  3. Lua - Code to encrypt / decrypt with AES 128 CBC
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
27 Posts 3 Posters 19.0k Views 3 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Thanks @toggledbits
    I think you’re right about the Lua/Luup editor wrecking the format of the values being generated, plus I’m perhaps not helping matters by working on various parts of the overall code separately ; so I have been copying things over.
    FYI - You can see how the generated values are stored/presented differently (one image is via a print screen using LuaView and the other is writing them as new variables into Vera)
    I’m going to try and do as much as I can using the Vera written values, as ultimately that’s where my target for where this code will need to eventually run..
      OK, yeah, so big problem, you cannot store binary data in state variables. That is going to fail, 100%. State variables are character strings, and assumed to contain character data, and when they are stored, they are put through UTF-8 encoding and decoding. Your binary data is going to look like Unicode characters to the innards of Luup throwing this stuff around, and anything that isn't a valid codepoint is going to get changed to something else (and boom, data corrupted), while converting it to JSON to store on flash and back, etc.
      Store everything in hex or base64.
      • parkercP Offline
        parkercP Offline
        parkerc
        What would I do without you 🙂
        Ok, so I can still write to a device variable in Vera, I’d just need to encode it first , in either one of those two options. e.g like this if base64?
        local function base64_encode(data)
        	local b='ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/'
            return ((data:gsub('.', function(x)
                local r,b='',x:byte()
                for i=8,1,-1 do r=r..(b%2^i-b%2^(i-1)>0 and '1' or '0') end
                return r;
            end)..'0000'):gsub('%d%d%d?%d?%d?%d?', function(x)
                if (#x < 6) then return '' end
                local c=0
                for i=1,6 do c=c+(x:sub(i,i)=='1' and 2^(6-i) or 0) end
                return b:sub(c+1,c+1)
            end)..({ '', '==', '=' })[#data%3+1])
        local key = string.char(unpack(key_vals)) - -
        local keyEnc = base64_encode(key)
        luup.variable_set("urn:nodecentral-net:serviceId:NodeCentral1","key",keyEnc, 1187)
          It's easier than that in Luup...
          local mime = require("mime")
          local encoded = mime.b64( "Hello world!" );
          local decoded = mime.unb64( encoded );
          luup.log( decoded, 2 )
          • parkercP Offline
            parkercP Offline
            parkerc
            Awesome, thanks - I often forget what’s already there in luup.. !
            Also am I right in saying that i only need to enc/dec in hex or base64 if I’m planning to store (read/write) those values/variables, if I can keep them ‘active; and flowing within the code itself (in memory) then, I’m ok ?
              Yes, in memory is fine. So for example, you may generate IV from random numbers byte by byte, put it through b64 or hex before storing it on a state variable. For openssl, you'll be giving key and IV in hex, so that seems a sensible way to keep it. Once it's converted to hex, you'll never need to reverse that, since it can be stored in a state variable as hex, and can be handed directly to openssl as hex.
              • parkercP Offline
                parkercP Offline
                parkerc
                This time round, I seem to have generated some new hex values this time, which I’ve used in a io.popen openssl command, feels a bit better, but sadly not quite yet right (yet).. FYI
                openssl enc -aes-128-cbc -nosalt -e -a -A -in etc/payload.txt -K 'enNIQi9wNmYxd1RDUXMvNHJhdHNGZz09' -iv 'B6B1919A88C696AE87A692B1BBADCE9B' -out etc/payload2.txt
                non-hex digit
                invalid hex key value
                  Well the key you show is definitely not hex, because 16 bytes of hex should be 32 characters long with only 0-9, A-F. Looks like you have base64 for the key, not hex.
