  4. [SOLVED] Will Pulse work for retrying a ruleset if the device hasn't responded as expected
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
26 Posts 2 Posters 8.8k Views 2 Watching
  • toggledbitsT Online
    toggledbitsT Online
    They can -- it depends on when their respective conditions get them rolling...
      @toggledbits Before heading off to sleep the house slips into "night" mode. One stat, the upstairs one, did not change to night temp so I came in to watch the correction happen.
      It didn't. No sustained for timers rolling, nothing.
      I moved the Sustained for 300s back down to the next group level, that of the Up and Down t-stat level and the sustained for timer showed up. #win
      When I hit reset the rule state for Arm for Heating started its sustained for timer as expected. So did the timer for down which makes sense because it is the stat that didn't come along.
      And then when the 300 seconds ran out... nothing. Nothing happened. Even the highest level pulse didn't... pulse.
      Up is still wrong and nothing looks like it's running to correct it. I'm wondering if moving the pulse to the top-most level isn't working. I can't see why not - but I don't know why the sustained for timers didn't go at one level higher, either.
      Update: those moves didn't help, when the timers ran out the AND Upstairs for at least 300 secs [or] bar blinked and... no reaction ran.
        toggledbitsT Online
        Stats is in AND mode, so both Upstairs and Downstairs need to be true at the same time. Is that intended?
          @toggledbits Wow, great catch. There's also another error in this one where statmode and setpoints should be AND, not OR. I think this got bolluxed when I started moving groups into groups into groups.
          Quick review of the other rulesets and I see a couple more of these here and there including one that I was trying to test/troubleshoot just this morning.
          Nice catch - appreciate it! Now I'll validate these work again and then, one by one, make the pulse and sustained for edits back up to higher levels.
            toggledbitsT Online
            #25
            Remember to give those status lines a good hard squiz. I still don't understand your logic completely, but when you said you expected pulses to be rolling, and the top interior group was not true while an interior group was true (and that was correct/expected, as you also pointed out), that was the clue to make me ask about the operation on the group. Follow your groups up from where they are as expected to where they are not, and check those operators! 🙂
              @toggledbits I'm marking this as solved because I watched a couple of the rulesets WIA this morning as the day's temps ramped up.
              Thanks for your incite and guidance as always, sir!
              • G gwp1 referenced this topic on
                164.2k
