  3. Plugins
  4. openLuup: Shelly Bridge plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
144 Posts 7 Posters 128.4k Views 6 Watching
    wrote on last edited by Elcid
    #36
    Restarting mosquitto brings devices back to life.
    log
    2021-04-17 21:09:39.969   openLuup.io.server:: MQTT:1884 connection closed  tcp{client}: 0xff53448
    2021-04-17 21:09:39.972   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0xff53448
    2021-04-17 21:09:39.973   openLuup.mqtt:: localhost.bridge-01 UNSUBSCRIBE from # tcp{client}: 0xff53448
    2021-04-17 21:09:45.774   openLuup.io.server:: MQTT:1884 connection from 192.168.1.25 tcp{client}: 0xf527b20
    2021-04-17 21:09:45.823   openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xf527b20
    2021-04-17 21:09:45.826   luup.shelly:46: New Shelly announced: shellyix3-rear
    2021-04-17 21:09:45.827   luup.attr_set:: 30004.ip = 192.168.1.105
    2021-04-17 21:09:45.828   luup.attr_set:: 30004.mac = E8DB84D6E80A
    2021-04-17 21:09:45.829   luup.attr_set:: 30004.model = SHIX3-1
    2021-04-17 21:09:45.829   luup.attr_set:: 30004.firmware = 20210413-154502/v1.10.2-gb89901a
    2021-04-17 21:09:45.906   luup.shelly:46: New Shelly announced: shelly1-93A847
    2021-04-17 21:09:45.907   luup.attr_set:: 30002.ip = 192.168.1.102
    2021-04-17 21:09:45.908   luup.attr_set:: 30002.mac = BCDDC293A847
    2021-04-17 21:09:45.908   luup.attr_set:: 30002.model = SHSW-1
    2021-04-17 21:09:45.909   luup.attr_set:: 30002.firmware = 20210415-125832/v1.10.3-g23074d0
    2021-04-17 21:09:46.040   luup.shelly:46: New Shelly announced: shelly1-93FC56
    2021-04-17 21:09:46.041   luup.attr_set:: 30005.ip = 192.168.1.100
    2021-04-17 21:09:46.042   luup.attr_set:: 30005.mac = BCDDC293FC56
    2021-04-17 21:09:46.043   luup.attr_set:: 30005.model = SHSW-1
    2021-04-17 21:09:46.043   luup.attr_set:: 30005.firmware = 20210415-125832/v1.10.3-g23074d0
    2021-04-17 21:09:46.360   luup.shelly:46: New Shelly announced: shellyix3-front
    2021-04-17 21:09:46.361   luup.attr_set:: 30001.ip = 192.168.1.106
    2021-04-17 21:09:46.362   luup.attr_set:: 30001.mac = E8DB84D6C6C8
    2021-04-17 21:09:46.363   luup.attr_set:: 30001.model = SHIX3-1
    2021-04-17 21:09:46.363   luup.attr_set:: 30001.firmware = 20210413-154502/v1.10.2-gb89901a
    2021-04-17 21:09:51.275   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
    2021-04-17 21:09:51.594   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
    2021-04-17 21:09:51.647   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
    2021-04-17 21:09:51.936   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
    2021-04-17 21:09:54.170   luup.shelly:46: New Shelly announced: shelly1-93BEFE
    2021-04-17 21:09:54.171   luup.attr_set:: 30007.ip = 192.168.1.101
    2021-04-17 21:09:54.172   luup.attr_set:: 30007.mac = BCDDC293BEFE
    2021-04-17 21:09:54.172   luup.attr_set:: 30007.model = SHSW-1
    2021-04-17 21:09:54.173   luup.attr_set:: 30007.firmware = 20210415-125832/v1.10.3-g23074d0
    2021-04-17 21:10:00.117   luup_log:0: 13Mb, 0.8%cpu, 0.0days
      so this does seem to be something to do with bridging with Mosquitto, rather than anything else...
      Is it just that you've recently noticed this, or did a recent update break this, I wonder?
        Did not notice as the variables in the I3's are not as easy to notice as a switch moving position
        i can return to previous version and check if you wish, what should i type instead of development is it 21.4.17?
          No, don't try that yet. I need to think rather than just react. I reboot all the time and the Shellies just keep on working.
            #40
            I was thinking that the bridge may be starting a new clean session when open luup reconnects after a reload, maybe that's an issue.
              This setting should make no difference to the openLuup MQTT server, since it keeps noothing but the basic session info. However, it may make a difference to Mosquitto.
                OK Mosquitto reports bridge disconnect and 5 seconds later reconnects, when i reload luup.
                I then power off 1 device and back on, Mosquitto reports device already connected,closing connection then new client shelly device and ip.
                back in AltUI the device i power cycled is working , all other still not.
                  It seems that this is related to the CLEAN SESSION flag. Can you configure Mosquitto to set that flag?