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Progress at last ! well I’ve at least got the key and iv in the correct hex format for the OpenSSL aes cbc encryption command to work.🥳
                    Which leads me on to the next part, where the output of the above is referred to as the ciphertext;, of which I now need to do the following with..
                      ciphertext = MyopensslAEScbcCall()
                      sig = encdec.hmacsha256(ciphertext, hmac_key, true)
                      encrypted_payload = encdec.base64enc(ciphertext .. sig)
                      return encrypted_payload
                    hmacsha256 seems to be next, and it might also be something I could do with OpenSSL too ? -> https://unix.stackexchange.com/questions/610039/how-to-do-hmacsha256-using-openssl-from-terminal ?
                    I also found this too - https://github.com/jqqqi/Lua-HMAC-SHA256/blob/master/sha256.lua
                    @toggledbits any suggestions/recommendations on what to do with this next part ?
                      I would stick with OpenSSL. You just need to assemble the correct bits (HMAC key and ciphertext) to send to the hash function, compute the hash, then append the hash to the ciphertext. The trick here will be that you currently have the AES encyption outputting its result base64-encoded... you can't append the signature to that. You need the ciphertext output in binary for that, so you need to remove the -a (and -A) to let the output be binary. Then you can put that into the hash. And then you can take the (binary) hash output and append that to the binary ciphertext, and then you base64 encode the assembled result at the very end. The whole thing takes a few steps. I would recommend writing a shell script to do all the steps, and just have Lua run the shell script. You can then more easily develop and test the steps (because they are all in the shell script and runnable from the command line).
                      parkercP 1 Reply Last reply
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        Thanks @toggledbits - I struggle enough with Lua, so i admire your optimism in thinking I could create a shell script too 🙂
                        I must admit, I can’t help but feel like I’m making this more complicated that it needs to be, especially as there are working Lua and Python scripts already out there, which seem to be doing everything natively (although I do admit much of this thread is trying to plug holes in Vera 😞 )
                        With that said, the following might help you understand the bigger picture of what I’m trying to replicate, and maybe help me more, as I found some related posts, the first one which uses python e.g. https://github.com/florianholzapfel/panasonic-viera/issues/9 - and I’ve extracted the related HMAC part below.
                        # Let's encrypt it with AES-CBC! We need to make sure we pad it to a multiple of 16 bytes beforehand
                        aes = AES.new(key, AES.MODE_CBC, iv)
                        ciphertext = aes.encrypt(pad(payload))
                        # Calculate the HMAC-SHA-256 signature of our encrypted payload
                        sig = hmac.new(hmac_key, ciphertext, hashlib.sha256).digest()
                        # Concatenate the HMAC signature to the encrypted payload and base64 encode it, and we're done!
                        encrypted_payload = base64.b64encode(ciphertext + sig)
                        Plus there’s this pure Lua version called Haslib -> https://github.com/howmanysmall/Rewrites/blob/master/src/HashLib.lua - which looks like it might be promising to add to Vera as a module ?
                        USAGE:
                        	Input data should be a string
                        	Result (SHA digest) is returned in hexadecimal representation as a string of lowercase hex digits.
                        	Simplest usage example:
                        		local HashLib = require(script.HashLib)
                        		local your_hash = HashLib.sha256("your string")
                        Looking at the functions within the latter HashLib.lua file, it has one called local function hmac(hash_func, key, message) which makes me wonder could i use that and do the following.. ?
                        local mySig = HashLib.hmac(sha256, ciphertext, hmac_key)
                          #21
                          Approach however you want, it's yours to choose, of course. I can just recommend (and you asked). My experience is that snatching random code snippets from Github can be hit or miss, and if it's a miss, it will take longer to find because of your implicit trust of "working" code by others. OpenSSL is widely-used and well-known. It is, for practical purposes, a reference standard. If you find "good code" on Github and it turns out it isn't, it will likely be a long time before you figure it out, because you'll trust it, even though you should not. And in this scenario, with so much computation, and in so many steps, it's all a black box and debugging any piece of it will be extremely challenging. You'll post here when it doesn't work and I and anyone else won't be able to help you, because we can verify it either. Using a known-good tool, even if you struggle to get to know it, will give you a more reliable result, because then you are only fighting with your handling of the inputs and outputs and getting the steps right and in the right order. You should use the best tools possible to minimize the number of variables in the equation. Once you know how it all works, you see it all hang together, and you've got some "sand in your pants" as they say, then you can start replacing with other things, if necessary.
