  3. Looking for Remote Switch boxes that can also be used with a wireless Decora Style Switch.
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 2 Posters 2.5k Views 2 Watching
  • V Offline
    V Offline
    Venom
    Hi All,
    Kind of new to Home Automation. Started off Using Amazon Echo units and added a Samsung SmartThings hub. I have mostly been using plug in modules for turning lights on and off. I live in a very rural area where the internet goes out a lot. I eventually want to change to to a non internet Hub so things will work without needing an internet connection. But I will post with those questions at a later date.
    So, the task at hand is this: I have flood lights at each corner of my house. They are currently controlled by switches at the front and back doors. I would like to add Security Cameras to each corner also. I can easily find small Wifi switches to put into the electrical box where the flood lights are located, then I can terminate the leads together behind the Decora switch to have constant power. Then I can use the constant power up at the lights electrical box to power the security cameras. I would also like to have a wireless switch to take the place of the Decora switch to be able to turn the lights off and on.
    I cannot seem to find a product like this. It seems I can find the small wired in switch boxes that will also come with external smart wall switches, but the wall switches are an external box that does not fit in or cover the existing Wall switch electrical box. I can also find Wireless Decora switches that come with a remote wired in small switch box , but they all seem to be RF and do not integrate with a Smart Hub.
    I am hoping someone here knows of a product that matches what I am looking for. Any help would be appreciated.
    Also any recommendations for Wireless Security cameras are welcome.
    Thanks for any help.
      Not quite clear on what you’d need, but have you looked at the Shelly range of products for remote switching?
      • V Offline
        V Offline
        Venom
        I will look into Shelly, Thank you.
        I have also found this, which I think may be what I am looking for...
        (https://www.amazon.com/dp/B08TMWLY74/?coliid=ILBWG7JECYL7G&colid=2Z12AIGMR6R2K&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it)
          As it says, this will need a Zwave hub to work.
          • V Offline
            V Offline
            Venom
            Yes, I have a SmartThings Version 2 Hub. Do I need to use the Shelly Z wave relay switches or would the Shelly Wifi / Bluetooth switches also work with that Z wave Scene Controller wall switch I linked above?
              Not sure if your controller handles WiFi controlled devices?
                157.7k
