  3. 'Random' lights turning on
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
12 Posts 4 Posters 4.2k Views 4 Watching
    I thought I had created a topic on this some time back, but can't find it to close the loop.
    The issue was the lights on my drive appeared to be randomly switching on, with nothing from MSR logging and just a simple 'turn this on' in Openluup logs.
    Finally got to the bottom of it this morning, which might help someone.
    Turns out that somehow Alexa has decided that my drive lights are part of my Living room. If I tell her 'Living room lights on' the drive lights also come on. And if I tell her to turn them off, they also go off.
    Which is madness because they are NOT in the living room group.
    Current solution is to disable the drive lights in the Alexa app, which is fine as I never need to voice control them.
    • CatmanV2C CatmanV2 has marked this topic as solved on
      Bizarre! … but good catch.
      I’m a Siri user, myself. How do you link Alexa to openLuup? My link to Siri is via HomeKit (of course) for Hue and Shelly devices.
        Very bizarre, but I'm not going to troubleshoot Alexa!
        I had to actually think about the answer to the next bit. One of the things that worries me about my system and its integrations, it mostly just worked, and I forget how!
        Anyway: HA bridge. So several virtual devices that emulate Philips Hue devices. Alexa can see those natively, and HA bridge just makes an http call.
        I think the same set up would work with Siri, but have never checked, although I;m an Apple user, I standardised on Alexa
        • CatmanV2C CatmanV2 has marked this topic as unsolved on
          This way madness lies! I spoke too soon.
          If I speak to another Alexa device and say 'Living room lights on', all the lights in the living room come on correctly. (And the drive lights stay off)
          If I say to the Alexa device in the living room 'Turn the lights on' all the lights go on including the drive lights even though they are disabled in the app!
          Insanity.
          Appears to be fixed by adding the Drive lights to the Living room area, saving, then deleting them. We shall see!
            And we did. And it worked once, then reverted. Bloody Amazon!
              @CatmanV2Last night I said "Siri, turn on the TV" and my Alexa device replied "TV is not responding."
              Just to reinforce that I'd not stuttered or mispoken, Siri had (in fact) turned on the TV.
              They're all in cahoots.
                ...and then she laughed, and Jeff Bezos laughed, and Steve Jobs laughed 😉
                  mrFarmer
                  In Alexa there is an option that it 'learns' from 'your behavior'. When I turned that off and removed the rules it created for that 'feature' this spook behavior stopped. I would look into the rules on your Alexa, you may find some you do not remember creating.
                  Cheers Rene
                    Ooooh ta. Any pointers as to where they are in the app?
                    Cheers
                      mrFarmer
                      You had to ask 🙂
                      Have a look here https://www.amazonforum.com/s/question/0D56Q0000BafbkqSQA/alexa-created-routine-on-its-own
                      Cheers Rene
                        You are a gent sir, but I have no routines other than the single one I made (which works fine and has nothing to do with the the drive lights)
                        Very odd. I can delete the instance from HA bridge (or send it to a duff device ID for testing I guess)
                        Cheers
                          mrFarmer
                          Have you asked the wife? Mine likes to randomly turn lights on (never off!) just to get me confused 😁
                          Cheers Rene
                            164.5k
