Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
Lua - Code to encrypt / decrypt with AES 128 CBC
Thanks @toggledbits
I’ve been playing around with OpenSSL a little this morning, I’ve, not had much success so far., based on the source code, it looks like i need to encrypt the generated
payload
with the createdkey
andiv
using aes 128 cbc.. Does that sound right to you.. (Looking at OpenSSL guide, it seems pretty comprehensive and complex.- https://www.openssl.org/docs/man1.1.1/man1/openssl-enc.html )Here’s my code so far, any thoughts/suggestions welcome..
local name = "openssl" local version = "version" local data="1234" local key="\\S„ßÍ}/Ìa4!" local hmac_key="¹jz¹2¸F\r}òcžÎ„ 臧.ª˜¹=¤µæŸ" local iv=" {¬£áæ‚2žâ3ÐÞË€ú " local payload = "0000000000001234" --local buildsslcommand1 = name .." "..version --local buildsslcommand2 = "openssl aes-128-cbc -e -a -K hex-"..key.." -iv hex-"..iv.."[-in xxx]" --local buildsslcommand3 = "openssl enc -aes-128-cbc -iv "..iv.." -k "..key.." | hexdump -C" local buildsslcommand = "openssl enc -aes-128-cbc -nosalt -e -a -A "..payload.." -K "..key.." -iv "..iv print("Command to send = " ..buildsslcommand) local file = assert(io.popen(buildsslcommand, 'r')) local output = file:read('*all') file:close() print(string.len(output)) --> just count what's returned. print(output) -- > Prints the output of the command.
Practice on the command line and don't worry about the Lua until you know how the command works and what you need to give it.
Your key and IV have to be hex, so that's your first challenge. The command will want to read stdin if you don't specify
-in <file>
; you can't put the payload on the command line directly. Plus it contains binary data, so that's a non-starter. So at a minimum you're going to be writing the payload to a temporary file and encrypting that with-in
. OpenSSL can write the encrypted output to stdout (it will if you don't specify-out <file>
), which is good because you can read that directly when usingio.popen()
, so that part's going to be OK. -
Thanks @toggledbits ,
To make the key and iv hex, could I use binascii.lua (https://github.com/tst2005/binascii/blob/master/binascii.lua) ?
—Converts a string of bytes to a hexadecimal string local function hexlify(s) local a = {} for i=1,#s do local c = s:sub(i,i) local byte = c:byte() a[#a+1] = ('%02X'):format(byte) end return table.concat(a) end
As for the OpenSSL command line structure, I’ve come across a number of different examples online - this one seems to relate to what you’re suggesting (I’d just need to change it to 128, rather than 256)
openssl enc -aes-256-cbc -nosalt -e -a -A -in input.dat -K '7c07f68ea8494b2f8b9fea297119350d78708afa69c1c76' -iv 'FEDCBA987654321' -out input-test.enc
QQ : You mentioned that I’m going to need to write the payload to a temp file and encrypt it with
-in
?How does
-in
do any encryption?In the OpenSSL manual it just says the following about -in and -out
-in filename The input filename, standard input by default. -out filename The output filename, standard output by default.
@parkerc said in Lua - Code to encrypt / decrypt with AES 128 CBC:
QQ : You mentioned that I’m going to need to write the payload to a temp file and encrypt it with -in?
You need to use
-in
on the encryption command to tell it to read from a file. You didn't have-in
in your previous example, you just put the payload on the command line, and that doesn't work.The hex conversion doesn't need two steps for the byte conversion and math for target array position:
-- Converts a string of bytes to a hexadecimal string local function hexlify(s) local a = {} for i=1,#s do a[i] = ('%02X'):format( s:byte( i ) ) end return table.concat(a) end
Ok, not sure how far I’ve progressed with this, but hopefully I’m getting somewhere ??
Here are the values created earlier..
local key= "\\S„ßÍ}/Ìa4!" local iv = "{¬£áæ‚2žâ3ÐÞË€ú" local payload = "0000000000001234"
I’ve put the payload value into a file..
local file = "etc/payload.txt" local outf = io.open(file, "w") outf:write(payload) outf:close()
Then created Hex values of the key and iv
local function hexlify(s) local a = {} for i=1,#s do a[i] = ('%02X'):format( s:byte( i ) ) end return table.concat(a) end print(hexlify(key)) print(hexlify(iv))
keyHEX = "5C53E2809EC39FC38D7D191E2FC38C1D61057F3421"
ivHEX = "7BC2ACC2A3C3A1C3A6E2809A32C5BEC3A233C390C39EC38BE282ACC3BA"Then I’ve taken those new hex values and accessed the command line of vera to run the following openssl command I created…
openssl enc -aes-128-cbc -nosalt -e -a -A -in etc/payload.txt -K '5C53E2809EC39FC38D7D191E2FC38C1D61057F3421' -iv '7BC2ACC2A3C3A1C3A6E2809A32C5BEC3A233C390C39EC38BE282ACC3BA' -out etc/payload2.txt
The above resulted in etc/payload2.txt being created, however it's empty and the command line returns the following messages.
hex string is too long
invalid hex iv valueOther than checking how the initial key and I’ve values are created again, is there anything else I need to look into/check ?