                          The other issue is that no Lua implementation, of crypto in particular, which can be very complex and iterative, is going to be more efficient than the C/C++-based, optimized implementation of OpenSSL. That matters on the weak CPUs we are working with.
                          At a minimum, you should get your procedure working on the command line, with all the steps and a full cycle of encode and decode with a couple of different payloads. Once you have that, you have something (known inputs and known outputs/results) you can use to test Lua replacements, because you have known benchmarks to compare to. If you don't know what a particular input will produce on the output, you will never know if any piece of code you find is correct or not.
                          • parkercP Offline
                            parkercP Offline
                            parkerc
                            Thanks so much @toggledbits for your open and honest feedback, I really appreciate it. Taking your advice I’m going to persist with OpenSSL to get this next encrypted payload step done.
                            How does this set of next steps look to you ..?
                            Step 1, Adjust the OpenSSL ciphertext aes-cbc command, so it outputs in binary (do this by removing the -a (and -A) parameters ).
                            Step 2, When it comes to the hmac_key , it looks like it created in the following way, and as I can’t see any hex or base64 references, only bit - is it already using the right binary format ?
                            local bit = require("bit")
                            local binascii = require("binascii")
                            function createHMACKey()
                            	local iv_vals = { iv:byte(1, -1) }
                            	local hmac_key_mask = binascii.unhexlify('15C95AC2B08AA7EB4E228F811E34D04FA54BA7DCAC9879FA8ACDA3FC244F3854')
                            	local hmac_key_mask_vals = { hmac_key_mask:byte(1, -1) }
                            	local hmac_vals = {}
                            	for i = 1, 32, 4 do
                            		hmac_vals[ i ] = bit.bxor(hmac_key_mask_vals[ i ], iv_vals[ bit.band(i + 1, 0xF) + 1 ])
                            		hmac_vals[ i + 1 ] = bit.bxor(hmac_key_mask_vals[ i + 1 ], iv_vals[ bit.band(i + 2, 0xF) + 1 ])
                            		hmac_vals[ i + 2 ] = bit.bxor(hmac_key_mask_vals[ i + 2 ], iv_vals[ bit.band(i - 1, 0xF) + 1 ])
                            		hmac_vals[ i + 3 ] = bit.bxor(hmac_key_mask_vals[ i + 3 ], iv_vals[ bit.band(i, 0xF) + 1 ])
                            	local hmac_key = string.char(unpack(hmac_vals))
                            	print(hmac_key)
                            	return hmac_key
                            createHMACKey()
                            Step 3. Use openSSL to encrypt the binary ciphertext and binary hmac_key with hmacsha256 to create the sig (signature)
                            Step 4. Then using mime.base64, encrypt the ciphertext with the new singnature to create the payload
                              parkercP Offline
                              parkercP Offline
                              parkerc
                              Hi @toggledbits
                              If/when you have time , I’d really appreciate some further help..
                              Quick reminder of my current goal, which is to convert the following 3 steps, so an equivalent can run on Vera.
                              One..
                              aes_cbc, err = aes:new(key, nil, aes.cipher(128, 'cbc'), { iv = iv }, nil, 1)
                              ciphertext = aes_cbc:encrypt(payload)
                              Two..
                              Three..
                              @toggledbits said in Lua - Code to encrypt / decrypt with AES 128 CBC:
                              You make it sound so easy, I’d love to get this to work.. 🙂
                              Looking at the guide (https://linux.die.net/man/1/openssl ) I’m trying to see how the command results in a the output being base64 encoded ?
