  3. Hello and first network question
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
9 Posts 3 Posters 3.0k Views 3 Watching
  • D Offline
    D Offline
    Dr Paul
    Just bought a couple of generic smart plugs and set them up easily using SmartLife app in the house I then plugged one into a workshop over 100m away This workshop has a hardwired internet connection with a separate wireless access router (not mesh) after doing a reset on the device and pairing to the new router it actually works from the house when my phone is connected to a completely separate wifi network - how is that possible ?
    I did read something about these devices connecting to a server somewhere in China similar to IP cameras but there is no lag
      Welcome. That's exactly what they do, I'm afraid. I have a couple myself, but use a local hub (well it's a doorbell) and find them very effective bits of kit.
        Welcome! What is the workshop router connected to, the main router or the modem? Your can have separate wifi networks, but the devices will all be under one LAN unless you set up something like a VLAN for your workshop router.
        • D Offline
          D Offline
          Dr Paul
          Yes they are all on the same lan but everything still works when I connect to the main router/modem wifi which is separate with a different IP also when I do a network scan the devices don't show up. One of the smart switches has a " check network status " which shows the MAC address and an Ip that is my WAN
            If the IP addresses of one of the routers starts with a 192.XXX.XX.X then it is still under the same LAN network as the other router.
            Also these Smartlife wifi switches are probably connected to the cloud so they will work anywhere you have internet, so even if they are somehow on their own LAN network you will still have access to them. That is unless you blocked internet access for them in your router's settings.
            • D Offline
              D Offline
              Dr Paul
              I got two networks 192 168 2 xx and 192 168 1 xx. I scanned both and the devices don't show up maybe I'll turn off the internet and reset them to see what happens and perhaps try another app
                What's the subnet mask on those two networks?
                D 1 Reply Last reply
                  D Offline
                  D Offline
                  Dr Paul
                  @CatmanV2
                  255 255 255 0
                  both
                    Apologies for the delay. Unless you've done some vlanning, those two networks cannot see each other directly so they must be communicating via China. Unless I'm missing something!
                      164.0k