Those initial values for key and IV being binary data in strings could be a problem. Your editor may be wrecking them because it thinks they are Unicode, or they've already been wrecked along the way by other means. Both are supposed to be 16 bytes, and you've got 29 for IV and 21 for the key, so something has definitely gone wrong, and Unicode/UTF-8 encoding and decoding in the file handling is a prime suspect.
Fortunately, the IV doesn't really matter, I think. You could just use the first 16 bytes of the payload for testing. But it's supposed to be a 16-byte (128 bit) nonce, used only one time with the key (so if you encrypt something else with the same key, you should use a different IV). Maybe just generate 16 random bytes and call it good, but make sure to seed the random number generator, otherwise it generates the same 16 "random" numbers after every restart (that's a feature, actually, but you have to remember to seed in production to get away from it).
And really, probably the key doesn't matter either. You need both the key and IV to encrypt and decrypt, so it's not like you are dealing with a known key from another system like a remote API (unless they are doing this all wrong and using the same key and IV for every payload--that would be an... error). Pick 16 bytes and go to town!
patrick@drupal:/tmp$ echo "I am a secret message." > in.txt patrick@drupal:/tmp$ cat in.txt I am a secret message. # Encrypt patrick@drupal:/tmp$ openssl aes-128-cbc -e -a -in in.txt -K '9988227744aaff003388ffccee1188ff' -iv '112233445566778899aabbccddeeff00' -out out.txt patrick@drupal:/tmp$ cat out.txt MQi9QVm1/R3dvZncbX0nQeRqlf0+2oFcMuW/vp0FQ2Q= # Now decrypt patrick@drupal:/tmp$ openssl aes-128-cbc -d -a -in out.txt -K '9988227744aaff003388ffccee1188ff' -iv '112233445566778899aabbccddeeff00' I am a secret message.
Thanks @toggledbits
I think you’re right about the Lua/Luup editor wrecking the format of the values being generated, plus I’m perhaps not helping matters by working on various parts of the overall code separately ; so I have been copying things over.
FYI - You can see how the generated values are stored/presented differently (one image is via a print screen using LuaView and the other is writing them as new variables into Vera)
I’m going to try and do as much as I can using the Vera written values, as ultimately that’s where my target for where this code will need to eventually run..
OK, yeah, so big problem, you cannot store binary data in state variables. That is going to fail, 100%. State variables are character strings, and assumed to contain character data, and when they are stored, they are put through UTF-8 encoding and decoding. Your binary data is going to look like Unicode characters to the innards of Luup throwing this stuff around, and anything that isn't a valid codepoint is going to get changed to something else (and boom, data corrupted), while converting it to JSON to store on flash and back, etc.
Store everything in hex or base64.
What would I do without you
Ok, so I can still write to a device variable in Vera, I’d just need to encode it first , in either one of those two options. e.g like this if base64?
local function base64_encode(data) local b='ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/' return ((data:gsub('.', function(x) local r,b='',x:byte() for i=8,1,-1 do r=r..(b%2^i-b%2^(i-1)>0 and '1' or '0') end return r; end)..'0000'):gsub('%d%d%d?%d?%d?%d?', function(x) if (#x < 6) then return '' end local c=0 for i=1,6 do c=c+(x:sub(i,i)=='1' and 2^(6-i) or 0) end return b:sub(c+1,c+1) end)..({ '', '==', '=' })[#data%3+1]) end local key = string.char(unpack(key_vals)) - - local keyEnc = base64_encode(key) luup.variable_set("urn:nodecentral-net:serviceId:NodeCentral1","key",keyEnc, 1187)
It's easier than that in Luup...
local mime = require("mime") local encoded = mime.b64( "Hello world!" ); local decoded = mime.unb64( encoded ); luup.log( decoded, 2 )
Awesome, thanks - I often forget what’s already there in luup.. !
Also am I right in saying that i only need to enc/dec in hex or base64 if I’m planning to store (read/write) those values/variables, if I can keep them ‘active; and flowing within the code itself (in memory) then, I’m ok ?
