  3. Eachen No Neutral smart wall switch to lights and Sonoff Mini R4 switch for LEDs
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
1 Posts 1 Posters 2.3k Views 1 Watching
    RenierWessels
    Hi all. First post so please be gentle.
    I have an Eachen two-gang smart wall switch wired no neutral (with capacitor) connected to existing bathroom lights which works perfectly. It's also wired to a Sonoff Mini R4 Extreme connected to LED lights. I want the LED lights to switch on when the bathroom lights switch on (and vice versa). The Mini R4 works separately on my phone via Ewelink as well as on the Mini R4 itself (physical button). The switch is installed inside the wall and the rest of the components are in the ceiling / attic / roof cavity. The Mini R4 is set to Edge switch mode which works in my example I wired.
    How I wired it:
    I have a video showcasing the example I wired today works. I could share it if required. Ignore the white cable. I only used it to power the example.
    The wiring diagram I used for the mini R4.
    I wired it together with the existing lights of the bathroom so that L1 switches on both the Mini R4 and the bathroom lights:
    This is the wiring diagram for the Eachen switch:
    The Eachen's first gang (L1) doesn't trigger the Mini R4 in any way.
    Any help or advice will be much appreciated.
    Thanks,
      165.5k