                              opensslAES128command = "openssl enc -aes-128-cbc -nosalt -e -a -A -in etc/payload.txt -K  "..key.." -iv "..iv.." -out etc/payload2.txt"
                              The above command output this....
                              gGBjfMi+lMGhQYdhjy1UWuRCtY1WIE07CmQ5aW/jITDYbe8I01QxtYfXzkpk4km8
                              I also tried the above command, without both the -a -A options and it returns this…
                              €`c|Ⱦ”Á¡A‡a-TZäBµV M;
                              d9ioã!0ØmïÓT1µ‡×ÎJdâI¼
                              is this binary ?
                              Next when you say hash do you mean the second part, the encdec.hmacsha256 piece ? If so what exactly am I hashing ? Are (ciphertext, hmac_key, true) all concatenation into one long string ? Like this maybe ?
                              openssl dgst -sha256 -hmac $(<etc/my ciphertext,-hmac_key.txt) etc/hmacoutput.txt
                              With mime.b64 I think, I’m good on the last step ..
                              Totally agree I just need to ensure I have right ones ?
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                #24
                                I’m still persevering with this one, but something’s not quite right, so hopefully the following with help people help me..
                                1. I send a request to the TV to obtain a PIN Code, which it presents on the screen e.g 1234
                                2. It also provides me with a Challenge Key.
                                --[[ challenge key returned will be something like this..
                                		<?xml version="1.0" encoding="utf-8"?>
                                			<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                                			<s:Body>
                                				<u:X_DisplayPinCodeResponse xmlns:u="urn:panasonic-com:service:p00NetworkControl:1">
                                				<X_ChallengeKey>iL9XqQOMfkFWz2rvh0Xm+w==</X_ChallengeKey>
                                				</u:X_DisplayPinCodeResponse>
                                			</s:Body>
                                			</s:Envelope>
                                I extract the challenge key and store it, and to give me options, I also store a base64 and a Hex version too.
                                challenge_Key = string.match(pairing_res,'<X_ChallengeKey>(.*)</X_ChallengeKey>')
                                luup.variable_set(PANI_SERV,"challenge_Key",challenge_Key,DEVICE)
                                local iv_b64 = mime.b64(challenge_Key)
                                luup.variable_set(PANI_SERV,"iv_b64",iv_b64,DEVICE)
                                local iv_HEX = binascii.hexlify(challenge_Key)
                                luup.variable_set(PANI_SERV,"iv_HEX",iv_HEX,DEVICE)
                                Which gives me..
                                challenge_Key = 6Sj5RAitzqplQ860TviWLw==
                                challenge_Key_b64 = NlNqNVJBaXR6cXBsUTg2MFR2aVdMdz09
                                challenge_Key_HEX = 36536A35524169747A71706C51383630547669574C773D3D
                                So far so good, and going forward base64 version will be known as IV.
                                Next step is to take the IV and create a KEY and a HMAC_KEY, which I do the following way..
                                1st the KEY
                                local iv = luup.variable_get(PANI_SERV,"iv", DEVICE)
                                local key_vals = {}
                                	for i = 1, 16, 4 do
                                		key_vals[ i ] = bit.band(bit.bnot(iv_vals[ i + 3 ]), 0xFF)
                                		key_vals[ i + 1 ] = bit.band(bit.bnot(iv_vals[ i + 2 ]), 0xFF)
                                		key_vals[ i + 2 ] = bit.band(bit.bnot(iv_vals[ i + 1 ]), 0xFF)
                                		key_vals[ i + 3 ] = bit.band(bit.bnot(iv_vals[ i ]), 0xFF)
                                luup.variable_set(PANI_SERV,"key",key,DEVICE)
                                And then the HMAC_KEY
                                	for i = 1, 32, 4 do
                                luup.variable_set(PANI_SERV,"hmac_key",hmac_key,DEVICE)
                                This then gives me the following..