Yes, in memory is fine. So for example, you may generate IV from random numbers byte by byte, put it through
b64
orhex
before storing it on a state variable. Foropenssl
, you'll be giving key and IV in hex, so that seems a sensible way to keep it. Once it's converted to hex, you'll never need to reverse that, since it can be stored in a state variable as hex, and can be handed directly toopenssl
as hex. -
This time round, I seem to have generated some new hex values this time, which I’ve used in a io.popen openssl command, feels a bit better, but sadly not quite yet right (yet).. FYI
openssl enc -aes-128-cbc -nosalt -e -a -A -in etc/payload.txt -K 'enNIQi9wNmYxd1RDUXMvNHJhdHNGZz09' -iv 'B6B1919A88C696AE87A692B1BBADCE9B' -out etc/payload2.txt non-hex digit invalid hex key value
Well the key you show is definitely not hex, because 16 bytes of hex should be 32 characters long with only 0-9, A-F. Looks like you have base64 for the key, not hex.
Progress at last ! well I’ve at least got the key and iv in the correct hex format for the OpenSSL aes cbc encryption command to work.🥳
Which leads me on to the next part, where the output of the above is referred to as the ciphertext;, of which I now need to do the following with..
ciphertext = MyopensslAEScbcCall() sig = encdec.hmacsha256(ciphertext, hmac_key, true) encrypted_payload = encdec.base64enc(ciphertext .. sig) return encrypted_payload
hmacsha256
seems to be next, and it might also be something I could do with OpenSSL too ? -> https://unix.stackexchange.com/questions/610039/how-to-do-hmacsha256-using-openssl-from-terminal ?I also found this too - https://github.com/jqqqi/Lua-HMAC-SHA256/blob/master/sha256.lua
@toggledbits any suggestions/recommendations on what to do with this next part ?
I would stick with OpenSSL. You just need to assemble the correct bits (HMAC key and ciphertext) to send to the hash function, compute the hash, then append the hash to the ciphertext. The trick here will be that you currently have the AES encyption outputting its result base64-encoded... you can't append the signature to that. You need the ciphertext output in binary for that, so you need to remove the
-a
(and-A
) to let the output be binary. Then you can put that into the hash. And then you can take the (binary) hash output and append that to the binary ciphertext, and then you base64 encode the assembled result at the very end. The whole thing takes a few steps. I would recommend writing a shell script to do all the steps, and just have Lua run the shell script. You can then more easily develop and test the steps (because they are all in the shell script and runnable from the command line). -
Thanks @toggledbits - I struggle enough with Lua, so i admire your optimism in thinking I could create a shell script too
I must admit, I can’t help but feel like I’m making this more complicated that it needs to be, especially as there are working Lua and Python scripts already out there, which seem to be doing everything natively (although I do admit much of this thread is trying to plug holes in Vera )
With that said, the following might help you understand the bigger picture of what I’m trying to replicate, and maybe help me more, as I found some related posts, the first one which uses python e.g. https://github.com/florianholzapfel/panasonic-viera/issues/9 - and I’ve extracted the related HMAC part below.
… # Let's encrypt it with AES-CBC! We need to make sure we pad it to a multiple of 16 bytes beforehand aes = AES.new(key, AES.MODE_CBC, iv) ciphertext = aes.encrypt(pad(payload)) # Calculate the HMAC-SHA-256 signature of our encrypted payload sig = hmac.new(hmac_key, ciphertext, hashlib.sha256).digest() # Concatenate the HMAC signature to the encrypted payload and base64 encode it, and we're done! encrypted_payload = base64.b64encode(ciphertext + sig)
Plus there’s this pure Lua version called Haslib -> https://github.com/howmanysmall/Rewrites/blob/master/src/HashLib.lua - which looks like it might be promising to add to Vera as a module ?
USAGE: Input data should be a string Result (SHA digest) is returned in hexadecimal representation as a string of lowercase hex digits. Simplest usage example: local HashLib = require(script.HashLib) local your_hash = HashLib.sha256("your string")
Looking at the functions within the latter HashLib.lua file, it has one called
local function hmac(hash_func, key, message)
which makes me wonder could i use that and do the following.. ?local HashLib = require(script.HashLib) local mySig = HashLib.hmac(sha256, ciphertext, hmac_key)
Approach however you want, it's yours to choose, of course. I can just recommend (and you asked). My experience is that snatching random code snippets from Github can be hit or miss, and if it's a miss, it will take longer to find because of your implicit trust of "working" code by others. OpenSSL is widely-used and well-known. It is, for practical purposes, a reference standard. If you find "good code" on Github and it turns out it isn't, it will likely be a long time before you figure it out, because you'll trust it, even though you should not. And in this scenario, with so much computation, and in so many steps, it's all a black box and debugging any piece of it will be extremely challenging. You'll post here when it doesn't work and I and anyone else won't be able to help you, because we can verify it either. Using a known-good tool, even if you struggle to get to know it, will give you a more reliable result, because then you are only fighting with your handling of the inputs and outputs and getting the steps right and in the right order. You should use the best tools possible to minimize the number of variables in the equation. Once you know how it all works, you see it all hang together, and you've got some "sand in your pants" as they say, then you can start replacing with other things, if necessary.
