  3. Recommendation for a smart in-wall plug
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
3 Posts 3 Posters 2.3k Views 3 Watching
  • D Offline
    D Offline
    dhilbe
      sheraz99
      It sounds like you've got a solid plan to reset your HVAC system remotely using a smart plug! The high attic temperature is definitely a key concern here. Most consumer-grade smart plugs aren't designed for environments as hot as 135°F, but there are a few industrial-grade or higher temperature-rated options you could consider.
      Unfortunately, Wyze and Lutron don't currently offer smart plugs that can handle that kind of heat. However, here are some options that might work for your situation:
      Kasa Smart Wi-Fi Plug by TP-Link – This plug is reliable and WiFi-based, but it’s only rated for temperatures up to around 104°F. You could possibly mitigate the heat with some insulation or a vented enclosure.
      Insteon On/Off Outlet – While this requires the Insteon hub, it’s designed to withstand higher temperatures, and it's one of the more durable options available.
      Meross Smart Plug – Meross plugs are Wi-Fi based and may be more temperature-resistant compared to regular smart plugs. However, you'd need to check specific temperature limits.
      If none of these options work in the attic due to heat, you could consider placing the smart plug in a cooler area outside the attic, connected to a switch that controls the HVAC unit.
      Lastly, make sure the plug you choose can handle 15 amps and ensure that the installation adheres to local electrical codes for safety.
      • Peter19P Offline
        Peter19P Offline
        Peter19
        It’s a smart idea to use a smart plug to reset your Ecobee remotely. However, the high temperatures in the attic (up to 135°F) are definitely a concern since many smart plugs aren’t rated for that heat. Unfortunately, Wyze and Lutron Caseta don’t offer in-wall smart plugs that are rated for those temps. You might want to look into industrial-grade smart plugs that can handle extreme conditions, or maybe relocate the smart plug to a cooler spot near the attic access, if possible. Kasa makes some Wi-Fi-based options rated up to 104°F, but you'd need to confirm if they can handle brief periods of higher heat. Be sure to double-check the specs to ensure safety and longevity.
          165.5k
