Updated doco here.
Hope it works - YMMV.
Hey guys....
long time 😉
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
Hi akbooer,
tnks
donato
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
Yes. Noticed they stopped earlier so deleted and reloaded, nothing happened untill I restarted Mosquitto. So I kept an eye on them to see if they stopped again.
Then about 20 mins ago I was messing with the Tasmota's, so I did a reload and after that the shelly 1 stopped working (devices still in ui). So deleted them again and restart Mosquitto and then they reloaded.
Restarting mosquitto this is in log
2021-04-17 20:59:14.986 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=687035184&Timeout=60&MinimumDelay=1500&_=1618687270165 HTTP/1.1 tcp{client}: 0xf5619c8 2021-04-17 20:59:21.613 openLuup.io.server:: MQTT:1884 connection closed tcp{client}: 0xfc60a48 2021-04-17 20:59:21.614 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0xfc60a48 2021-04-17 20:59:21.616 openLuup.mqtt:: localhost.bridge-01 UNSUBSCRIBE from # tcp{client}: 0xfc60a48 2021-04-17 20:59:27.984 openLuup.io.server:: MQTT:1884 connection from 192.168.1.25 tcp{client}: 0xf096c288 2021-04-17 20:59:28.031 openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xf096c288 2021-04-17 20:59:28.033 luup.variable_set:: 30001.shellyix3-front.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.036 luup.variable_set:: 30007.shelly1-93BEFE.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.056 luup.variable_set:: 30002.shelly1-93A847.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.068 luup.variable_set:: 30005.shelly1-93FC56.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:28.384 openLuup.server:: request completed (4780 bytes, 1 chunks, 13396 ms) tcp{client}: 0xf5619c8 2021-04-17 20:59:28.453 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=687028312&_=1618687270166 HTTP/1.1 tcp{client}: 0xf5619c8 2021-04-17 20:59:28.931 openLuup.server:: request completed (766007 bytes, 48 chunks, 476 ms) tcp{client}: 0xf5619c8 2021-04-17 20:59:32.943 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:32.994 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=687035197&Timeout=60&MinimumDelay=1500&_=1618687270167 HTTP/1.1 tcp{client}: 0xf5619c8 2021-04-17 20:59:33.059 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:33.538 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:33.630 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 20:59:34.639 luup.variable_set:: 30004.shellyix3-rear.online was: EMPTY now: true #hooks:0 2021-04-17 20:59:34.763 openLuup.server:: request completed (3732 bytes, 1 chunks, 1767 ms) tcp{client}: 0xf5619c8 2021-04-17 20:59:34.813 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=687028316&_=
Devices still work after mosquitto restart
Will now reload luup and double check If this does infact cause devices to fail.
reload luup devices have now failed
log2021-04-17 21:04:07.840 openLuup.scheduler:: [25] BroadLink-Mk2 device startup completed: status=true, msg=All OK, name=BroadLink_Mk2 2021-04-17 21:04:07.841 openLuup.scheduler:: [46] Shelly device startup 2021-04-17 21:04:07.841 luup.set_failure:: status = 0 2021-04-17 21:04:07.842 luup.variable_set:: 46.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.843 luup.variable_set:: 46.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.843 openLuup.scheduler:: [46] Shelly device startup completed: status=true, msg=OK, name=ShellyBridge 2021-04-17 21:04:07.844 openLuup.scheduler:: [47] Tasmota device startup 2021-04-17 21:04:07.844 luup.set_failure:: status = 0 2021-04-17 21:04:07.844 luup.variable_set:: 47.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.845 luup.variable_set:: 47.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-17 21:04:07.846 openLuup.scheduler:: [47] Tasmota device startup completed: status=true, msg=OK, name=TasmotaBridge 2021-04-17 21:04:07.847 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.11,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.11,[{
2021-04-17 21:04:21.212 openLuup.server:: request completed (835 bytes, 0 chunks, 0 ms) tcp{client}: 0xfc86dd0 2021-04-17 21:04:21.214 openLuup.server:: GET /luvd/D_GenericShellyDevice.xml HTTP/1.1 tcp{client}: 0xf37a830 2021-04-17 21:04:21.215 openLuup.server:: request completed (293 bytes, 0 chunks, 0 ms) tcp{client}: 0xf37a830 2021-04-17 21:04:21.217 openLuup.server:: GET /luvd/D_Reactor.xml HTTP/1.1 tcp{client}: 0xfe92080 2021-04-17 21:04:21.221 openLuup.server:: request completed (1156 bytes, 0 chunks, 0 ms) tcp{client}: 0xfe92080 2021-04-17 21:04:21.222 openLuup.server:: GET /luvd/D_ReactorSensor.xml HTTP/1.1 tcp{client}: 0xff353d8 2021-04-17 21:04:21.224 openLuup.server:: request completed (1572 bytes, 0 chunks, 0 ms) tcp{client}: 0xff353d8 2021-04-17 21:04:21.226 openLuup.server:: GET /luvd/D_DimmableRGBLight1.xml HTTP/1.1 tcp{client}: 0xfe940f8 2021-04-17 21:04:21.229 openLuup.server:: request completed (1507 bytes, 0 chunks, 0 ms) tcp{client}: 0xfe940f8 2021-04-17 21:04:21.253 openLuup.server:: GET /luvd/D_ShellyBridge.xml HTTP/1.1 tcp{client}: 0xfd25c78
will now restart mosquitto without deleting devices.