The other issue is that no Lua implementation, of crypto in particular, which can be very complex and iterative, is going to be more efficient than the C/C++-based, optimized implementation of OpenSSL. That matters on the weak CPUs we are working with.
At a minimum, you should get your procedure working on the command line, with all the steps and a full cycle of encode and decode with a couple of different payloads. Once you have that, you have something (known inputs and known outputs/results) you can use to test Lua replacements, because you have known benchmarks to compare to. If you don't know what a particular input will produce on the output, you will never know if any piece of code you find is correct or not.
Thanks so much @toggledbits for your open and honest feedback, I really appreciate it. Taking your advice I’m going to persist with OpenSSL to get this next encrypted payload step done.
How does this set of next steps look to you ..?
Step 1, Adjust the OpenSSL ciphertext aes-cbc command, so it outputs in binary (do this by removing the -a (and -A) parameters ).
Step 2, When it comes to the hmac_key , it looks like it created in the following way, and as I can’t see any hex or base64 references, onlybit
- is it already using the right binary format ?local bit = require("bit") local binascii = require("binascii") function createHMACKey() local iv_vals = { iv:byte(1, -1) } local hmac_key_mask = binascii.unhexlify('15C95AC2B08AA7EB4E228F811E34D04FA54BA7DCAC9879FA8ACDA3FC244F3854') local hmac_key_mask_vals = { hmac_key_mask:byte(1, -1) } local hmac_vals = {} for i = 1, 32, 4 do hmac_vals[ i ] = bit.bxor(hmac_key_mask_vals[ i ], iv_vals[ bit.band(i + 1, 0xF) + 1 ]) hmac_vals[ i + 1 ] = bit.bxor(hmac_key_mask_vals[ i + 1 ], iv_vals[ bit.band(i + 2, 0xF) + 1 ]) hmac_vals[ i + 2 ] = bit.bxor(hmac_key_mask_vals[ i + 2 ], iv_vals[ bit.band(i - 1, 0xF) + 1 ]) hmac_vals[ i + 3 ] = bit.bxor(hmac_key_mask_vals[ i + 3 ], iv_vals[ bit.band(i, 0xF) + 1 ]) end local hmac_key = string.char(unpack(hmac_vals)) print(hmac_key) return hmac_key end createHMACKey()
Step 3. Use openSSL to encrypt the binary ciphertext and binary hmac_key with hmacsha256 to create the
sig
(signature)
Step 4. Then using mime.base64, encrypt the ciphertext with the new singnature to create thepayload
Hi @toggledbits
If/when you have time , I’d really appreciate some further help..
Quick reminder of my current goal, which is to convert the following 3 steps, so an equivalent can run on Vera.
One..
aes_cbc, err = aes:new(key, nil, aes.cipher(128, 'cbc'), { iv = iv }, nil, 1) ciphertext = aes_cbc:encrypt(payload)
Two..
Three..
@toggledbits said in Lua - Code to encrypt / decrypt with AES 128 CBC:
You make it sound so easy, I’d love to get this to work..
Looking at the guide (https://linux.die.net/man/1/openssl ) I’m trying to see how the command results in a the output being base64 encoded ?
opensslAES128command = "openssl enc -aes-128-cbc -nosalt -e -a -A -in etc/payload.txt -K "..key.." -iv "..iv.." -out etc/payload2.txt"
The above command output this....
gGBjfMi+lMGhQYdhjy1UWuRCtY1WIE07CmQ5aW/jITDYbe8I01QxtYfXzkpk4km8
-a
(and-A
) to let the output be binary.I also tried the above command, without both the -a -A options and it returns this…
€`c|Ⱦ”Á¡A‡a-TZäBµV M; d9ioã!0ØmïÓT1µ‡×ÎJdâI¼
is this binary ?
Next when you say
hash
do you mean the second part, the encdec.hmacsha256 piece ? If so what exactly am I hashing ? Are (ciphertext, hmac_key, true) all concatenation into one long string ? Like this maybe ?openssl dgst -sha256 -hmac $(<etc/my ciphertext,-hmac_key.txt) etc/hmacoutput.txt
With mime.b64 I think, I’m good on the last step ..
Totally agree I just need to ensure I have right ones ?
