Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
[solved] Ordering of global expressions
@toggledbits before edit & after save
Wait... wut? That makes no sense. Let's try this again. Open the JavaScript console. Go into the Global Expressions editor. Move something to another position, then hit Save. Then report if any errors were logged.
I'm getting a slightly different effect with Expressions, under latest-21292-ac02d68, namely when I visit my list of existing Globals and drag one to the top of the list, then click SAVE and go visit elsewhere in the UI... upon returning to Expressions, that item now appears at the very bottom of the list. I haven't watched for browser errors in the monitor yet, just wanted to report this anomaly.
UPDATE: More generally, even if I drag an existing expression anywhere in the ordered list, and click SAVE, the topmost item seems always to hop to the bottom of the list. Grabbed these screen shots to illustrate:
BEFORE (after dragging 'sun' to the 2nd position from top)
AFTER (following SAVE, leaving 'Expressions' then returning)
At that point, 'Timestamp' had been bumped to the bottom of the list.
OK. @LibraSun 's description was a bit more concise, so I was able to find that issue. Next build tomorrow.
@toggledbits I’m good at finding bugs, but bad at explaining them
@librasun looks like you have some interesting expressions, like this one at the timestamp
Can you share the full screen for us to look at? And of course use good ideas
And your last comment is very good, we can find each other, but to reproduce and explain is another story
Just a note, @LibraSun 's timeStamp expression was necessary before the addition of
strftime()
to the function catalog. -
@toggledbits said in Ordering of global expressions:
strftime()
Master sorry for the ignorance of your apprentice, can't this strftime() function be used this way?
I am getting an error.
@wmarcolin Grasshopper, the arguments for
strftime()
are described in the reading thus:strftime( format_string [, time ] )
— Formats time to a human-readable form controlled byformat_string
. Iftime
is not given or null, the current time is used.It should be clear from this that the first argument is to be a string containing the formatting codes. A string is a sequence of characters enclosed in quotes. You are missing the quotes.
@toggledbits just to confirm/check, that this fix (on ordering of expressions) is included in 21294?
Yes, it is.
@toggledbits can confirm that the fix is working (tested with 21297)