                    #44
                    Tried that last night both cleansession false and ture, no effect
                    I have posted the issue in the Eclypse forum.
                      #45
                      Here's what I found with my Shellies (more to come, I have a couple more on the test bench, not already connected).
                      • Shelly 1PM seems OK. Ext temperatures are not mapped, but the variable is crated:
                        90932026-6392-42c5-a8f6-9e47c0a08ae1-image.png This should be easily mapped. I don't have humidity attached, but it's similar, looking at the docs.
                      • Shelly plug is not correctly mapped. Here's the announce payload:
                      {"id":"shelly-veraplug","model":"SHPLG-S","mac":"XXX","ip":"192.168.1.46","new_fw":true,"fw_ver":"20210323-105718/v1.10.1-gf276b51"}
                      It's mapped as a scene control, instead of a plug. Power variables are correctly saved.
                      As I've said, I have buttons, uni and EM on my test bench and I'll add them very soon, so I could help with code if necessary @akbooer .
                        @therealdb
                        Try v21.4.18 to see if the plug now works (it will create a separate child device.)
                          @therealdb
                          #47
                          @akbooer all set now for shelly plug!
                          EDIT: I think category_num and subcategory_num should be set to at least 3/0, so the UI could filter them better.
                          So, the recommendation for Shelly 1 PM used as detached relay (input separated from relay) is to manually use the variables?
                            Good news on the plug. I haven't yet considered setting the (sub)category automatically, but it should be easy enough.
                            For any Shelly with switches, the generic device has the raw variables but also they're treated as a scene controller, so you have sl_SceneActivated and LastSceneTime available to you.
                              ArcherS
                              @akbooer I have a Shelly Plug (not the "S" variant) that I now finally setup on my test Pi to try the Shelly bridge.
                              The plug shows as it should in the Shellies room:
                              The following variables are mapped:
                              The payload is:
                              {"id":"shellyplug-6CC126","model":"SHPLG2-1","mac":"xxx","ip":"192.168.1.30","new_fw":false,"fw_ver":"20201124-092420/v1.9.0@57ac4ad8"}
                              However no child devices show up for the plug what I can see.
                              Is this something that can be added to the bridge, or have I missed anything in my setup?
                              (running OpenLuup v 21.4.18)
                              • A ArcherS
                                The payload is:
                                #50
                                @archers it needs to be mapped. If you go to line 416 of the Shelly bridge, you should be able to adapt it quickly, while @akbooer is busy coding it.
                                  Version 21.4.25 has the addition!
                                    ArcherS
                                    @akbooer that seems to have worked, now I get the child device and can control the plug on/off, thanks! 🙂
                                    • A ArcherS
                                      ArcherS
                                      @akbooer now on to my second Shelly, a Shelly Uni.
                                      Same thing here, I assume, no child devices are created some mapping is required.
                                      (For my Uni I have the two relays connected to two relays reading two states from the alarm, and no buttons connected to control the two inputs. In other words in my application I do not really need the input child devices.)
                                      It gets created as it should:
                                      Variables:
                                      The temperature gets mapped correctly.
                                      The two "relay" variables are the outputs for each channel are also as they should from what I can see.
                                      Payload:
                                      {"id":"shellyuni-483FDA82C252","model":"SHUNI-1","mac":"xxx","ip":"192.168.1.31","new_fw":false,"fw_ver":"20201124-093042/v1.9.0@57ac4ad8"}
                                      I think the "input" variables are the two buttons that you can control as a user that need child devices.
                                      If I remember it correctly @therealdb also has a Uni if you need more input from a second use case. 🙂
                                      • A ArcherS
                                        Variables:
                                        Payload:
                                        @archers said in openLuup: Shelly Bridge plugin:
                                        I literally have bought anything from them, but I've not fully deployed every device. I'm still waiting for my Uni and EM to be inserted. the EMs will soon monitor my AC, so I could detect if it's running or not (I have to use two switchbots to turn it on/off, because it's still under warranty and I could not mess with the original thermostat).
                                        All that said, I'm voting for automatic creation of child temp/humidity sensors, and for Uni to create relays and inputs separately. That's what most people will do, anyway.
                                          ArcherS
                                          @therealdb said in openLuup: Shelly Bridge plugin:
                                          @therealdb I still have an EM that I will setup over time to monitor the consumption of the spa and the HVAC.
                                          I also have a few more Shellies inbound in the mail; some Shelly 1's, a few 1PMs and a Button1. The plan is to replace a few aeging Aeotec relays that do not behave properly with the 1PMs. 🙂
                                          The Button1 I plan to use instead of a really old Zwave.me wall controller.
                                          I can second the thought on autocreation of temp/humidity and relay/input for the Uni if it is feasible to maintain. However not being a developer I am happy with what I get! 🙂
                                          The native Shelly and Tasmota support in OpenLuup together with the Mqtt support is a huge and really cool addition to the platform!
                                          akbooerA 2 Replies Last reply
                                            165.7k