                                Key = ޱ“±½µ©±É­§žŒ½§œ
                                key_HEX = 8EB193B1BDB5A9B1C9ADA79E8CBDA79C
                                hmac_key = [¸®úÈé½îÙ\G³ë:é°æÚ7¬Øû¤f<[
                                hmac_key_HEX = 5BB814AEFAC8E9BD1C14EED95C47B317EB3AE9B0E6DA37ACD8FBC2A4663C5B0C
                                Once I have these available I then need to create the payload which these will be used to help encrypt etc.
                                The payload creation process is uses the PIN number presented at the very start.
                                local data = "<X_PinCode>5852</X_PinCode>"
                                local payload = '000000000000'
                                local n = #data
                                	payload = payload .. string.char(bit.band(bit.rshift(n, 24), 0xFF))
                                	payload = payload .. string.char(bit.band(bit.rshift(n, 16), 0xFF))
                                	payload = payload .. string.char(bit.band(bit.rshift(n, 8), 0xFF))
                                	payload = payload .. string.char(bit.band(n, 0xFF))
                                	payload = payload .. data
                                luup.variable_set(PANI_SERV,"payload",payload,DEVICE)
                                Which returns this.
                                payload = 0000000000005852
                                The modules I have in use are as follows..
                                Does all of the above look correct?
                                These are important parts to take this into the openSSL requests earlier in this thread, which so far (used as HEX) are throwing errors (invalid/too long)
                                • parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  Calling the likes of @toggledbits , @akbooer , @therealdb to help check my logic below, as I’ve been trying to get this to work for a while now, and feel I need to step back and just check some of the basics are correct, before I even get into the ciphers/encryption part..
                                  Here goes, using a http command , I can get a random PIN number (e.g. 1234) and the following XML response back from the TV, as it’s the Challenge_key I need first, I extract that..
                                   <s:Body>
                                   </s:Body>
                                  </s:Envelope>
                                  Guidance online suggests I then need to encode that in Base64, which would be this..
                                  local challenge_key = "iL9XqQOMfkFWz2rvh0Xm+w=="
                                  local challenge_Key_b64 = mime.b64(challenge_key)
                                  print (challenge_Key_b64)
                                  Which gives me this..
                                  aUw5WHFRT01ma0ZXejJydmgwWG0rdz09
                                  To then get the key which I assume is the real encryption key, it looks like I would do the following…
                                  local challenge_Key_b64 = "aUw5WHFRT01ma0ZXejJydmgwWG0rdz09"
                                  local challengekey_vals = { challenge_Key_b64:byte(1, -1) }
                                  local key_vals = {}
                                  for i = 1, 16, 4 do
                                  	key_vals[ i ] = bit.band(bit.bnot(challengekey_vals[ i + 3 ]), 0xFF)
                                  	key_vals[ i + 1 ] = bit.band(bit.bnot(challengekey_vals[ i + 2 ]), 0xFF)
                                  	key_vals[ i + 2 ] = bit.band(bit.bnot(challengekey_vals[ i + 1 ]), 0xFF)
                                  	key_vals[ i + 3 ] = bit.band(bit.bnot(challengekey_vals[ i ]), 0xFF)
                                  print(key)
                                  Which give me this..
                                  ʈªž­¹·¨’ÎÏ«§¥Ïž
                                  I’m conscious at this point that I’m using a web based Lua IDE, so I’m not sure if the values returned are accurate, plus @toggledbits has recommended HEX which sounds ideal, but for now I just want to be sure I’m working through it correctly?