Restarting mosquitto brings devices back to life.
log
2021-04-17 21:09:39.969 openLuup.io.server:: MQTT:1884 connection closed tcp{client}: 0xff53448 2021-04-17 21:09:39.972 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0xff53448 2021-04-17 21:09:39.973 openLuup.mqtt:: localhost.bridge-01 UNSUBSCRIBE from # tcp{client}: 0xff53448 2021-04-17 21:09:45.774 openLuup.io.server:: MQTT:1884 connection from 192.168.1.25 tcp{client}: 0xf527b20 2021-04-17 21:09:45.823 openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xf527b20 2021-04-17 21:09:45.826 luup.shelly:46: New Shelly announced: shellyix3-rear 2021-04-17 21:09:45.827 luup.attr_set:: 30004.ip = 192.168.1.105 2021-04-17 21:09:45.828 luup.attr_set:: 30004.mac = E8DB84D6E80A 2021-04-17 21:09:45.829 luup.attr_set:: 30004.model = SHIX3-1 2021-04-17 21:09:45.829 luup.attr_set:: 30004.firmware = 20210413-154502/v1.10.2-gb89901a 2021-04-17 21:09:45.906 luup.shelly:46: New Shelly announced: shelly1-93A847 2021-04-17 21:09:45.907 luup.attr_set:: 30002.ip = 192.168.1.102 2021-04-17 21:09:45.908 luup.attr_set:: 30002.mac = BCDDC293A847 2021-04-17 21:09:45.908 luup.attr_set:: 30002.model = SHSW-1 2021-04-17 21:09:45.909 luup.attr_set:: 30002.firmware = 20210415-125832/v1.10.3-g23074d0 2021-04-17 21:09:46.040 luup.shelly:46: New Shelly announced: shelly1-93FC56 2021-04-17 21:09:46.041 luup.attr_set:: 30005.ip = 192.168.1.100 2021-04-17 21:09:46.042 luup.attr_set:: 30005.mac = BCDDC293FC56 2021-04-17 21:09:46.043 luup.attr_set:: 30005.model = SHSW-1 2021-04-17 21:09:46.043 luup.attr_set:: 30005.firmware = 20210415-125832/v1.10.3-g23074d0 2021-04-17 21:09:46.360 luup.shelly:46: New Shelly announced: shellyix3-front 2021-04-17 21:09:46.361 luup.attr_set:: 30001.ip = 192.168.1.106 2021-04-17 21:09:46.362 luup.attr_set:: 30001.mac = E8DB84D6C6C8 2021-04-17 21:09:46.363 luup.attr_set:: 30001.model = SHIX3-1 2021-04-17 21:09:46.363 luup.attr_set:: 30001.firmware = 20210413-154502/v1.10.2-gb89901a 2021-04-17 21:09:51.275 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 21:09:51.594 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 21:09:51.647 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 21:09:51.936 luup.tasmota:47: JSON error: Expected value but found invalid token at character 1 2021-04-17 21:09:54.170 luup.shelly:46: New Shelly announced: shelly1-93BEFE 2021-04-17 21:09:54.171 luup.attr_set:: 30007.ip = 192.168.1.101 2021-04-17 21:09:54.172 luup.attr_set:: 30007.mac = BCDDC293BEFE 2021-04-17 21:09:54.172 luup.attr_set:: 30007.model = SHSW-1 2021-04-17 21:09:54.173 luup.attr_set:: 30007.firmware = 20210415-125832/v1.10.3-g23074d0 2021-04-17 21:10:00.117 luup_log:0: 13Mb, 0.8%cpu, 0.0days
OK Mosquitto reports bridge disconnect and 5 seconds later reconnects, when i reload luup.
I then power off 1 device and back on, Mosquitto reports device already connected,closing connection then new client shelly device and ip.
back in AltUI the device i power cycled is working , all other still not.
Here's what I found with my Shellies (more to come, I have a couple more on the test bench, not already connected).
- Shelly 1PM seems OK. Ext temperatures are not mapped, but the variable is crated:
This should be easily mapped. I don't have humidity attached, but it's similar, looking at the docs. - Shelly plug is not correctly mapped. Here's the announce payload:
{"id":"shelly-veraplug","model":"SHPLG-S","mac":"XXX","ip":"192.168.1.46","new_fw":true,"fw_ver":"20210323-105718/v1.10.1-gf276b51"}
It's mapped as a scene control, instead of a plug. Power variables are correctly saved.
As I've said, I have buttons, uni and EM on my test bench and I'll add them very soon, so I could help with code if necessary @akbooer .
Try v21.4.18 to see if the plug now works (it will create a separate child device.)
@akbooer all set now for shelly plug!
EDIT: I think category_num and subcategory_num should be set to at least 3/0, so the UI could filter them better.
So, the recommendation for Shelly 1 PM used as detached relay (input separated from relay) is to manually use the variables?
