.
    pi@raspberrypi:~ $
      That's better. OK, no more command line. Do this as well:
      This will tell systemd to start Reactor at boot (which you should then test). If you have any other mechanism for starting Reactor at boot (e.g. modified .profile or bashrc files), then those will need to be removed/disabled.
      @toggledbits said in Updated to latest MSR 21243 and no entities are being executed I Hubitat:
      M 1 Reply Last reply
        Matteburk
        ok.... I cut the power and restarted the pie and msr got up by it self!!
        Coool!
          Noice! OK. You're on your way! NOW we're finished! 🙂
            Matteburk
            Big thanx again Patrick!
            Keep up the good work!!
            Now bedtime in Sweden!
            /Mattias
              @matteburk could check this post, although you probably have some other issue
              @tunnus said in Updated to latest MSR 21243 and no entities are being executed I Hubitat:
              Well, it turned out you had the same issue
                May I say to you all - thank you!
                I undertook the mini-project of migrating MSR from SD card to SSD. Full transparency, I'm not a Linux guy in any way/shape/form so there was a good deal of feeling my way thru the dark. Once I got it moved and running (honestly, on the first try!) I wanted the next logical step of start/restart at boot. Was really fumbling until I found this thread - it was better than any tutorial I'd been using.
                Success is mine: on the SSD and with everything starting at boot like desired.
                Thanks @Matteburk for making mistakes similar to mine and to @toggledbits for his INFINITE patience and guidance. (The app -p thing was actually a question I had after seeing an earlier screenshot in the thread and having removed it only to meet failure nose-to-nose.)
                *Hubitat C-7 2.5.1.142
                Core 2026.7.4
                MSR: latest-26193-8dd8f854
                  146.3k