                                  Continuing on, next step is to get the hmac_val - and it looks like I need to use the same challengekey_vals to generate the hmac_key
                                  local challengekey_64 = "aUw5WHFRT01ma0ZXejJydmgwWG0rdz09"
                                  local challengekey_vals = { challengekey_64:byte(1, -1) }
                                  for i = 1, 32, 4 do
                                  	hmac_vals[ i ] = bit.bxor(hmac_key_mask_vals[ i ], challengekey_vals[ bit.band(i + 1, 0xF) + 1 ])
                                  	hmac_vals[ i + 1 ] = bit.bxor(hmac_key_mask_vals[ i + 1 ], challengekey_vals[ bit.band(i + 2, 0xF) + 1 ])
                                  	hmac_vals[ i + 2 ] = bit.bxor(hmac_key_mask_vals[ i + 2 ], challengekey_vals[ bit.band(i - 1, 0xF) + 1 ])
                                  	hmac_vals[ i + 3 ] = bit.bxor(hmac_key_mask_vals[ i + 3 ], challengekey_vals[ bit.band(i, 0xF) + 1 ])
                                  print(hmac_key)
                                  Which give me this…
                                  bü;—öØð£OÛ±Dl±Ò~ƉêÊ.²» ÷Ì~Yd
                                  And then I think to get the IV, i would do the following.
                                  local payload = '000000000000' -- First 12 bytes are randomised
                                  local pincode = "<X_PinCode>1234</X_PinCode>"  -- Next 4 bytes are from the pincode prompted by the TV
                                  n = #pincode
                                  payload = payload .. pincode
                                  local iv = payload
                                  print(iv)
                                  Which returns this ..
                                  0000000000001234
                                  Does all of the above look correct to create the 3 items needed below.. ?
                                  Key = ʈªž­¹·¨’ÎÏ«§¥Ïž
                                  HMAC_KEY = bü;—öØð£OÛ±Dl±Ò~ƉêÊ.²» ÷Ì~Yd
                                  IV = 0000000000001234
                                  • parkercP parkerc
                                     <s:Body>
                                     </s:Body>
                                    </s:Envelope>
                                    local key_vals = {}
                                    for i = 1, 16, 4 do
                                    print(key)
                                    ʈªž­¹·¨’ÎÏ«§¥Ïž
                                    for i = 1, 32, 4 do
                                    print(hmac_key)
                                    Which give me this…
                                    n = #pincode
                                    local iv = payload
                                    print(iv)
                                    0000000000001234
                                    @parkerc said in Lua - Code to encrypt / decrypt with AES 128 CBC:
                                    Looks to me that iL9XqQOMfkFWz2rvh0Xm+w== is already in base64, and that would make sense, given that's been sent to you via HTTP.
                                    • parkercP Offline
                                      parkercP Offline
                                      parkerc
                                      #27
                                      Thanks @akbooer - you’re so right i cant believe i missed that, I’m supposed to decode, not encode ! Doh !!
                                      FYI - Here’s the source.. https://github.com/florianholzapfel/panasonic-viera/issues/9#issuecomment-476919658
                                      How did the rest look ? Here’s my Lua inline with the source.
                                      -- import binascii
                                      -- import base64
                                      -- import hmac, hashlib
                                      -- from Crypto.Cipher import AES
                                      -- # Example challenge (which is our IV)
                                      -- iv = base64.b64decode("mUQdS7/RyJTMsiojPz9i1Q==")
                                      local challenge_Key_unb64 = mime.unb64(challenge_key)
                                      print (challenge_Key_unb64)
                                      -- # Get character codes from IV bytes
                                      -- iv_vals = [ord(c) for c in iv]
                                      -- # Initialise key character codes array
                                      -- key_vals = [0] * 16
                                      -- # Derive key from IV
                                      -- i = 0
                                      -- while i < 16:
                                      --     key_vals[i] = ~iv_vals[i + 3] & 0xFF
                                      --     key_vals[i + 1] = ~iv_vals[i + 2] & 0xFF
                                      --     key_vals[i + 2] = ~iv_vals[i + 1] & 0xFF
                                      --     key_vals[i + 3] = ~iv_vals[i] & 0xFF
                                      --     i += 4
                                      -- # Convert our key character codes to bytes
                                      -- key = ''.join(chr(c) for c in key_vals)
                                      local challenge_Key_unb64 = "ˆ¿W©Œ~AVÏjï‡Eæû"
                                      local challengekey_vals = { challenge_Key_unb64:byte(1, -1) }
                                      local key_vals = {}
                                      for i = 1, 16, 4 do
                                      print(key) -- "V¨@w¾sü•0©ºx     "
                                      -- # Initialise HMAC key mask (taken from libtvconnect.so)
                                      -- hmac_key_mask_vals = [ord(c) for c in binascii.unhexlify("15C95AC2B08AA7EB4E228F811E34D04FA54BA7DCAC9879FA8ACDA3FC244F3854")]
                                      -- # Initialise HMAC key character codes array
                                      -- hmac_vals = [0] * 32
                                      -- # Calculate HMAC key using HMAC key mask and IV
                                      -- i = 0
                                      -- while i < 32:
                                      --     hmac_vals[i] = hmac_key_mask_vals[i] ^ iv_vals[(i + 2) & 0xF]
                                      --     hmac_vals[i + 1] = hmac_key_mask_vals[i + 1] ^ iv_vals[(i + 3) & 0xF]
                                      --     hmac_vals[i + 2] = hmac_key_mask_vals[i + 2] ^ iv_vals[i & 0xF]
                                      --     hmac_vals[i + 3] = hmac_key_mask_vals[i + 3] ^ iv_vals[(i + 1) & 0xF]
                                      --     i += 4
                                      -- # Convert our HMAC key character codes to bytes
                                      -- hmac_key = ''.join(chr(c) for c in hmac_vals)
                                      for i = 1, 32, 4 do
                                      	hmac_vals[i] = bit.bxor(hmac_key_mask_vals[ i ], challengekey_vals[ bit.band(i + 1, 0xF) + 1 ])
                                      	hmac_vals[i+1] = bit.bxor(hmac_key_mask_vals[ i + 1 ], challengekey_vals[ bit.band(i + 2, 0xF) + 1 ])
                                      	hmac_vals[i+2] = bit.bxor(hmac_key_mask_vals[ i + 2 ], challengekey_vals[ bit.band(i - 1, 0xF) + 1 ])
                                      	hmac_vals[i+3] = bit.bxor(hmac_key_mask_vals[ i + 3 ], challengekey_vals[ bit.band(i, 0xF) + 1 ])
                                      print(hmac_key) --"B`Ò}Îˤg$ÍÙNøÏWòâ/cÒÙzvà"õ3´¿""
                                      -- # This is our plaintext SOAP argument for the pin code shown on the TV
                                      -- authinfo = "<X_PinCode>4410</X_PinCode>"
                                      -- # First 12 bytes are randomised, let's just set them to 0 because it doesn't matter
                                      -- payload = "000000000000"
                                      -- # The next 4 bytes contain the plaintext (SOAP arg) length in big endian
                                      -- n = len(authinfo)
                                      -- payload += chr(n >> 24)
                                      -- payload += chr((n >> 16) & 0xFF)
                                      -- payload += chr((n >> 8) & 0xFF)
                                      -- payload += chr(n & 0xFF)
                                      -- # Now we concatenate our payload, which is starting at byte 17 of the payload
                                      -- payload += authinfo
                                      n = #pincode
                                      local iv = payload
                                      print(iv) -- "0000000000001234"
                                      -- # Let's encrypt it with AES-CBC! We need to make sure we pad it to a multiple of 16 bytes beforehand
                                      -- aes = AES.new(key, AES.MODE_CBC, iv)
                                      -- ciphertext = aes.encrypt(pad(payload))
                                      -- # Calculate the HMAC-SHA-256 signature of our encrypted payload
                                      -- sig = hmac.new(hmac_key, ciphertext, hashlib.sha256).digest()
                                      -- # Concatenate the HMAC signature to the encrypted payload and base64 encode it, and we're done!
                                      -- encrypted_payload = base64.b64encode(ciphertext + sig)
                                      Still the AES/CBC bit to get working, but hopefully this is progress..
                                        163.3k
